Civil Engineering Association eBooks Codes, Manual & Handbook AS/NZS 2311:2009 Guide to the painting of buildings
01-06-2011, 06:45 PM (This post was last modified: 01-07-2011, 12:38 PM by oanm2000.)
Author: Committee CH-003, | Size: 1.48 MB | Format: PDF | Publisher: AS/NZS | Year: 2009 | pages: 120 | ISBN: 0733790542
[Image: 40284795594287609835.jpg]
1.1 SCOPE
This Standard provides a guide to products and procedures for the painting of buildings for general domestic, commercial and industrial use.
The Standard does not include a specific recommendation for the long-term protection of iron or steel exposed directly to the atmosphere or to internal climates likely to have aggressive environments which are dealt with in AS/NZS 2312.
1.2 OBJECTIVE
The Standard is intended to assist those with interest in building design and maintenance such as trades people, architects, builders or building owners in the preparation of painting specifications for inclusion in contracts. It should not be called up in contracts without also specifying the detail to be derived from it.
In providing guidance on the preparation of painting and repainting specifications for surfaces forming parts of buildings, the Standard necessarily gives choices of paint types for use in different areas. For each contract, the architect, or owners, should draw up a complementary painting schedule to detail the options that are to be used together with a colour schedule. This Standard can then be referred to when specifying the necessary preparation, the coating system and the methods and conditions of application.
NOTE: Information on the preparation of painting specifications is given in Section 9 and Appendices A and B. Information on inspection and testing is given in Appendix C.
  â€¢ blaze, ascetic19, dinu69in, Dell_Brett, lednar_ved, jcbv, usman, oanm2000, kowheng, cleopie71
  ANSI/ASHRAE 189.1-2009: Standard for the Design of High-Performance Green Buildings oanm2000 3 4,196 09-15-2017, 01:13 PM
