Civil Engineering Association eBooks Journals, Papers and Presentations Durability Guidelines For The Design, Construction, Repair And Maintenance Of Parking
03-02-2011, 06:46 AM (This post was last modified: 04-08-2013, 04:30 PM by usman.)
DURABILITY GUIDELINES FOR THE DESIGN, CONSTRUCTION, REPAIR AND MAINTENANCE OF PARKING STRUCTURES
Size: 1.21 MB | Format: PDF | Year: 1993 | pages: 253
[Image: 07714971726555255094.jpg]
This project on Parking Structures Durability Guidelines was proposed by Technology Development and Demonstration and was funded by the Real Property Program and the Panel on Energy Research and Development (PERD). This research was conducted in collaboration with Halsall Associates Limited. The objective of this project was to develop specific guidelines for the design, construction, repair and maintenance of parking structures.
Every year, Public Works & Government Services Canada (PWGSC) spends vast sums of money on the repair and maintenance of parking structures. While it is generally accepted that a certain degree of garage maintenance is inevitable, the design and construction practices in past failed to provide adequate protection against the increasing amounts of chloride based de-icing chemicals which are being used in present in-service environments. The salts carried into garages by cars migrate through the concrete to the steel resulting in corrosion of the embedded steel components.
For the past five years, Technology, A&ES Services, Headquarters, in conjunction with the Institute for Research in Construction (IRC) at National Research Council Canada (NRC), have been monitoring the performance of several parking garage structures and evaluating various repair strategies in an attempt to develop techniques for effective rehabilitation and maintenance of indoor parking garages. Much of the knowledge gained from this multiyear research study was used in the development of these guidelines. This document will serve as a very useful tool for builders, operators and property managers. However, it must be emphasized that decisions in design, construction, repair and maintenance must be the responsibility of qualified professionals. If proper procedures are followed, the life of parking garages will be greatly enhanced.
  â€¢ kowheng, blaze, Dell_Brett, cigutierrezg, oanm2000, Quantumm, vvvv
Threads: 49
04-08-2013, 12:15 PM
all links dead; direct link here:
  â€¢ Jackass, vvvv, ruaumoko, malc, slowet
  Shotcrete Design Guidelines Design guidelines to avoid, minimise and improve the appe ir_71 2 8,825 05-10-2016, 10:15 PM
Last Post: gulilero
  SEISMIC DESIGN FACTORS FOR PRECAST CONCRETE SHEAR WALL PARKING GARAGES TAFATNEB 0 5,875 02-12-2015, 01:39 PM
  UFC 3-270-01 ASPHALT MAINTENANCE AND REPAIR ir_71 1 5,779 04-08-2013, 01:13 PM
  Bridge Member Repair Guidelines ir_71 1 6,549 04-08-2013, 12:18 PM
  Guidelines for the Design and Construction of Externally Bonded FRP Systems for Stren ir_71 2 6,799 04-08-2013, 12:12 PM
  NYDOT: Guidelines For Embankment Construction mybest 0 4,008 04-16-2012, 10:07 AM
Last Post: mybest
