Civil Engineering Association eBooks Codes, Manual & Handbook British Standards (BS) BS EN 13524:2003+A1:2009 Highway maintenance machines — Safety requirements
01-08-2011, 05:59 AM (This post was last modified: 01-08-2011, 04:19 PM by Grunf.)
Author: CEN/TC 151 | Size: 0.7 MB | Format: PDF | Publisher: CEN | Year: 2009 | pages: 30 | ISBN: 9780580618727
[Image: 45922160381821715001.jpg]
This European Standard applies to machines used for highway maintenance which are attached to or mounted on
carrier vehicles and which are defined in clause 3. Directives and standards for the vehicular truck chassis aspect,
termed 'carrier vehicle' in this standard, would be those relevant to that equipment, even where specific
modifications have been made to adapt the machines for highway maintenance application. The use in public road
traffic is governed by the national regulations.
This European Standard deals with all significant hazards identified through a risk assessment pertinent to highway
maintenance machines, when they are used as intended and under the conditions foreseen by the manufacturer
(see clause 4). This European Standard does not deal with significant hazards associated with !deleted text"
EMC. This European Standard specifies the appropriate technical measures to eliminate or reduce risks arising
from the significant hazards associated with machine operation, setting and adjustments, load discharge and
routine maintenance.
This European Standard does not include requirements for the carrier vehicles (e.g. trucks, tractors, construction
machines, industrial trucks) as well as their demountable bodywork. These are covered in directives related to the
construction of vehicles. Demountable bodywork systems are specified in other standards.
This European Standard does not deal with:
 walker-operated an hand-held machines;
 machines for the maintenance of sports grounds;
 machines for agriculture, horticulture and forestry;
 winter-service machines;
 street-cleansing machines, except sweepers in compliance with 3.9;
 earth-moving machinery;
 pit and sewer cleaning vehicles/-machines;
 lifting platforms;
 refuse-collecting vehicles;
 bridge-inspection equipment;
 loading cranes;
 wood-choppers (bush wood choppers).
A machine which is a combination of several parts with different uses should conform to all the standards referring
to the corresponding parts of the machine.
This European Standard does not deal with the risks associated with the operation of machines in potentially
explosive atmospheres.
This standard applies to machines manufactured after the date of approval of this standard through CEN.
  • usman, blaze, toa011, Grunf, oanm2000, kowheng, peixoto, asim99
Threads: 307
01-08-2011, 04:22 PM
👉 CLICK HERE 👈 Uploaded: Jan/08/2011, File Size: 579.27 KB, RAR'd single PDF (paginated, searchable text)
If you like this publication, CivilEA's Team strongly suggest you to buy it! Support the authors!
[-] The following 6 users Like Grunf's post:6 users Like Grunf's post
  • shaqee, oanm2000, usman, kowheng, roaming79, asim99
Threads: 49
02-14-2013, 10:04 AM
links dead; reposted here:
pass:
  • Jackass, peixoto, Dell_Brett, asim99, zrilek
  BS EN 1338:2003 Concrete paving blocks. Requirements and test methods mybest 5 4,861 02-28-2016, 12:56 PM
  BS EN 14439:2006+A2:2009 Cranes. Safety. Tower cranes mybest 1 2,796 12-16-2014, 07:47 PM
Last Post: allagui10
  BS 6173:2009 Specification for installation and maintenance of gas-fired mybest 2 2,821 02-26-2013, 07:13 AM
Last Post: arshiakh
  BS 6798:2009 Specification for installation and maintenance of gas-fired boilers of r mybest 2 2,954 02-26-2013, 07:10 AM
Last Post: arshiakh
  BS EN 13659:2004+A1:2008 Shutters. Performance requirements including safety mybest 1 2,167 02-21-2013, 09:20 PM
Last Post: arshiakh
  BS OHSAS 18001:2007 Occupational health and safety management systems. Requirements mybest 1 2,344 12-08-2011, 01:06 PM
Last Post: kvtasp
