Civil Engineering Association eBooks Codes, Manual & Handbook EN EN 12699:2000 Execution of special geotechnical work - Displacement piles
01-03-2011, 03:09 PM (This post was last modified: 09-12-2012, 10:23 PM by 3fan.)
Author: CEN/TC 288 | Size: 0.85 MB | Format: PDF | Publisher: CEN | Year: 2000 | pages: 50 | ISBN: 0580370364
[Image: 79283564945374239225.jpg]
are installed in the ground without excavation or removal of material from the ground except for limiting heave, vibration, removal of obstructions or to assist penetration.
Piles are driven into the ground using impact, vibration, pressing, screwing or a combination of these methods. 1.2 The material of displacement piles covered by this standard can be :
¾ steel ;
¾ cast iron ;
¾ concrete, mortar ;
¾ timber ;
¾ grout ;
¾ combination of above.
1.3 This standard covers prefabricated, cast in place, or a combination of these methods to form displacement
piles of regular shape.
Examples are given in Figures A.2 and A.3 in annex A.
1.4 This standard is limited to piles with a diameter or maximum cross sectional dimension greater than 150 mm.
1.5 Other than practical considerations there are for the purpose of this Standard no limitations regarding shaft
or base enlargements, length or rake.
1.6 The provisions of the standard apply to :
¾ single piles ;
¾ pile groups ;
¾ walls formed by concrete sheet piles.
1.7 Columns constructed by ground improvement techniques (such as mixed in place columns, jet grouting,
compaction grouting, vibro flotation, stone columns are not covered by this standard. Bored piles are covered in EN
1536. Steel and timber sheet piles walls are covered in EN 12063. Micropiles are covered in (WI 00288010)1).
[-] The following 22 users Like ir_71's post:22 users Like ir_71's post
  • kmmh76, amrzaki200, vvvv, ascetic19, Grunf, ilgar, oanm2000, isurya, Dell_Brett, Adam Smith, utan, nhim4mat2006, salahcivil, usman, roaming79, zrilek, kowheng, theanhpe, toa011, 2824, gatob, vpmohammed
01-19-2011, 03:27 PM (This post was last modified: 03-21-2012, 05:53 PM by Grunf.)
  • usman, Dell_Brett, oanm2000, zrilek
03-21-2012, 04:42 AM (This post was last modified: 09-12-2012, 10:41 PM by 3fan.)
New working links for EN 12699:
  • Dell_Brett, Jackass, jacs127, zrilek, blaze, eng donny, peixoto, techno
 st77bel
Romania
User ID: 12964
Threads: 12
Likes: 432 in 86 posts
Given Likes: 696
09-13-2012, 04:35 AM
Here you cand find it:
[-] The following 8 users Like st77bel's post:8 users Like st77bel's post
  • blaze, 3fan, malc, techno, PinkPant, uetian19, rizal13, CAMSECT
 3fan
Romania
User ID: 29614
Threads: 141
Likes: 7,359 in 1,207 posts
Given Likes: 5546
09-20-2012, 03:48 PM
[/MIRROR] 🔽🔽🔽🔽🔽🔽🔽🔽🔽
[-] The following 5 users Like 3fan's post:5 users Like 3fan's post
  • Dell_Brett, blaze, knrsa, serhioSPA, PinkPant
  EN 14199:2005 Execution of special geotechnical works - Micropiles ir_71 4 6,395 03-03-2022, 08:55 AM
Last Post: concreteok
  EN 12715:2000 Execution of special geotechnical work - Grouting ir_71 3 5,194 06-29-2020, 04:12 AM
  EN 12716:2001 Execution of special geotechnical works - Jet grouting ir_71 4 5,757 06-29-2020, 02:54 AM
  EN 15237:2007 Execution of special geotechnical works - Vertical drainage ir_71 1 2,825 11-03-2012, 04:44 PM
Last Post: st77bel
  EN 14475:2006 Execution of special geotechnical works - Reinforced fill ir_71 1 2,976 10-27-2012, 07:55 AM
Last Post: st77bel
