Civil Engineering Association Various Free Discussion [PROBLEM] How to Protect a CAD drawing?
[Problem] How to Protect a CAD drawing?
 jupe01
User ID: 6535
Threads: 4
Likes: 116 in 31 posts
Given Likes: 68
05-07-2011, 01:43 PM
Hi friends,
I almost sure that you're all ever getting problem, that you need your CAD Drawing should not be copied or distributed by other who you send the file.
So my problem is how can I protect a drawing I am sending to someone, with something like stamps, that hidden in model, but always seen if they print the file?
This case, remember me about stamp: "Produced by an Autodesk Educational Product".
But..., in my mind, can we protect our CAD Drawing with stamps, that we can create by ourself like: "created by jupe01 Happy"
if VBA or AutoLisp is a solution, how it make us sure that the code always load when the file open. Isn't it any option "don't load or disable"?
thanks before for anyone who can give me solution,
peace,
jupe.
 ynopum
Burundi
User ID: 2733
Threads: 24
Likes: 2,399 in 365 posts
Given Likes: 155
05-07-2011, 02:13 PM
Would you describe exactly what is your 'fear', as I can't understand properly.
You don't want something to be stolen from your DWG, or you don't want somebody to print the drawing without your permission?..or something else.
There is a password protection option, so only the person who knows the password can open the DWG.
Another option is to use a custom application that "unhides" some objects from the drawing, and if the 'opponent' doesn't have this application, he can't see those hidden objects.
Third idea is to define custom object types, associated with different application name (not ACAD), so the Autocad itself will show those objects, but they will not be editable.
[-] The following 1 user Likes ynopum's post:1 user Likes ynopum's post
  • jupe01
 Dell_Brett
Admin Deputy
Admin Deputy
Brazil
User ID: 4
Threads: 246
Likes: 19,035 in 2,188 posts
Given Likes: 42492
05-07-2011, 02:17 PM (This post was last modified: 05-07-2011, 02:18 PM by Dell_Brett.)
Dear Jupe01,
There´s no effective way to protect a AutoCAD drawing (DWG file format drawing).
The Autodesk Stamp: "Produced by Educational...." is easily removable, consequently, any similar solution will be removable too.
All other alternatives: DWF file format, send as PDF file format, as GIF image, etc, are partially protection! All can be converted to DWG again (not pure, but effective for lines)
There´s a LISP routine (quite old) reasonably efficient to lock a drawing, named LOCKUP.lsp (see link below) that you can experiment if are useful for you. Don´t forget to make a backup of your drawing before using this routine! It´s irreversible for non expert programmers or CAD users.
Dell Brett
  • rusty, Jackass, oanm2000, jupe01, Ultra Zone, wesam_19701970
 jupe01
User ID: 6535
Threads: 4
Given Likes: 68
05-08-2011, 11:09 AM
@ynopum
Thanks for the reply. Actually, I don't mind someone opens, edits or prints the drawing, but I would like he/she has a stamp "created by jupe' on the print out, while he/she could not see the stamp on the model/lay out when he/she opens/edits the drawing. So at least he/she needs to do something (e.g. erase the stamp) on his/her model in the file I sent, while he/she actually cannot see the stamp on the model. I agree with your second and third option. However, which application is more suitable in my case? What should I do in order to meet the second and third options?
Thank you.
@Dell Brett
Thank you for replying.
I agree with you that using method such as Autodesk Stamp: "Produced by Educational...." is easily removable, consequently, any similar solution will be removable. In my case, for beginner receivers, they rarely know the way to remove it, although I know how to remove it myself. the problem is I cannot make it although I know the way to remove it. Could you help me how to make it?
I agree sending it in DWF file format, PDF file format, and GIF image, etc, but there is a disavantage in sending the file in those formats, that i don't send them the original file (DWG file). My customer wants the file in the DWG format.
Thank you for the link LISP routine (LOCKUP.lsp).
 Dell_Brett
Admin Deputy
Admin Deputy
Brazil
User ID: 4
Threads: 246
Given Likes: 42492
05-08-2011, 03:04 PM
Removing the "Produced by an Autodesk Educational Product" advert
Follow this steps:
1- Save the drawing as DXF file format: Use DXFOUT (in command line) or: SAVEAS --> DXF. Use another name;
2- Close the DWG file;
3- Open the DXF file;
4- Save as DWG.
That´s all! No more Autodesk advert!
Dell Brett
[-] The following 1 user Likes Dell_Brett's post:1 user Likes Dell_Brett's post
  • pssst
 ynopum
Burundi
User ID: 2733
Threads: 24
Given Likes: 155
05-08-2011, 04:11 PM
Jupe, you need quite specific thing. I am sure there was no such wish from anybody else yet.
There is a command "plotstamp" in the newer version of Autocad.
Such watermark (or plotstamp) you wish should be not an Autocad object (i.e. RTEXT) or anything that has coordinates, because the opponent can print another part of the drawing, where your hidden object is not in the plot area. It seems you need exactly this "educational stamp" effect, but with your personal contents. I can't say that I can even understand how autodesk did such 'marking' of the file. Could somebody provide here such "educational' drawing?
_____________
"damaging" and hiding objects in files is much more easier that your "watermark stamp" wish. You can use LISP (or ARX) applications to bring back damaged drawings to normal state, but as you said: such watermark needs an application to be present on opponents computer to print.
  • jupe01
 ottavio
Poland
User ID: 13096
Threads: 3
Likes: 58 in 12 posts
Given Likes: 3
05-08-2011, 08:44 PM (This post was last modified: 05-08-2011, 09:03 PM by Dell_Brett.)
Check this out:
[-] The following 1 user Likes ottavio's post:1 user Likes ottavio's post
  • jupe01
  Protect your eyes from computer. vati 7 11,910 10-23-2010, 07:22 AM
Last Post: chigozie
  Protect your system without using AV software PrinceOfHeartz 8 11,663 01-18-2010, 10:46 PM
Last Post: PrinceOfHeartz
