Civil Engineering Association eBooks Journals, Papers and Presentations A simplified 3D model for soil-structure interaction with radiation damping and...
 cve_jule
Macedonia
User ID: 6973
Threads: 28
Likes: 888 in 90 posts
Given Likes: 882
07-15-2011, 10:24 AM (This post was last modified: 07-15-2011, 10:14 PM by oanm2000.)
A simplified 3D model for soil-structure interaction with radiation damping and free field input
Author: V. Saouma · F. Miura · G. Lebon · Y. Yagome | Size: 701 KB | Format: PDF | Publisher: Bull Earthquake Eng | Year: 2011 | pages: 16
[Image: 85759340700022040474.jpg]
Bull Earthquake Eng
DOI 10.1007/s10518-011-9261-7
ORIGINAL RESEARCH PAPER
Received: 25 August 2010 / Accepted: 22 March 2011
© Springer Science+Business Media B.V. 2011
Abstract:
This paper addresses the time history finite element analysis of rock-structure interaction. Modeled is not only the lateral energy dissipation, but also the interaction between the far field and the numerical model itself. This is accomplished by a preliminary analysis of the far field as a shear beam (for lateral excitation), and then velocities and displacements are transferred to the model as nodal forces through damping and stiffness matrices respectively. Details of the finite element implementation are given, along with an extensive series of simulations comparing this method, with the one of Lysmer for both 2D and 3D models. The model is derived from the principle of virtual work, and its implementation does not require any modification of existing finite element codes, only clever pre and postprocessing of results are needed.
[-] The following 13 users Like cve_jule's post:13 users Like cve_jule's post
  • malc, chigozie, blaze, kowheng, oanm2000, aslam, Dell_Brett, Jackass, tluc, zrilek, Clouseau, DamirDz, peymanlord
  Soil-Structure Interaction of Retaining Walls under Earthquake Loads TAFATNEB 0 5,830 12-26-2014, 10:12 PM
  Seismic soil – pile – structure kinematic and inertial interaction — Anew beam approa TAFATNEB 0 4,718 08-12-2014, 01:28 PM
  Assessment of Soil-Structure Interaction Modeling Strategies for Response History Ana TAFATNEB 0 4,408 05-09-2014, 04:13 PM
  Modeling the Effects of Soil-Structure Interaction on a Tall Building Bearing on a Ma TAFATNEB 0 4,618 09-14-2013, 10:57 AM
  Non-Linear Seismic Soil-Structure Interaction Analysis Based on the Substructure Meth TAFATNEB 0 4,320 09-06-2013, 10:17 AM
  Influence of the soil–structure interaction on the fundamental period of buildings TAFATNEB 0 4,064 09-06-2013, 10:08 AM
  RECOMMENDATIONS FOR SOIL STRUCTURE INTERACTION (SSI) INSTRUMENTATION TAFATNEB 0 3,967 09-06-2013, 09:49 AM
