Civil Engineering Association Various Free Discussion Water proofing compound for water tank?
 bascojhon
User ID: 24736
Threads: 2
Likes: 39 in 3 posts
Given Likes: 33
07-08-2011, 05:37 AM
Hi,
Pl suggest water proofing compound for water tank intended to use for my house
1) For mixing in concrete & In which ratio.
2) For Inside Plastering & In which ratio.
Thanks in advance.
 axee1980
User ID: 21327
Threads: 4
Likes: 34 in 10 posts
Given Likes: 218
07-08-2011, 09:58 AM
As you will be aware, there are plenty of construction waterproofing chemicals out there. You can check BASF, Fosroc, Sika etc etc. If I'm informed correctly Sika is quite common in india. Make sure you check the datasheet/supplier if the chemical is appropriate for potable water storage tanks (if that is the intended use of the tank).
 ruwan75
User ID: 11425
Threads: 5
Likes: 45 in 17 posts
Given Likes: 113
07-08-2011, 02:29 PM
there is another product called penetron seems to be very good product. this one you need to add to the concrete mix. you can Google it go to their website for more information. I think you should able to get this product as it popular world wide.
  Water supply system Drawings Adam Smith 0 3,894 09-25-2011, 01:01 AM
Last Post: Adam Smith
  Under water structures-tunnels luvtejas 0 3,897 04-30-2010, 06:47 AM
Last Post: luvtejas
