Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Archive [REQUEST] ASTM Standards - ASTM International
[Request] ASTM Standards - ASTM International
 whwy99
User ID: 18823
Threads: 22
Likes: 6 in 3 posts
Given Likes: 4
#91
06-04-2011, 02:20 PM
Dear all member,
l m looking for this ASTM. Thanks
  β€’
 whwy99
User ID: 18823
Threads: 22
Likes: 6 in 3 posts
Given Likes: 4
#92
06-05-2011, 01:42 PM
Dear all member,
Looking for this ASTM. Thanks
  β€’
 didie
User ID: 5839
Threads: 12
Likes: 16 in 11 posts
Given Likes: 32
#93
06-21-2011, 04:48 AM
Dear All,
If you had the following ASTM section please share it with us.
ASTM D1195/D1195M-09 Standard Test Method for Repetitive Static Plate Load Tests of Soils and Flexible Pavement Components, for Use in Evaluation and Design of Airport and Highway Pavements.
Many thanks in advance.
Cheers,
Didie
  β€’
 medo_sk
Macedonia
User ID: 18907
Threads: 39
Likes: 108 in 43 posts
Given Likes: 63
#94
06-23-2011, 06:25 AM (This post was last modified: 06-23-2011, 06:44 AM by kowheng.)
Hi Civileans,
I need:
- LUM.D.2, In-situ stress tests on masonry based on the flat jack, 1991
- LUM.D.3, In-situ strength/elasticity tests on masonry based on the flat-jack, 1990
from RILEM book:
RILEM Recommendations for the Testing and Use of Constructions Materials, 1994.
and
- ASTM, In-situ compressive stress within solid unit masonry estimated using flat-jack measurements, ASTM Standard C 1196-91, 1991
- ASTM, In-situ measurement of masonry deformability properties using flat-jack method, ASTM Standard C 1197-91, 1991
If anyone has this, please share it.
  β€’
 utan
Japan
User ID: 30193
Threads: 115
Likes: 1,654 in 158 posts
Given Likes: 1732
#95
07-12-2011, 12:23 PM
Please help me to find
ASTM D2573 - 08
Thanks in advance!
  β€’
 utan
Japan
User ID: 30193
Threads: 115
Given Likes: 1732
#96
07-14-2011, 09:53 AM
Dear All,
Please help me to find ASTM 6067-10.
Thanks in advance!
  β€’
 kegumingxin
User ID: 26179
Threads: 1
Likes: 1 in 1 posts
Given Likes: 2
#97
07-18-2011, 10:41 PM
Dear all,
Can you please upload the ASTM 7176? I need it for my work. Thank you.
  β€’
 hessi
User ID: 31872
Threads: 21
Likes: 116 in 18 posts
Given Likes: 75
#98
07-31-2011, 04:17 PM
Hi dudes
ASTMC230-90,Standard specification for flow table for use in tests of
hydraulic cement,Annual book of ASTM standards,vol.04.02.3.American
Society for Testing and Materials
I will appreciate if any body can help me by providing this code for me
  β€’
 ypyenpham
User ID: 21701
Threads: 22
Likes: 23 in 9 posts
Given Likes: 29
#99
08-03-2011, 05:15 AM
ASTM D3740 - 10 Standard Practice for Minimum Requirements for Agencies Engaged in Testing and/or Inspection of Soil and Rock as Used in Engineering Design and Construction
  β€’
 rkce
User ID: 25910
Threads: 56
Likes: 717 in 122 posts
Given Likes: 1282
#100
08-16-2011, 02:36 AM
Dear Members,
ASTM F1145 - 05(2011) Standard Specification for Turnbuckles, Swaged, Welded, Forged
Abstract
This specification covers swaged welded, cast, or forged turnbuckles with and without jam nuts. A turnbuckle is an internally threaded loop or sleeve intended for assembly with a threaded stud, eye, hook, or jaw at each end, used for applying tension to rods, wire rope, and so forth. Turnbuckles shall be of the following types and grades: Type I (forged, spread, resistance welded and arc or gas welded); Type II; and Type III. Turnbuckles shall be of the following classes; Class A; Class B; Class C; Class D; Class E; Class F; Class G; and Class H. The following tests shall be performed: proof test; breaking strength test; bending test; and galvanizing test.
Please share ASTM F1145 - 05(2011)!
Anyway is there any TIS or other standard similar to ASTM F1145?
Best regards,
rkce
  β€’
Pages (13): « Previous 1 … 4 5 6 7 8 9 10 11 12 13 Next »
  [REQUEST] ASTM E1300-12ae1? Glass Design Garylam1029 3 3,253 07-30-2019, 04:48 AM
Last Post: concreteok
  [REQUEST] ASTM D4694 - 09(2015): Standard Test Method for Deflections with a FWD type utan 2 2,417 01-20-2018, 08:10 AM
  [REQUEST] ASTM D1143/D1143M - 07 Standard Test Methods for Deep Foundations Under Static Axial scml2003 2 2,952 03-09-2017, 12:27 AM
Last Post: tomtumx
  [REQUEST] ASTM 2015 Annual Book abualamal 0 1,669 10-10-2015, 03:34 PM
Last Post: abualamal
  [REQUEST] ASTM A706 / A706M - 14 aslam 0 1,709 11-26-2014, 03:43 PM
Last Post: aslam
  [REQUEST] ASTM D-290 -91a and AASHTO T-172 ervikas34 0 1,487 10-16-2014, 01:15 AM
Last Post: ervikas34
  [REQUEST] (ASTM STP702) Full-Scale Load Testing of Structures apocalipse 0 1,625 08-19-2014, 08:59 PM
Last Post: apocalipse
