Civil Engineering Association eBooks Journals, Papers and Presentations Cause of Damage and Failures in Silo Structures
 rigid_joint
Senior Member
Jamaica
User ID: 6110
Threads: 13
Likes: 333 in 122 posts
Given Likes: 244
03-16-2011, 12:19 PM (This post was last modified: 10-10-2011, 08:59 PM by Grunf.)
Author: Adem Dogangun ; Zeki Karaca ; Ahmet Durmus ; and Halil Sezen, M.ASCE | Size: 0.8 MB | Format: PDF | Publisher: JOURNAL OF PERFORMANCE OF CONSTRUCTED FACILITIES Β© ASCE | Year: 2009 | pages: 7
[Image: 86245972754637492378.jpg]
Abstract: Silos are special structures subjected to many different unconventional loading conditions, which result in unusual failure
modes. Failure of a silo can be devastating as it can result in loss of the container, contamination of the material it contains, loss of
material, cleanup, replacement costs, environmental damage, and possible injury or loss of life. Silo damage and failures that occurred in
different regions of the world are presented in the paper using illustrative photos. Also provided are a review and discussion of the
common or spectacular silo failures due to explosion and bursting, asymmetrical loads created during filling or discharging, large and
nonuniform soil pressure, corrosion of metal silos, deterioration of concrete silos due to silage acids, internal structural collapse, and
thermal ratcheting. Silo damage and failures from several earthquakes are also presented.
[-] The following 12 users Like rigid_joint's post:12 users Like rigid_joint's post
  β€’ blaze, henrycv, shaqee, malc, seriousboy, faros3000, isurya, zrilek, monter, Dell_Brett, hcardenas, ivanveliki
Threads: 307
10-10-2011, 08:56 PM
Direct link:
[-] The following 14 users Like Grunf's post:14 users Like Grunf's post
  β€’ jcbv, Jackass, blaze, Dell_Brett, lasalleguy, zrilek, cigutierrezg, tluc, slowet, kowheng, atram, chenamoy, harsono, dinu69in
  Detection and assessment of damage in 2D structures using measured modal response arshiakh 0 3,760 04-24-2013, 07:03 PM
Last Post: arshiakh
  STRUCTURAL DAMAGE ASSESSMENT OF BUILDING STRUCTURES USING DYNAMIC EXPERIMENTAL DATA asim99 0 4,334 12-31-2012, 02:00 AM
  Silo Problems SR71 1 4,404 03-16-2011, 12:20 PM
Last Post: rigid_joint
