Civil Engineering Association eBooks Codes, Manual & Handbook EN EN 12502 parts 1 to 5 Protection of metallic materials against corrosion
12-19-2010, 10:50 AM (This post was last modified: 12-19-2010, 11:09 AM by ir_71.)
EN 12502 parts 1 to 5 Protection of metallic materials against corrosion — Guidance on the assessment of corrosion likelihood in water distribution and storage systems
Author: CEN/TC 262 | Size: 0.3 MB | Format: PDF | Publisher: CEN | Year: 2004 | pages: 14 | ISBN: 0 580 45298 0
[Image: 50475300712392506877.jpg]
This document gives guidance for the assessment of the corrosion likelihood of metallic materials in water
distribution and storage systems, as a result of corrosion on the water-side.
NOTE This document lists the different types of corrosion and describes in general terms the factors influencing
corrosion likelihood.
Water distribution and storage systems considered in this document are used for waters intended for human
consumption according to EC directive 98/83/EEC and for waters of similar chemical composition.
This document does not cover systems that convey the following types of water.
 sea water;
 brackish water;
 geothermal water;
 sewage water;
 swimming pool water;
 open cooling tower water;
 recirculating heating and cooling water;
 demineralized water.
Parts 2 to 5 of this document cover the factors influencing the corrosion likelihood for copper and copper
alloys, hot-dip galvanized ferrous materials, stainless steels and cast iron, unalloyed and low alloyed steels in
detail.
This document does not cover lead.
Author: CEN/TC 262 | Size: 0.45 MB | Format: PDF | Publisher: CEN | Year: 2004 | pages: 20 | ISBN: 0 580 45297 2
[Image: 96813032625308526375.jpg]
This document gives a review of influencing factors of the corrosion likelihood of copper and copper alloys used as
tubes, tanks and equipment in water distribution and storage systems as defined in EN 12502-1.
Author: CEN/TC 262 | Size: 0.4 MB | Format: PDF | Publisher: CEN | Year: 2004 | pages: 18 | ISBN: 0 580 45296 4
[Image: 96528343936704044100.jpg]
This document gives a review of influencing factors of the corrosion likelihood of hot dip galvanized steel and
cast iron, used as tubes, tanks and equipment, unalloyed and low alloy ferrous materials in water distribution
Author: CEN/TC 262 | Size: 0.35 MB | Format: PDF | Publisher: CEN | Year: 2004 | pages: 18 | ISBN: 0 580 45296 4
[Image: 34736258736662287701.jpg]
This document gives a review of influencing factors of the corrosion likelihood of stainless steels used as
Author: CEN/TC 262 | Size: 0.35 MB | Format: PDF | Publisher: CEN | Year: 2004 | pages: 16 | ISBN: 0 580 45295 6
[Image: 35583096592629846320.jpg]
This document reviews the influencing factors for the corrosion likelihood of bare unalloyed or low alloyed
ferrous materials (mild steels and cast irons) used as tubes, tanks and equipment in water distribution and
storage systems, except for water intended for human consumption.
NOTE See EN 12502-1.
  • kowheng, zrilek, datagap, Dell_Brett, jcbv, Grunf, usman, ziggywas1, cordoba123, roaming79
  EN 1011-1:2009 Welding — Recommendations for welding of metallic materials Part 1: Ge ir_71 2 3,695 04-09-2017, 04:00 AM
  EN 2243 parts 1-4 Non-metallic materials - Structural adhesives - Test method ir_71 0 2,044 12-18-2010, 11:56 AM
  EN 13636:2004 Cathodic protection of buried metallic tanks and related piping ir_71 0 2,063 12-04-2010, 07:37 AM
