Civil Engineering Association eBooks Geotechnical Engineering Foundation & Geotechnics in general USDOT: Design and Construction of Mechanically Stabilized Earth Walls and Reinforced
Threads: 1,298
05-25-2011, 05:04 AM (This post was last modified: 01-05-2012, 10:48 PM by usman.)
GEOTECHNICAL ENGINEERING CIRCULAR NO. 11 Design of Mechanically Stabilized Earth Walls and Reinforced Soil Slopes – Volume I
Author: Ryan R. Berg, P.E.; Barry R. Christopher, Ph.D., P.E. and Naresh C. Samtani, Ph.D., P.E. | Size: 6.75 MB | Format: PDF | Publisher: FHWA | Year: 2009 | pages: 332
[Image: 43628765212245090228.jpg]
This manual is the reference text used for the FHWA NHI courses No. 132042 and 132043 on Mechanically Stabilized Earth Walls and Reinforced Soil Slopes and reflects current practice for the design, construction and monitoring of these structures. This manual was prepared to enable the engineer to identify and evaluate potential applications of MSE walls and RSS as an alternative to other construction methods and as a means to solve construction problems. The scope is sufficiently broad to be of value for specifications specialists, construction and contracting personnel responsible for construction inspection, development of material specifications and contracting methods. With the aid of this text, the engineer should be able to properly select, design, specify, monitor and contract for the construction of MSE walls and RSS embankments.
The MSE wall design within this manual is based upon Load and Resistance Factor Design (LRFD) procedures. This manual is a revision (to LRFD) and an update to the FHWA NHI- 00-043 manual (which was based upon allowable stress design (ASD) procedures).
GEOTECHNICAL ENGINEERING CIRCULAR NO. 11 Design and Construction of Mechanically Stabilized Earth Walls and Reinforced Soil Slopes – Volume II
Author: Ryan R. Berg, P.E.; Barry R. Christopher, Ph.D., P.E. and Naresh C. Samtani, Ph.D., P.E. | Size: 4.63 MB | Format: PDF | Publisher: FHWA | Year: 2009 | pages: 378
[Image: 05847714041594639927.jpg]
[-] The following 32 users Like ir_71's post:32 users Like ir_71's post
  • utan, llbb, zrilek, kowheng, blaze, civilteam, melkat, pedzaquino, tang1942, kaci, Evandrojr, PinkPant, Dell_Brett, cigutierrezg, oanm2000, seriousboy, Jackass, youceftli, malc, techno, sodapas, alibouafia, legarleon, amrshana, peymanlord, ting tsai huang, slowet, Josep Soroz, tonmjr, spat, shadabg, gulilero
 usman
User ID: 59
Threads: 138
Likes: 6,571 in 671 posts
Given Likes: 4974
01-16-2012, 10:24 PM
Direct Mirror (Volume I & 2 combined)
12.5MB
[-] The following 8 users Like usman's post:8 users Like usman's post
  • Dell_Brett, Jackass, kowheng, oanm2000, tonmjr, shadabg, blaze, gulilero
08-18-2012, 08:08 AM
[-] The following 4 users Like shadabg's post:4 users Like shadabg's post
  • Dell_Brett, Evandrojr, pmg814, SCREAM7890
 gulilero
Italy
User ID: 14057
Threads: 113
Likes: 4,989 in 647 posts
Given Likes: 6732
08-18-2012, 04:33 PM
I don't think Posts #2 and 3 correspond exactly to the references given in Post #1.
Links given in Post #1 are dead.
Kindly, repost if available.
  Earth Pressure and Earth-Retaining Structures, 3th Ed. odiclas 4 4,014 06-10-2021, 07:39 AM
  Drystone Retaining Walls: Design, Construction and Assessment (Applied Geotechnics) RyanRS 1 1,919 12-24-2015, 10:48 PM
Last Post: gulilero
  Diaphragm Walls Design and Construction gianniorlati 0 1,656 07-13-2015, 10:06 PM
Last Post: gianniorlati
  USDOT: Drilled Shafts: Construction Procedures and LRFD Design Methods isurya 4 4,128 11-22-2012, 03:46 PM
Last Post: miquan
  PERFORMANCE OF GEOSYNTHETIC-REINFORCED WALLS SUPPORTING THE FOUNDERS/MEADOWS BRIDGE A mahyarov 0 1,497 11-12-2012, 09:05 PM
Last Post: mahyarov
  USDOT: Dynamic Compaction ir_71 3 2,807 10-28-2012, 06:23 AM
Last Post: mahyarov
  Assessing the Long-Term Performance of Mechanically Stabilized Earth Walls mahyarov 0 1,612 10-24-2012, 01:27 PM
Last Post: mahyarov
