Civil Engineering Association eBooks Codes, Manual & Handbook British Standards (BS) BS 7121 - Code of Practice for Safe use of Cranes
05-10-2011, 05:20 AM (This post was last modified: 05-10-2011, 02:18 PM by usman.)
BS 7121-1:2006
General
Author: Committee MHE/3/11 | Size: 0.74 MB | Format: PDF | Publisher: BSI | Year: 2006 | pages: 78 | ISBN: 0580478254
[Image: 99717581175200172169.jpg]
This part of BS 7121 gives recommendations for the safe use of cranes. Subjects covered include safe systems of work, management, planning, selection, erection and dismantling, inspection, testing, examination, operation and maintenance of cranes and the planning and management of lifting operations.
[-] The following 19 users Like ir_71's post:19 users Like ir_71's post
  â€¢ rohailiyaz, 3fan, blaze, jcbv, almadar12, babakfeizy, ebaturalp, Dell_Brett, seriousboy, kowheng, toa011, knrsa, Umer.Aleem, DamaD, oanm2000, zrilek, sivlad, harika, Nilupa
05-10-2011, 05:27 AM (This post was last modified: 05-10-2011, 02:19 PM by usman.)
BS 7121-2:2003
Inspection, Testing and Examination
Author: Committee MHE/3/11 | Size: 3.4 MB | Format: PDF | Publisher: BSI | Year: 2003 | pages: 68 | ISBN: 0580413713
[Image: 87920810526065234370.jpg]
This part of BS 7121 gives recommendations for the pre-use checks, in-service inspection, thorough examination and testing of cranes, including associated equipment, and the means by which tests are to be carried out.
Although this part is not applicable to the testing of new cranes, it does give guidance on safety matters to be observed during these tests within the UK.
  â€¢ blaze, almadar12, babakfeizy, ebaturalp, Dell_Brett, seriousboy, kowheng, toa011, knrsa, Umer.Aleem, DamaD, oanm2000, zrilek, sivlad
05-10-2011, 05:36 AM (This post was last modified: 05-10-2011, 02:19 PM by usman.)
BS 7121-3:2000
Mobile Cranes
Author: Committee MHE/3/11 | Size: 0.39 MB | Format: PDF | Publisher: BSI | Year: 2000 | pages: 40 | ISBN: 058033158X
[Image: 65938251917681476647.jpg]
This part of BS 7121 provides recommendations for the safe use of mobile cranes and should be used in conjunction with BS 7121-2, which gives general guidance on inspection, testing and examination of all types of cranes.
Mobile cranes are manufactured in many different forms. Mobility is either by means of road wheels or crawler tracks. Rail-mounted cranes are not covered by this part of BS 7121. Cranes may be fully mobile and able to travel with rated capacity loads suspended (pick and carry), or may be semi-mobile and not permitted to travel with suspended loads.
Semi-mobile cranes include wheeled and crawler-mounted cranes, fitted with stabilizers or
outriggers; and cranes that, due to size and weight, are taken to the work site in parts and assembled at the site. Cranes that are assembled on site to work from a fixed base with outriggers are also covered by this part of BS 7121. Because of their mobility, the cranes covered by this part of BS 7121 can be used for a wide variety of lifting operations in numerous locations. BS 7121-1 provides general advice on planning, management, selection of equipment and personnel, etc., for safe lifting with all types of cranes. This part of BS 7121 provides specific guidance on safety when dealing with the hazards caused by mobility and the diversity of locations for mobile crane lifting operations.
  â€¢ rohailiyaz, almadar12, babakfeizy, ebaturalp, Dell_Brett, seriousboy, kowheng, toa011, knrsa, DamaD, oanm2000, zrilek, sivlad
05-10-2011, 05:45 AM (This post was last modified: 05-10-2011, 02:20 PM by usman.)
BS 7121-4:1997
Lorry Loaders
Author: Committee MHE/3/11 | Size: 0.3 MB | Format: PDF | Publisher: BSI | Year: 1997 | pages: 26 | ISBN: 0580271218
[Image: 00222022201583058966.jpg]
This Part of BS 7121 gives recommendations for the safe use of lorry loaders. It should be read in conjunction with BS 7121 : Part 1 : 1989 and BS 7121 : Part 2 : 1991.
Subjects covered include management, procedures and precautions, testing, inspection, maintenance and examination.
  â€¢ babakfeizy, blaze, ebaturalp, Dell_Brett, seriousboy, kowheng, toa011, knrsa, Umer.Aleem, DamaD, oanm2000, sivlad
05-10-2011, 05:56 AM (This post was last modified: 05-10-2011, 02:22 PM by usman.)
BS 7121-5:2006
Tower Cranes
Author: Committee MHE/3/11 | Size: 1.2 MB | Format: PDF | Publisher: BSI | Year: 2006 | pages: 110 | ISBN: 0580481298
[Image: 53307143566549187034.jpg]
This part of BS 7121 gives recommendations for the safe installation and use of tower cranes, including self-erecting tower cranes. Subjects covered include selection of tower cranes, planning the installation (including site specific design work, e.g. base and ties), erection, extension (including climbing), thorough examination (including testing), maintenance, operation, and dismantling, as well as safety measures to be taken during the execution of all the above functions. It also covers the appropriate selection and training of
personnel involved in the safe installation and use of tower cranes.
