Civil Engineering Association eBooks Codes, Manual & Handbook British Standards (BS) BS EN 10343:2009 Steels for quenching and tempering for construction purposes — Techn
12-17-2010, 06:48 AM
BS EN 10343:2009 Steels for quenching and tempering for construction purposes — Technical delivery conditions
Author: Technical Committee ECISS/TC 23 | Size: 0.4 MB | Format: PDF | Publisher: CEN | Year: 2009 | pages: 38 | ISBN: 978 0 580 56129 0
[Image: 17370428118373711414.jpg]
the construction industry:
bars (including hammer-forged bars);
wide flats;
hot-rolled strip and sheet/plate;
forgings.
They are manufactured from the direct hardening non alloy steels for quenching and tempering and the direct
hardening alloy steels for quenching and tempering and supplied in one of the heat treatment conditions given
for the different types of products in Table 1.
These steels are generally intended for the manufacture of quenched and tempered parts, but can also be
used in the normalized condition.
The requirements for mechanical properties are restricted to part sizes given in Tables 4 and 5.
NOTE 1 In accordance with EN 10020, the steels covered by this standard are quality and special steels. The
differences between quality and special steels are characterized by the following requirements, which are valid for special
steels only:
 the minimum impact values in the quenched and tempered condition (for non alloy special steels in the case of mean
percentages by mass of carbon < 0,50 % only);
 limited oxide inclusion content;
 lower maximum contents for phosphorus and sulphur.
NOTE 2 This standard does not apply for bright steel products.
NOTE 3 This standard only applies for the manufacture of products without any further cold or hot forming and no
additional heat treatment, i.e. the properties are according to the delivery condition (+N, +QT).
In addition to the specifications of this European Standard, the general technical delivery conditions given in
EN 10021 will be applicable unless otherwise specified
  • kowheng, Dell_Brett, Grunf, jcbv, blaze, zrilek, usman, roaming79
09-30-2012, 06:17 AM
New links:
  • miquan, Jackass, peixoto, st77bel, warbeast
  BS EN 10060:2003 Hot rolled round steel bars for general purposes - Dimensions and to ir_71 2 3,140 05-15-2014, 08:18 AM
  BS 5228:2009 Code of practice for noise and vibration control on construction and ope ir_71 1 2,181 02-14-2013, 01:20 PM
  BS 245:1976 Specification for mineral solvents for paints and other purposes ziadjordan 2 2,742 02-14-2013, 10:30 AM
  BS 8902 2009 Responsible sourcing sector certification schemes for construction produ mybest 0 1,868 11-28-2011, 04:34 PM
Last Post: mybest
