Civil Engineering Association eBooks Codes, Manual & Handbook British Standards (BS) PD 8010-2:2004 Code of practice for pipelines - Part 2: Subsea pipelines
01-15-2011, 06:54 PM
Author: Technical Committee PSE/17 | Size: 2.49 MB | Format: PDF | Publisher: BSI | Year: 2004 | pages: 142 | ISBN: 0580439526
[Image: 97810500806264987195.jpg]
This part of PD 8010 gives recommendations for and guidance on the design, use of materials, construction,
installation, testing, commissioning and abandonment of carbon steel subsea pipelines in offshore,
nearshore and landfall environments. Guidance on the use of flexible composite pipelines is also given.
It is not intended to replace or duplicate hydraulic, mechanical or structural design manuals.
This part of PD 8010 is applicable to subsea pipelines intended for the conveyance of hydrocarbon liquids,
hydrocarbon gases and other gases, liquids and gases in two-phase flow, fluid-based slurries and water.
NOTE Although primarily concerned with subsea pipelines associated with the oil and gas industry, PD 8010-2 is likely to have
application to a wider range of offshore activities.
The extent of pipeline systems covered by this part of PD 8010 is shown in Figure 1.
This part of PD 8010 does not give recommendations for pipelines on land, which are covered in PD 8010-1.
It does not cover sea outfalls (see BS EN 752-4) or fluid umbilicals (see BS 5173).
  â€¢ faros3000, toa011, usman, Dell_Brett, kowheng, zrilek, roaming79, k1k0k0, BNBranko, tamboon, duazo2009, peixoto
10-07-2012, 04:51 AM
New links:
  â€¢ david-smith, malc, Dell_Brett, Jackass, ssobhan, zrilek
  BS 8006-1: Code of practice for Strengthened/reinforced soils and other fills ir_71 8 8,427 05-29-2024, 12:10 PM
  BS 5930:2015+A1:2020 - Code of practice for ground investigations concreteok 0 3,998 07-25-2023, 10:35 AM
Last Post: concreteok
  BS 6349-1: Maritime Structures: Code of Practice for General Criteria Gabemzaman 9 10,462 06-07-2023, 05:10 AM
Last Post: ersin
  BS 8476: Code of practice for the safe use of concrete pumps ir_71 2 3,516 02-12-2022, 08:00 AM
  BS 5262:1991 Code of practice for External renderings ir_71 3 3,806 07-31-2021, 08:00 PM
Last Post: monter
  BS 8102:1990 Code of practice for Protection of structures against water from the gro ir_71 6 5,399 07-31-2021, 07:54 PM
Last Post: monter
  BS 8102:2009 - Code of practice for protection of below ground structures against wat Mohammad6299 1 2,626 02-17-2021, 11:20 AM
Last Post: temp1366
