Civil Engineering Association eBooks Codes, Manual & Handbook API RP 14E: RP for Design and Installation of Offshore Production Platform Piping Sys
05-03-2011, 07:00 PM (This post was last modified: 12-29-2011, 11:51 PM by usman.)
API - Recommended Practice for Design and Installation of Offshore Production Platform Piping Systems
Author: API | Size: 4 MB | Format: PDF | Publisher: API | Year: 2000 | pages: 62
[Image: 01342691528760476576.jpg]
Scope. This document recommends minimum requirements and guidelines for the design and installation of new piping systems on production platforms located offshore. The maximum design pressure within the scope of this document is 10,000 psig and the temperature range is -20’F to 650’F. For applications outside these pressures and temperatures. special consideration should be given to material properties (ductility, carbon migration, etc.). The recommended practices presented are based on years of ex erience in developing oil and gas leases. Practically alrof the offshore experience has been in hydrocarbon service free of hydrogen sulfide. However, recommendations based on extensive experience onshore are included for some as cts of hydrocarbon service containing hydrogen suEde.
a This document contains both general and specific information on surface facility piping systems not specified in. API Specification 6A. Sections 2, 3 and 4 contain eneral information concerning the design and appfication of pipe, valves, and fittings for typical processes. Sections 6 and 7 contain general information concerning installation, quality
control, and items related to piping systf?ms, e.g.. insulation, etc. for typical processes. Section 5 contains specific information concerning the design of articular piping systems including any deviations sections.
b. Carbon steel materials are suitable for the majority of the piping systems on productipn platforms. At least one carbon steel material recommendation is included for most applications. Other materials that may be suitable for platform piping systems have not been included because they are not generally used. The following should be considered when selecting materials other than those detailed in this RP.
(i) Type of service.
(2) Compatibility with other materials.
(3) Ductility.
(4) Need for special welding procedures.
( 5 ) Need for special inspection, tests, or quality control.
(6) Possible misapplication in the field.
(7) Corrosionlerosion caused by internal fluids andlor marine environments.
  β€’ 3fan, seriousboy, Dell_Brett, malc, strengr, melkat, oanm2000, kowheng, rendel_Β©, bigone, sivlad
  Steel Forgings: Design, Production, Selection, Testing and Application, Manual ibg0203 1 2,762 11-02-2016, 11:30 PM
Last Post: gulilero
  PTI: Recommendations for stay cable design, testing and installation lamkin 4 5,269 03-17-2013, 10:38 PM
  API RP 686-2009: RP for Machinery Installation and Installation Design yucapareja 0 1,980 09-12-2010, 03:36 PM
Last Post: yucapareja
  Oil and gas production handbook. An introduction to oil and gas production by HΓ₯var rendel_Β© 0 2,069 11-15-2009, 02:33 AM
Last Post: rendel_Β©
