Civil Engineering Association eBooks Structural Dynamics and Earthquake Engineering Mechanical Vibrations and Shocks, volume 1-5: Christian Lalanne
 tmstru
User ID: 25703
Threads: 6
Likes: 77 in 12 posts
Given Likes: 104
03-15-2011, 03:18 PM (This post was last modified: 01-03-2012, 10:13 PM by usman.)
Mechanical Vibrations and Shocks: Sinusoidal Vibrations (Volume 1)
[Image: 37051023173192703337.jpg]
Kogan Page Science | February 14, 2002 | ISBN-10: 1903996031 | 320 pages | PDF | 4.28 MB
This volume is from the "Mechanical Vibration and Shock" five-volume study. The relative and absolute response of a mechanical system to one degree with freedom is considered for arbitrary excitation, and its transfer function defined in various forms. The characteristics of sinusoidal vibration are placed in the context both of the real world and of laboratory tests, and transient and steady state response of the single-degree-of-freedom system. First viscous damping and then non-linear damping is considered. The various types of sine-sweep and their properties are described and, for the one-degree-of-freedom system, the consequences of an inappropriate choice of sweep rate are considered. From the latter, rules governing the choice of suitable sweep rates are developed.
Moderator note: thread moved from Bad Posts, redesinged using CivilEA Post Generator, info added
[-] The following 7 users Like tmstru's post:7 users Like tmstru's post
  • seriousboy, blaze, zrilek, madkestas, foxxx2010, gulilero, rkce
 tmstru
User ID: 25703
Threads: 6
Given Likes: 104
03-15-2011, 03:21 PM (This post was last modified: 03-25-2011, 01:24 PM by Grunf.)
Mechanical Vibrations and Shocks: Volume 1-5
By: Christian Lalanne (Author)
Hardcover: 1580 pages
Publisher: Kogan Page Science (April 10, 2002)
ISBN-10: 1903996120
ISBN-13: 9781903996126
Product Description:
This five-volume set lays down the theoretical basis for the specification and testing of international standards related to product design. Manufactured product has to be designed to withstand the effects of the environmental factors (temperature, humidity) and also the effects of externally imposed mechanical shocks and vibrations, which might result in fatigue and other damage. This has given rise to the concept of the tailorization of product, leading to the tailorization of tests. Tailorization implies not only an understanding of the effects of the environment, but also presupposes proper understanding of the mechanical systems subjected to mechanical loads, and knowledge of the most frequent failure modes. This is implemented by the use of a simple theoretical model, enabling the effects of shocks and vibrations to be assessed, and the drafting of specifications, pre-sizing calculations and the establishment of rules for analysis and definitions of tests to be developed. Throughout, the theoretical treatments are placed in the context of the real environment and of laboratory tests - essential for the development of standards. The series culminates, in Volume V, in the development of specifications.
About the Author:
Christian Lallane is an expert specialist at the French Atomic Energy Authority, who has specialised in the study of vibration and shock for more than thirty years. The author of numerous publications in this field, he has been associated with the new methods of drafting testing specifications and associated informatic tools.
(converted from HTM)
  • seriousboy, blaze, zrilek, spat, madkestas, kowheng, mgdario
 tmstru
User ID: 25703
Threads: 6
Given Likes: 104
03-15-2011, 03:21 PM (This post was last modified: 03-25-2011, 01:19 PM by Grunf.)
Mechanical Vibrations and Shocks: Mechanical Shock (Volume 2)
[Image: 54977557240756593990.jpg]
Hardcover: 320 pages
Publisher: Kogan Page Science (February 16, 2002)
ISBN-10: 190399604X
ISBN-13: 9781903996041
This volume considers the shock response spectrum, its various definitions, its properties and the assumptions involved in its calculation. In developing the practical application of these concepts, the shock shapes most often used with test facilities are presented, together with their characteristics and indications of how to establish test configurations comparable with those of the real, measured environment. There follows a demonstration of how to meet these specifications using standard laboratory equipment - shock machines, electrodynamic exciters driven by a time signal or a response spectrum - with discussion of the limitations, advantages and disadvantages of each method.
[-] The following 1 user Likes tmstru's post:1 user Likes tmstru's post
  • spat
 3fan
Romania
User ID: 29614
Threads: 161
Likes: 7,359 in 1,207 posts
Given Likes: 5546
09-20-2011, 12:12 PM
[-] The following 10 users Like 3fan's post:10 users Like 3fan's post
  • Dell_Brett, kowheng, mgdario, zrilek, gulilero, rkce, ting tsai huang, yantonegr, draluka, pingfan2
  Mechanical Vibrations: Theory and Application to Structural Dynamics; Third Edition amindoxiti 3 3,075 04-15-2019, 06:54 AM
  Applied Structural and Mechanical Vibrations Grunf 5 4,466 11-20-2016, 09:57 AM
  Mechanical Vibrations, by Singiresu S. Rao Grunf 11 8,411 11-14-2016, 05:57 AM
  Mechanical Systems: A Unified Approach to Vibrations and Controls ssobhan 0 1,609 08-08-2015, 07:00 AM
Last Post: ssobhan
  Fundamentals of Mechanical Vibrations tibas 6 4,877 04-27-2015, 08:07 AM
Last Post: PinkPant
  Random Vibrations: Analysis of Structural and Mechanical Systems Grunf 5 3,985 12-17-2014, 12:45 PM
  Vibrations of mechanical systems with regular structure Grunf 4 3,502 08-07-2014, 09:20 PM
Last Post: odiclas