NOTE Self-erecting tower cranes have been addressed briefly in this document. It is envisaged that a full treatment will be given in a future publication.
  â€¢ rohailiyaz, almadar12, blaze, ebaturalp, 3fan, Dell_Brett, avscorreia, meditation, meditation, seriousboy, kowheng, Jackass, toa011, knrsa, Umer.Aleem, DamaD, oanm2000, zrilek, sivlad
05-11-2011, 04:16 AM
BS 7121-11:1998 Code of practice for safe use of cranes. Offshore cranes
Author: Committee MHE/3/11 | Size: 0.6 MB | Format: PDF | Publisher: BSI | Year: 1998 | pages: 24 | ISBN: 0580295036
[Image: 43031170267691067541.jpg]
BS 7121-11:1998 gives recommendations for safe use of offshore cranes (including supporting structures affixed to offshore installations), primarily operating in an open sea environment. The following activities are not covered in this part of BS 7121:
- slinging practices;
- crane erection practices;
- use of all non-slewing cranes used offshore [e.g. blowout preventer (BOP) cranes, overhead travelling cranes, gantry cranes, hoists and davits].
  â€¢ Jackass, Dell_Brett, kowheng, seriousboy, toa011, knrsa, Umer.Aleem, DamaD, 3fan, oanm2000, zrilek, sivlad
05-12-2011, 05:02 AM
BS 7121-12:1999 Safe use of cranes - Part 12: Recovery vehicles and equipment - Code of practice
Author: Subcommittee MHE/3/14 | Size: 0.18 MB | Format: PDF | Publisher: BSI | Year: 1999 | pages: 14 | ISBN: 0580282597
[Image: 05930388202242255970.jpg]
This British Standard Code of Practice gives recommendations for the care and safe use of recovery vehicles and equipment, to ensure the safety of technicians and other persons in the vicinity of recovery operations.
  â€¢ kowheng, Jackass, knrsa, 3fan, seriousboy, toa011, DamaD, oanm2000, zrilek, sivlad, Dell_Brett
05-13-2011, 05:33 AM
BS 7121-13:2009 Code of practice for safe use of cranes – Part 13: Hydraulic gantry lifting systems
Author: Subcommittee MHE/3/11 | Size: 1.5 MB | Format: PDF | Publisher: BSI | Year: 2009 | pages: 70 | ISBN: 9780580684104
[Image: 93478249171105952953.jpg]
This part of BS 7121 gives recommendations for the safe use of hydraulic gantry lifting systems (HGLS). Subjects covered include safe systems of work, management, planning, selection, erection and dismantling, inspection, testing, examination, training, operation and maintenance.
NOTE 1 This part of BS 7121 has been developed along the lines of BS 7121-1 with significant modifications to incorporate HGLS-specific aspects. The modifications include some information contained in the US Specialized Carriers and Rigging Association (SC&RA) document, Recommended Practices for Hydraulic Jacking Systems [6]. This part of BS 7121 is intended to be used in conjunction with BS 7121-2, which provides general guidance on the inspection, testing and examination of all types of cranes.
NOTE 2 Annex A and Annex B give detailed recommendations on the training of HGLS personnel. Annex C provides background information on the BS 7121 series.
  â€¢ 3fan, kowheng, Jackass, seriousboy, oanm2000, toa011, knrsa, zrilek, sivlad, Dell_Brett
 glynj
Wales
User ID: 48707
Likes: 0 in 0 posts
Given Likes: 3
08-05-2012, 04:10 PM
The links to these posts seem to be out of date, I would be very grateful if somebody could update the links
Thanks,
GlynHappy
  â€¢
#10
10-12-2012, 04:21 AM
New links - all in one:
  â€¢ Dell_Brett, slowet, Jackass, lisine, peixoto, S3dbw, chenamoy, nickycruz
Pages (2): 1 2 Next »
  BS 8006-1: Code of practice for Strengthened/reinforced soils and other fills ir_71 8 8,229 05-29-2024, 12:10 PM
  BS 5930:2015+A1:2020 - Code of practice for ground investigations concreteok 0 3,921 07-25-2023, 10:35 AM
Last Post: concreteok
  BS 6349-1: Maritime Structures: Code of Practice for General Criteria Gabemzaman 9 10,205 06-07-2023, 05:10 AM
Last Post: ersin
  BS 8476: Code of practice for the safe use of concrete pumps ir_71 2 3,428 02-12-2022, 08:00 AM
  BS EN 13001 Cranes General Design mybest 4 4,956 09-03-2021, 08:20 AM
Last Post: malee
  BS 5262:1991 Code of practice for External renderings ir_71 3 3,710 07-31-2021, 08:00 PM
Last Post: monter
  BS 8102:1990 Code of practice for Protection of structures against water from the gro ir_71 6 5,281 07-31-2021, 07:54 PM
Last Post: monter
