Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Archive [REQUEST] A simplified method for flexural capacity assessment of circular RC cross-sections
[Request] A simplified method for flexural capacity assessment of circular RC cross-sections
 marion33
Poland
User ID: 15632
Threads: 28
Likes: 501 in 66 posts
Given Likes: 885
03-16-2011, 07:45 AM (This post was last modified: 03-16-2011, 09:16 AM by Grunf.)
A simplified method for flexural capacity assessment of circular RC cross-sections - from ScienceDirect
References and further reading may be available for this article. To view references and further reading you must purchase this article.
Edoardo Cosenzaa, Carmine Galassoa, Corresponding Author Contact Information, E-mail The Corresponding Author and Giuseppe Maddalonib
a Dipartimento di Ingegneria Strutturale, UniversitΓ  degli Studi di Napoli Federico II, via Claudio 21, 80125, Naples, Italy
b Dipartimento per le Tecnologie, UniversitΓ  degli Studi di Napoli Parthenope, Centro Direzionale isola C4, 80143, Naples, Italy
Received 19 August 2010;
revised 17 November 2010;
accepted 1 December 2010.
Available online 5 January 2011.
Abstract
A simplified method for the assessment of bending moment resistance for reinforced concrete (RC) members with circular cross-sections is presented. In the proposed method longitudinal rebars arrangement is replaced with a thin steel ring equivalent to the steel total area; moreover, according to modern codes, simplified stress–strain relationships for concrete and reinforcing steel are used.
The performed analyses demonstrate that the value of flexural capacity determined by the proposed approach, is very close to the results obtained by applying rigorous methods based on analytical and numerical algorithms.
The study also proves that in members subjected to bending moment without axial load, the flexural strength depends on the geometry of the section (i.e. radius and concrete cover) and on mechanical ratio of steel reinforcement by a very simple formula.
please share this document if you have it
  β€’
 Songoku
Azores
User ID: 2786
Threads: 16
Likes: 76 in 19 posts
Given Likes: 182
03-16-2011, 12:57 PM (This post was last modified: 03-16-2011, 01:31 PM by kowheng.)
Hi check out this link, the paper as a sligthly different name but is from the same authors
and i think it as the same content.
Moderator Notes:
You were warned for posting transparent link. Before making further posts and to avoid new warninig points, please read those:
and especially this:
  β€’
 mariusz
Member
User ID: 6590
Threads: 19
Likes: 174 in 23 posts
Given Likes: 27
03-16-2011, 06:53 PM
Dear Songoku,
Your link for artickle from 4shared is dead
  β€’
 Songoku
Azores
User ID: 2786
Threads: 16
Given Likes: 182
03-16-2011, 10:02 PM
Here is the link to the file.
[-] The following 5 users Like Songoku's post:5 users Like Songoku's post
  β€’ Dell_Brett, malc, Grunf, mariusz, marion33
  [REQUEST] Scribd: DuraGal - Design Capacity Tables for Steel Hollow Sections miquan 1 1,857 11-01-2014, 11:06 AM
Last Post: ssobhan
  [REQUEST] A Reliable Method to determine Friction Capacity of Piles Driven into Clays tomcat007 0 1,495 09-05-2014, 11:14 AM
Last Post: tomcat007
  [REQUEST] A simplified method of estimating construction pore pressures in earth dams rilxous 0 1,377 07-30-2014, 03:22 AM
Last Post: rilxous
  [REQUEST] Suspension Bridge Analysis By The Exact Method Simplified By Knowledge Of Its Relatio netsonicyxf 0 1,514 04-13-2014, 01:58 PM
Last Post: netsonicyxf
  [REQUEST] A Simplified MCFT for Shear Capacity Scaling of R/C Beams AlmostThere 1 1,874 11-06-2012, 01:09 PM
  [REQUEST] A simplified distortional buckling model for doubly symmetrical I-sections Nameno 0 1,610 01-26-2011, 09:44 AM
Last Post: Nameno
  [REQUEST] Journal : "Capacity Spectrum Method Based On Inelastic Spectra" budis 4 3,140 12-18-2010, 12:45 PM
Last Post: Grunf
