Civil Engineering Association eBooks Structural Books Analysis & Design Analysis and Modelling of Fiber-Wrapped Columns and Concrete-Filled Tubes
Threads: 1,298
Likes: 25,490 in 1,924 posts
07-08-2011, 04:27 PM
Author: Mohsen Shahawy, Tom Beitelman and Amir Mirmiran | Size: 3.1 MB | Format: PDF | Publisher: FDOT | Year: 1998 | pages: 93
[Image: 18177151195698153142.jpg]
Problem Statement
Fiber-wrapping offers a -high strength, low weight, and corrosion-resistant jacket which can be easily and quickly installed with negligible increase in the column's cross-section. Since the first application of fiber-wrapping technique to concrete chimneys in Japan (Katsumata and Yagi 1990), there has been an abundance of studies on the use of this technique. It has been put into practice in several states including California, Nevada, New York, and Vermont. Both carbon and glass fibers have been utilized, although carbon fibers are more expensive.
Since use of fiber composites for confinement of concrete is relatively new, theoretical work in this area is limited to the models that were originally developed for transverse steel reinforcement. However, it has been shown that concrete behaves very differently when confined by elasto-plastic materials such as steel as compared to linearly elastic materials such as fiber composites (Mirmiran and Shahawy 1997a). Applying the same models to fiber-wrapped concrete may result in overestimating the strength and unsafe design. In the absence of reliable models, construction industry may be forced to either avoid the use of advanced composites, or to incorporate high "factors of safety," making composite construction less economical. The PI has previously developed such a model for glass-wrapped concrete columns (Mirmiran 1997a&b). There is a need to extend the work to carbon-wrapped concrete columns.
Objectives
The objectives of this study were as follows:
1. Investigate the behavior of carbon-wrapped concrete specimens in uniaxial compression, based on the tests previously conducted by the Florida Department of Transportation.
2. Compare the experimental results with the confinement model of Samaan, Mirmiran and Shahawy (1998) which was developed for concrete-filled E-glass FRP tubes.
3. Compare the experimental results with a non-associative Drucker-Prager type plasticity model using the finite element analysis.
  • Jackass, sasan7351, kowheng, blaze, malc, pedzaquino, pabulumzeng, narendra, yutt, tluc, ajmf77, ladjin, igor1234
Threads: 54
09-24-2012, 07:52 PM
direct link
[-] The following 1 user Likes andersen3's post:1 user Likes andersen3's post
  • zrilek
09-24-2012, 09:05 PM
it's odd, the link posted above doesn't work for me, but I found this one that works:
[Image: 60928919175391555061.png]
which when coded became the same one posted by andersen3
anyways, try making the search by using google and those words:
Quote:Analysis and Modelling of Fiber-Wrapped Columns and Concrete-Filled Tubes Mohsen Shahawy, Tom Beitelman and Amir Mirmiran
the first result saying CHAPTER 4 CONFINEMENT MODELING - Florida Department of ... is the document you're looking for
[-] The following 4 users Like Grunf's post:4 users Like Grunf's post
  • sodapas, amir201, igor1234, simanta
Threads: 54
11-18-2013, 08:53 AM
link for the document:
password:
  • lisine, PinkPant, vardan
  Composite Structures of Steel and Concrete: Beams, Slabs, Columns, Frames Flexi 19 32,477 01-26-2022, 04:45 AM
Last Post: Veggeta
  Numerical Analysis and Modelling in Geomechanics Grunf 4 9,455 05-18-2017, 02:35 PM
Last Post: realbabilu
  Structural Analysis: Principles, Methods and Modelling cace-01 2 7,004 10-29-2015, 03:38 PM
Last Post: ibg0203
  Modern structural analysis: modelling process and guidance toa011 6 14,069 12-29-2014, 04:39 PM
Last Post: Veggeta
  The Modelling and Analysis of the Mechanics of Ropes ir_71 0 3,455 01-19-2014, 06:32 AM
  Design guide for SHS concrete filled columns ir_71 2 7,300 02-17-2012, 05:04 AM
Last Post: RedHorse
  Stability Analysis and Modelling in Fractured Rocks, Vol 1 by Jian Zhao, Weishen Zhu robertsas 1 5,640 11-22-2010, 08:36 AM
