Civil Engineering Association Software Software Installation Problems & Bugs Archive Problem Etabs model checking
 rendel_©
Philippine
User ID: 1138
Threads: 115
Likes: 2,115 in 214 posts
Given Likes: 2687
08-04-2009, 08:26 AM
I just want to share how I check my model in etabs and correct me if I'm wrong or advice the proper way:
1.)Gravity
make a safe model for slab which is the thickness
= no. of storey x slab thicknness in etabs model
Apply the area load
=no. of storey x average area load apllied in etabs
(THE CONCEPT OF THIS IS I COMBINED ALL THE SLAB AND MODEL IT IN SAFE AS 0NE SLAB)
Reaction in etabs should almost equal to the reaction of safe.
Or, roughly compute the reaction at base manually(by tributary area method) then compare to etabs reaction result
2.) Wind
Go in show deformed shape then choose the Wx and Wy(one at a time) then click the top corner of the building then right click to see the point displacement. This value should less than to the allowable lateral deflection, in ubc H/500, H is the total height of the building.
3.) Earthquake
Actual drift should be less than to allowable drift
allowable drift= 0.7 x R x 0.020 x story height
(with the period of less 0.7second)
= 0.7 x R x 0.025 x story height
(with the period of equal or more than 0.7second)
R= overstrenght coefficient form table 16-N of UBC 97 PART 2
Based in UBC 97 code
I have less experience in high rise..I not yet try to check the drift, Anybody can discuss how to get the actual drift and what load combination used in UBC 97 code in getting the actual drift.
[-] The following 5 users Like rendel_©'s post:5 users Like rendel_©'s post
  • Yasir, Yasir, levanduy, levanduy, blackjack
 jaks
User ID: 2764
Threads: 11
Likes: 258 in 54 posts
Given Likes: 1225
08-04-2009, 08:43 AM
Hi,
The basic checks are correct, I do the area method to check the gravity loads, will try your method also.
For the drift the EQ in X & Y direction are to be checked by the formulae you mentioned.
Also check the base shears for the eqrthquake, and if you are defining spectrums check the proportion values.
I think that should do to carry on the designing part.
[-] The following 2 users Like jaks's post:2 users Like jaks's post
  • rendel_©, rendel_©
 juice
User ID: 108
Threads: 7
Likes: 362 in 68 posts
Given Likes: 176
08-04-2009, 04:56 PM
(08-04-2009, 08:26 AM)reynand_d Wrote: I just want to share how I check my model in etabs and correct me if I'm wrong or advice the proper way:
1.)Gravity
Apply the area load
2.) Wind
3.) Earthquake
interstory drift = 0.7*R*(ETABS results) < 0.020*story ht or 0.025*story ht
juice
[-] The following 6 users Like juice's post:6 users Like juice's post
  • rendel_©, rendel_©, shuvo, shuvo, Yasir, Yasir
 tarugo
User ID: 201
Threads: 14
Likes: 415 in 55 posts
Given Likes: 154
08-04-2009, 08:43 PM
remeber to check drift modifiers of members before running and checking drift model for ETABS. divide property modifiers of all members by 0.7 , ex. beam = 0.35/0.7 = 0.5, col = 0.7/0.7 = 1
[-] The following 4 users Like tarugo's post:4 users Like tarugo's post
  • rendel_©, rendel_©, Nedian, Nedian
 concreteok
E-Book Moderator
Malaysia
User ID: 4764
Threads: 38
Likes: 4,964 in 638 posts
Given Likes: 3501
08-05-2009, 01:43 AM
'Anybody can discuss how to get the actual drift and what load combination used in UBC 97 code in getting the actual drift.'
View from non (seldom) etabs user and 'british' region concrete designer;
Drift check
ULS to check p-delta effect
- through 'braced' and 'unbraced' frame categorisation
load combination : 1.4DL+1.4WL and 1.2DL+1.2LL+1.2WL
SLS to check tolerance of human to the drift
- through control of interstorey drift, different countries different limit, 1/500 common
load combination : 1.0DL+1.0WL and 1.0DL+0.8LL+0.8WL
All moment inertia of the members when running structural analysis have to be reduced as per aci 318 (this is a typical british problem, why don't they provide guidance?)
concrete solution advocate
[-] The following 2 users Like concreteok's post:2 users Like concreteok's post
  How to model in etabs with full span opening of shearwall at the bottom. rendel_© 4 8,314 03-07-2010, 08:02 PM
Last Post: iceman84
  model ribbed slab in only grid Etabs pedrozarth 0 5,722 02-01-2010, 07:00 PM
Last Post: pedrozarth
