Civil Engineering Association eBooks Structural Books Concrete Fatigue of Fiber-reinforced Composites
 ska51
User ID: 11535
Threads: 382
Likes: 9,406 in 1,251 posts
Given Likes: 4017
07-19-2011, 03:41 AM
Fatigue of Fiber-reinforced Composites (Engineering Materials and Processes)
Author: Anastasios P. Vassilopoulos, Thomas Keller | Size: 3.3 MB | Format: PDF | Publisher: Springer | Year: 2011 | pages: 280 | ISBN: 1849961808
[Image: 62408727136806192295.jpg]
Fatigue has long been recognized as a mechanism that can provoke catastrophic material failure in structural applications and researchers are now turning to the development of prediction tools in order to reduce the cost of determining design criteria for any new material. Fatigue of Fiber-reinforced Composites explains these highly scientific subjects in a simple yet thorough way.
Fatigue behavior of fiber-reinforced composite materials and structural components is described through the presentation of numerous experimental results. Many examples help the reader to visualize the failure modes of laminated composite materials and structural adhesively bonded joints. Theoretical models, based on these experimental data, are demonstrated and their capacity for fatigue life modeling and prediction is thoroughly assessed.
Fatigue of Fiber-reinforced Composites gives the reader the opportunity to learn about methods for modeling the fatigue behavior of fiber-reinforced composites, about statistical analysis of experimental data, and about theories for life prediction under loading patterns that produce multiaxial fatigue stress states. The authors combine these theories to establish a complete design process that is able to predict fatigue life of fiber-reinforced composites under multiaxial, variable amplitude stress states. A classic design methodology is presented for demonstration and theoretical predictions are compared to experimental data from typical material systems used in the wind turbine rotor blade industry.
Fatigue of Fiber-reinforced Composites also presents novel computational methods for modeling fatigue behavior of composite materials, such as artificial neural networks and genetic programming, as a promising alternative to the conventional methods. It is an ideal source of information for researchers and graduate students in mechanical engineering, civil engineering and materials science.
"Downstream is Weaker"
[-] The following 8 users Like ska51's post:8 users Like ska51's post
  â€¢ kowheng, blaze, pssst, zrilek, Nilupa, mahyarov, Dell_Brett, Mohammad6299
 Flexi
User ID: 300
Likes: 5,440 in 422 posts
Given Likes: 110
04-30-2012, 02:21 AM
other link:
regards
Flexi
[-] The following 2 users Like Flexi's post:2 users Like Flexi's post
  â€¢ Dell_Brett, Jackass
 miquan
Vietnam
User ID: 631
Threads: 171
Likes: 3,748 in 387 posts
Given Likes: 1331
05-01-2012, 07:28 AM (This post was last modified: 05-01-2012, 08:04 AM by kowheng.)
[/MIRROR] 🔽🔽🔽🔽🔽🔽🔽🔽🔽
[-] The following 2 users Like miquan's post:2 users Like miquan's post
  â€¢ Dell_Brett, Mohammad6299
  Design procedures for the use of composites in strengthening of reinforced concrete s xnr09 3 3,023 02-06-2022, 08:27 AM
  Fiber-Reinforced Polymer: Reinforcement for Concrete Structures abudabeeja 1 2,985 05-21-2019, 06:35 AM
  Steel Fiber Reinforced Concrete: Behavior, Modelling and Design lisine 0 1,826 03-16-2017, 11:52 AM
  Reinforced Concrete Design with FRP Composites Ultra Zone 5 4,906 12-15-2014, 06:52 PM
  Fibre Reinforced cementitious Composites babak 3 3,550 07-04-2013, 01:23 PM
Last Post: ssobhan
  Failure Criteria in Fibre-Reinforced-Polymer Composites shadabg 0 1,629 12-27-2012, 12:39 PM
Last Post: shadabg
  High Performance Fiber Reinforced Cement Composites 6 ir_71 1 2,222 12-11-2012, 09:52 AM
Last Post: shadabg
