Civil Engineering Association eBooks Codes, Manual & Handbook British Standards (BS) BS 7255:2001 Code of practice for Safe working on lifts
03-14-2011, 06:21 AM
Author: Subcommittee MHE/4/1 | Size: 1.35 MB | Format: PDF | Publisher: BSI | Year: 2002 | pages: 52 | ISBN: 0580332942
[Image: 66462578331114424662.jpg]
This British Standard gives recommendations for safe working practices (supported by training) for:
— owners of permanently installed lifts serving defined landing levels;
— persons having effective control of the premises where such lifts are installed;
— persons responsible for, and involved in, the design, installation, thorough examination, inspection, testing, service, maintenance, repair and dismantling of such lifts.
NOTE 1 Requirements for lifts and associated parts of lift installations are not included in this code of practice; these are given in other types of standard such as specifications and test methods. The recommendations in this British Standard relate to the safety of persons when gaining access to and from the work area on a lift installation, and whilst working there. They also relate to the safety of others present in the vicinity, whether they are working or not, who could be endangered by the actions of those working on lifts.
This British Standard is applicable to persons working on all types of lift. However, not every recommendation is applicable for all types of lift that are covered by British Standards either published or in preparation. For lifts that have been designed and installed in accordance with the Lifts Regulations 1997 [2], the recommendations in this standard that affect product design do not apply.
NOTE 2 Legal responsibilities for the safety of persons working on lifts are summarized in Annex A, together with titles of the relevant UK legislation.
  • kowheng, Dell_Brett, blaze, mecheil.edwar, toa011, melkat, zrilek, roaming79, usman, cordoba123, kmmh76, peixoto, asim99
Threads: 150
Given Likes: 28542
08-09-2019, 08:45 PM
Please,
Could someone update the link?
Thanks in advance
 Nita1391
User ID: 174964
Threads: 3
Likes: 465 in 38 posts
Given Likes: 700
08-09-2019, 10:11 PM (This post was last modified: 08-09-2019, 10:12 PM by Nita1391. Edit Reason: N/A )
<p>Hi</p><p>New Link</p><p>
👉 CLICK HERE 👈 </p><p><br></p><p>2012 Edition</p><p>
👉 CLICK HERE 👈 <br></p><p><br></p>
[-] The following 4 users Like Nita1391's post:4 users Like Nita1391's post
  • zrilek, PinkPant, vvvv, CAMSECT
  BS 8006-1: Code of practice for Strengthened/reinforced soils and other fills ir_71 8 8,427 05-29-2024, 12:10 PM
  BS 5930:2015+A1:2020 - Code of practice for ground investigations concreteok 0 3,998 07-25-2023, 10:35 AM
Last Post: concreteok
  BS 6349-1: Maritime Structures: Code of Practice for General Criteria Gabemzaman 9 10,461 06-07-2023, 05:10 AM
Last Post: ersin
  BS 8476: Code of practice for the safe use of concrete pumps ir_71 2 3,516 02-12-2022, 08:00 AM
  BS 5262:1991 Code of practice for External renderings ir_71 3 3,803 07-31-2021, 08:00 PM
Last Post: monter
  BS 8102:1990 Code of practice for Protection of structures against water from the gro ir_71 6 5,396 07-31-2021, 07:54 PM
Last Post: monter
  BS 8102:2009 - Code of practice for protection of below ground structures against wat Mohammad6299 1 2,626 02-17-2021, 11:20 AM
Last Post: temp1366
