Civil Engineering Association Various Free Discussion Calculate beam and column strength
 ribak
User ID: 207
Threads: 49
Likes: 423 in 37 posts
Given Likes: 15
12-30-2010, 04:48 PM
I am looking for a software which can calculate the moment capacity of doubly reinforced concrete beam when concrete strength, steel strength, beam cross section, number of rebars and so on are given as input.
Also, with the similar input, I also want to calculate the interaction diagram of RC column so that the capacity of existing column can be determined.
 iceman84
User ID: 1829
Threads: 48
Likes: 419 in 154 posts
Given Likes: 402
12-30-2010, 05:22 PM
Any software whcih can do sectional anaysis is able to calculate the moment capacities.
You can use Xtract, Response2000, Biax or other software or you can use some Excel spreadsheets.
[-] The following 1 user Likes iceman84's post:1 user Likes iceman84's post
  • concreteok
 ivanveliki
User ID: 1250
Threads: 47
Likes: 886 in 110 posts
Given Likes: 480
12-30-2010, 06:05 PM (This post was last modified: 12-30-2010, 06:06 PM by ivanveliki.)
You can find formulas for moment capacities of beam and columns in Fardis's book about EN1998-1 here:
[-] The following 6 users Like ivanveliki's post:6 users Like ivanveliki's post
  • Dell_Brett, ruaumoko, duazo2009, Yasir, concreteok, jaks
 budis
User ID: 31753
Threads: 61
Likes: 149 in 37 posts
Given Likes: 126
01-01-2011, 06:41 AM (This post was last modified: 01-01-2011, 07:04 AM by budis.)
Dear ribak
If you do your design based on ACI Code :
1) If you want develop your own excel sheet, Mac Gregor book is a good reference to read
This book is useful both for student level & engineer level
2) If you want easy way, you can use PCA software < PCA beam & PCA column >
My suggestion you should make your own excel sheet.
Calculate "Moment Cap." provided by actual section of beam / column with its reinforcing is not difficult, you just need to read the book I mention above & you can make your own excel sheet.
Software sometime contain "bug", if you mastering the knowledge you can check your design - calculation & know whether the software containing "bug" or not.
I understand in practice ( in consultant firm ) using software is common matter, but, I suggest you should check at critical condition of your structure manually to ensure it.
Thx
[-] The following 4 users Like budis's post:4 users Like budis's post
  • concreteok, Dell_Brett, jaks, zuhalz
 seb3k
User ID: 7801
Threads: 5
Likes: 147 in 63 posts
Given Likes: 156
01-02-2011, 10:12 AM
There are good excel "RC spreadsheets: V3" here on civilea that can help you
[-] The following 1 user Likes seb3k's post:1 user Likes seb3k's post
  • jaks
 rigid_joint
Senior Member
Jamaica
User ID: 6110
Threads: 16
Likes: 333 in 122 posts
Given Likes: 244
03-05-2011, 08:46 AM
you can try GaLa Reinforcement which is free and supports all the widely used concrete codes
[-] The following 4 users Like rigid_joint's post:4 users Like rigid_joint's post
  • Dell_Brett, blr_over, ruaumoko, malc
  Beam/column chigozie 22 30,480 07-16-2010, 10:51 AM
Last Post: chigozie
