Civil Engineering Association eBooks Codes, Manual & Handbook AS 1012.18-1996 Methods of testing concrete - Determination of setting time of fres
04-01-2011, 05:32 AM
AS 1012.18-1996 Methods of testing concrete - Determination of setting time of fresh concrete, mortar and grout by penetration resistance
Author: Committee BD-042 | Size: 3.8 MB | Format: PDF | Publisher: Standards Australia | Year: 1996 | pages: 7 | ISBN: 073370638X
[Image: 50865142577783618431.jpg]
This Standard describes the procedures for determining the initial and final setting times of mortar sieved from fresh concrete mix, the slump of which is greater than zero, using penetration resistance needles. This method is also applicable to fresh mortar and grout.
NOTES:
1 As the hardening of concrete is a gradual process, any definition of setting time must necessarily be arbitrary.
2 This method is primarily intended to be used as a means for comparing setting times under the same conditions in the laboratory.
3 This method may be used to determine the setting characteristics at a standard temperature (23 2C), at some other specified temperature or alternatively to determine the setting time-temperature relationship.
4 This method may be used to estimate setting times of specific concretes, mortars or grouts in the field.
[-] The following 2 users Like ir_71's post:2 users Like ir_71's post
  â€¢ kowheng, sivlad
  AS 1012.13-1992 Methods of testing concrete - Determination of the drying shrinkage ir_71 1 3,385 10-01-2018, 11:02 AM
  AS 1012.2-1994 Methods of testing concrete - Preparation of concrete mixes in the la ir_71 1 2,619 06-03-2014, 04:09 AM
  PD CEN/TR 196-4:2007 Methods of testing cement mybest 0 1,918 12-03-2011, 06:46 AM
Last Post: mybest
  AS 1012.21-1999 Methods of testing concrete - Determination of water absorption and ir_71 0 2,167 04-01-2011, 05:56 AM
  AS 1012.20-1992 Methods of testing concrete - Determination of chloride and sulfate ir_71 0 2,030 04-01-2011, 05:49 AM
  AS 1012.19-2000 Methods of testing concrete - Accelerated curing of concrete comp ir_71 0 1,931 04-01-2011, 05:39 AM
  AS 1012.17-1997 Methods of testing concrete - Determination of the static chord mod ir_71 0 1,942 04-01-2011, 05:25 AM
