Civil Engineering Association eBooks Structural Books Steel Steel Members Design
 mowafi3m
Egypt
User ID: 1236
Threads: 385
Likes: 9,324 in 678 posts
Given Likes: 1667
01-14-2011, 10:26 PM (This post was last modified: 01-15-2011, 12:58 PM by oanm2000.)
Author: Prof. Dr. A. Varma | Size: 6.24 MB | Format: PDF | Publisher: unknown | Year: 2003 | pages: 195 | ISBN: unknown
[Image: 51534913748702491958.jpg]
GENERAL INTRODUCTION
Structural design is a systematic and iterative process that involves:
1) Identification of intended use and occupancy of a structure – by owner
2) Development of architectural plans and layout – by architect
3) Identification of structural framework – by engineer
4) Estimation of structural loads depending on use and occupancy
5) Analysis of the structure to determine member and connection design forces
6) Design of structural members and connections
7) Verification of design
8) Fabrication & Erection – by steel fabricator and contractor
9) Inspection and Approval – by state building official
Ideally, the owner and the architect, the architect and the engineer, and the engineer and the
fabricator/contractor will collaborate and interact on a regular basis to conceive, develop, design,
and build the structure in an efficient manner. The primary responsibilities of all these players
are as follows:
• Owner - primary responsibility is deciding the use and occupancy, and approving the
architectural plans of the building.
• Architect - primary responsibility is ensuring that the architectural plan of the building
interior is appropriate for the intended use and the overall building is aesthetically pleasing.
• Engineer – primary responsibility is ensuring the safety and serviceability of the structure,
i.e., designing the building to carry the loads safely and ___________.
• Fabricator – primary responsibility is ensuring that the designed members and connections
are fabricated economically in the shop or field as required.
1
CE 405: Design of Steel Structures – Prof. Dr. A. Varma
• Contractor/Erector - primary responsibility is ensuring that the members and connections are
economically assembled in the field to build the structure.
• State Building Official – primary responsibility is ensuring that the built structure satisfies
the appropriate building codes accepted by the Govt.GENERAL INTRODUCTION
are as follows:
[-] The following 49 users Like mowafi3m's post:49 users Like mowafi3m's post
  • orambo, ravisbassi, yucapareja, lednar_ved, jcoronellr, usman, mrco1124, strengr, deadlord, jferrer, dinu69in, rkce, techno, vardan, jcbv, Dell_Brett, oanm2000, mastermind, Milkshake, cordoba123, zrilek, Administrator , zainseiya, cesar3226, bigone, goober, hcardenas, Nilupa, kowheng, malc, araza023, knrsa, blaze, vvvv, warbeast, kristoffer_89, TAFATNEB, isurya, DamaD, Adam Smith, yutt, eliseo.as, sodapas, jayborre, ambrish, zego2000, rendel_©, Pinkto, baikur
 adshrt
User ID: 8297
Threads: 35
Likes: 1,203 in 114 posts
Given Likes: 364
06-25-2011, 03:17 AM
[-] The following 9 users Like adshrt's post:9 users Like adshrt's post
  • kowheng, zrilek, warbeast, Dell_Brett, oanm2000, Adam Smith, ruaumoko, cristi, mowafi3m
  Cold-Formed Tubular Members and Connections. Structural Behaviour and Design TAFATNEB 0 3,198 04-25-2023, 10:48 AM
  Design of Metallic Cold-Formed Thin-Walled Members babak 8 5,584 01-03-2015, 11:34 PM
Last Post: Veggeta
  SCI P057: Design of Members Subject to Combined Bending and Torsion ir_71 3 4,272 02-17-2014, 07:58 AM
Last Post: vinnunsam
  Steel and Composite Structures - Bending members faros3000 3 3,351 11-14-2012, 09:45 AM
  Steel and Composite Structures - Compresion members faros3000 3 3,233 11-14-2012, 09:44 AM
  Steel and Composite Structures - Tension members faros3000 4 4,053 11-14-2012, 09:43 AM
