Civil Engineering Association eBooks Traffic Engineering Asphalt Mix Design and performance
06-02-2011, 06:35 AM
Author: Badaruddin and White, Thomas D | Size: 7.6 MB | Format: PDF | Publisher: Purdue University | Year: 1995 | pages: 209
[Image: 02475876307337734332.jpg]
Premature flexible pavement distress became a major concern in Indiana. As a result, a study was conducted investigating the major underlying factors. Pavement sections were investigated based on a factorial study with four factors comprised of climate, truck traffic, pavement base type, and wheel path. The distresses evaluated were rutting, thermal cracking and stripping. All were evaluated agaist control sections with zero distress. The pavement condition of each section was determined. Laboratory tests of field samples included physical properties, dynamic creep and recompaction. Results of the study indicate that the Asphalt Institute mix design criteria identify an asphalt content that is too high. Inplace densities were found to be inadequate and a recommendation was made to use higher field compactive effort. The USAE Gyratory Testing Machine (GTM) was used in laboratory" studies to recompact bulk samples of mixtures. Good agreement was shown between GTM and in situ bulk density and air voids. Tests confirm that the in situ asphalt content was too high. Gap graded gradations were found to be prone to rutting. Benefit is shown in using dynamic modulus to evaluate mixtures. A statistical analysis method, discriminant analysis, was used to accurately predict mixture field performance using laboratory data.
  â€¢ kowheng, malc, jayborre, cigutierrezg, Jackass, Adam Smith, sodapas, Dell_Brett, portal61
  MS-2 Asphalt Mix Design Methods - 7th Edition febo927 0 2,084 06-26-2018, 11:59 AM
Last Post: febo927
  Asphalt Materials and Mix Design Manual preceptor 4 4,691 03-16-2014, 02:49 AM
Last Post: Mohammad6299
  Synthesis of Performance Testing of Asphalt Concrete mahyarov 0 2,076 11-17-2012, 12:51 PM
Last Post: mahyarov
  Porous Asphalt Pavement Performance in Cold Regions mahyarov 0 1,994 11-10-2012, 11:49 AM
Last Post: mahyarov
  New Simple Performance Tests for Asphalt Mixes mahyarov 0 1,908 10-27-2012, 09:07 AM
Last Post: mahyarov
  Asphalt Emulsion Technology: Review of Asphalt Emulsion Residue Procedures mahyarov 0 1,946 10-27-2012, 08:35 AM
Last Post: mahyarov
  NCHRP - R648 Mixing and Compaction Temperatures of Asphalt Binders in Hot-Mix Asphalt mahyarov 0 1,941 10-23-2012, 04:25 PM
Last Post: mahyarov
