Civil Engineering Association eBooks Codes, Manual & Handbook SETRA Technical Guides
 avge
Greenland
User ID: 27510
Threads: 10
Likes: 580 in 54 posts
Given Likes: 600
02-09-2011, 11:19 PM
Sétra is a Technical Department for Transport, Roads and Bridges Engineering and Road Safety of the french Ministry of Ecology, Sustainable Development, Transport and Housing.
As a center of excellence in infrastructure and transport engineering, Sétra has to produce and spread state of art knowledge and know how.
Sétra’s essential aim is to support national and local authorities in their policies to provide an effi cient and safe road network for people and goods, and to develop an integrated and sustainable European transportation system. In all the strategic fi elds dealing with road, bridges, multimodal and intermodal facilities, it provides expertise, methodologies, guidelines, as well as software and information systems.
So here are the direct links to the SETRA Technical Guides:
Civil engineering structures
Steel - Concrete composite bridges - Sustainable design guide
Pot bearings - Use on bridges, viaducts and similar structures
Laminated elastomeric bearings - Use on bridges, viaducts and similar structures
Memoar - Guide for construction on bridges
Prestressed concrete bridges built using the cantilever method
Watercourses and bridges
Timber Bridges
Eurocodes 3 and 4 - Application to steel-concrete composite road bridges
Road safety
Road safety inspections
Signing bends
Improving the safety of bends on major rural roads
Rural junction improvement and safety
Safety at level crossing - Case of proximity to a roundabout
Handling lateral obstacles on main roads in open country
Road safety stake analysis - Interurban environment
Landscape and road legibility
Environmental protection
Road noise prediction - 2-Noise propagation computation method including meteorolgical effects
Landscape and transport infrastructures
Facilities and measures for small fauna
Road pavements - Road water management
Treatment of soils with lime and/or hydraulic binders
The use of standards for hot mixes
Roadway water management
Road drainage
Valorization of local materials
Design and execution of earthworks
Hot remixing
Continuous hot mix production - The french expertise
Pavement roadmixing and recycling of bituminous pavement materials
Road operation and maintenance
Anticipation of winter road risks
Maintenance of green roadside ancillaries
Development of operation daybooks
Road design
The design of interurban intersections on major roads - At-grade intersections
ICTAAL - National instruction on technical design requirements for rural motorways
[-] The following 18 users Like avge's post:18 users Like avge's post
  • rezart, jf28, oanm2000, malc, usman, AG.NAYEL, kowheng, cace-01, essam2109, barukai, st77bel, Dell_Brett, zrilek, ir_71, dbsimon29, gulilero, slowet, uetian19
  Setra - Cable Stays, Recommendations of French interministerial commission on Prestre epee 3 5,547 02-15-2016, 12:06 AM
Last Post: RyanRS
  SETRA : Loading tests on road bridges and footbridges avge 0 2,716 02-03-2011, 09:00 PM
Last Post: avge
  Sétra – Assessment of vibration behaviour of Footbridge under pedestrian loading epee 0 2,398 01-13-2010, 12:11 PM
Last Post: epee
