Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Archive [REQUEST] ASTM Standards - ASTM International
[Request] ASTM Standards - ASTM International
 tynhanh
Vietnam
User ID: 19721
Threads: 107
Likes: 202 in 42 posts
Given Likes: 227
#81
05-06-2011, 02:32 AM
ASTM E11 - 09e1: Standard Specification for Wire Cloth and Sieves for Testing Purposes
 tynhanh
Vietnam
User ID: 19721
Threads: 107
Given Likes: 227
#82
05-11-2011, 05:29 AM
ASTM D4373 - 02(2007) Standard Test Method for Rapid Determination of Carbonate Content of Soils
 pelelo
Senior Member
User ID: 17858
Threads: 129
Likes: 49 in 39 posts
Given Likes: 242
#83
05-13-2011, 02:32 PM
ASTM D2487 Standard Practice for Classification of Soils for Engineering Purposes (Unified Soil Classification System)
Thanks
 tynhanh
Vietnam
User ID: 19721
Threads: 107
Given Likes: 227
#84
05-17-2011, 02:26 AM
ASTM D4648 / D4648M - 10 Standard Test Method for Laboratory Miniature Vane Shear Test for SaturatedFine-Grained Clayey Soil
 tynhanh
Vietnam
User ID: 19721
Threads: 107
Given Likes: 227
#85
05-17-2011, 02:47 AM
ASTM D2216 - 10 Standard Test Methods for Laboratory Determination of Water (Moisture) Content of Soil and Rock by Mass
 rohailiyaz
User ID: 925
Threads: 146
Likes: 1,152 in 117 posts
Given Likes: 733
#86
05-25-2011, 09:13 AM
Greetings
I need the following astm standard urgently
ASTM A121: Standard Specification for Metallic-Coated Carbon Steel Barbed
This specification covers metallic-coated steel barbed wire, consisting of a strand of two wires.
The barbed wire is available with aluminum, zinc, and zinc-5 % aluminum-mischmetal alloy coatings, with a number of coating weights, in a number of different constructions (designs), and in two grades. Not all designs are available in all coating types.
The values stated in inch-pound units are to be regarded as the standard. The values given in brackets are for information only.
The text of this specification references notes and footnotes that provide explanatory information. These notes and footnotes (excluding those in tables) shall not be considered as requirements of the specification.
barbed wire
carbon steel wire
metallic coated steel wire
steel barbed wire
wire
Rohail Iyaz
 rohailiyaz
User ID: 925
Threads: 146
Given Likes: 733
#87
05-25-2011, 11:25 AM
Can any guide and provide any astm or aci standard for the development length of piles both in tension and compression
Rohail Iyaz
 whwy99
User ID: 18823
Threads: 43
Likes: 6 in 3 posts
Given Likes: 4
#88
05-30-2011, 10:07 AM
Dear all,
Looking for this ASTM. Thx
 rohailiyaz
User ID: 925
Threads: 146
Given Likes: 733
#89
05-31-2011, 05:58 AM
Files doesn't exist...can you kindly re upload
[-] The following 1 user Likes rohailiyaz's post:1 user Likes rohailiyaz's post
  • utan
 shaker
User ID: 17336
Threads: 18
Likes: 714 in 73 posts
Given Likes: 537
#90
06-01-2011, 05:19 PM
ASTM A687-93 Standard Specification for High-Strength Nonheaded Steel Bolts and Studs (Withdrawn 1999)
1. Scope
1.1 This specification covers the chemical and mechanical requirements for quenched and tempered steel nonheaded bolts and studs with enhanced Charpy V-notch impact properties for anchorage and other purposes. The material shall be alloy steel as described in Table 1 and is limited to 5/8 to 3 in. (15.875 to 76 mm) inclusive, in nominal diameter.
1.2 This specification does not apply to mechanical expansion anchors for concrete or to powder-activated nails or studs for concrete or steel.
1.3 The values stated in inch-pound units are to be regarded as the standard. The values given in parentheses are for information only.
Pages (13): « Previous 1 … 4 5 6 7 8 9 10 11 12 13 Next »
  [REQUEST] ASTM E1300-12ae1? Glass Design Garylam1029 3 2,980 07-30-2019, 04:48 AM
Last Post: concreteok
  [REQUEST] ASTM D4694 - 09(2015): Standard Test Method for Deflections with a FWD type utan 2 2,174 01-20-2018, 08:10 AM
  [REQUEST] ASTM D1143/D1143M - 07 Standard Test Methods for Deep Foundations Under Static Axial scml2003 2 2,691 03-09-2017, 12:27 AM
Last Post: tomtumx
  [REQUEST] ASTM 2015 Annual Book abualamal 0 1,514 10-10-2015, 03:34 PM
Last Post: abualamal
  [REQUEST] ASTM A706 / A706M - 14 aslam 0 1,555 11-26-2014, 03:43 PM
Last Post: aslam
  [REQUEST] ASTM D-290 -91a and AASHTO T-172 ervikas34 0 1,374 10-16-2014, 01:15 AM
Last Post: ervikas34
  [REQUEST] (ASTM STP702) Full-Scale Load Testing of Structures apocalipse 0 1,478 08-19-2014, 08:59 PM
Last Post: apocalipse
