Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Theses, Journals and Papers Request Earthquake Engineering Thesis
 Administrator
CivilEA Founder
Administrators
User ID: 1
Threads: 258
Likes: 21,198 in 2,356 posts
Given Likes: 4260
09-04-2009, 02:59 PM
Krishnan, Swaminathan (2009) FRAME3D V2.0 – A Program for the Three-Dimensional Nonlinear Time-History Analysis of Steel Structures: User Guide. Technical Report: CaltechEERL:EERL-2009-04. Earthquake Engineering Research Laboratory, Pasadena, CA.
Krishnan, Swaminathan (2009) On the Modeling of Elastic and Inelastic, Critical- and Post-Buckling Behavior of Slender Columns and Bracing Members. Technical Report: CaltechEERL:EERL-2009-03. Earthquake Engineering Research Laboratory, Pasadena, CA.
Cheung, Sai Hung and Beck, James (2008) New Bayesian Updating Methodology for Model Validation and Robust Predictions Based on Data from Hierarchical Subsystem Tests. Technical Report: CaltechEERL:EERL-2008-04. Earthquake Engineering Research Laboratory, Pasadena, CA.
Olsen, Anna (2008) Steel Moment-Resisting Frame Responses in Simulated Strong Ground Motions: or How I Learned to Stop Worrying and Love the Big One. Technical Report: CaltechEERL:EERL-2008-02. Earthquake Engineering Research Laboratory, Pasadena, CA.
Wolf, Julie Anne (2008) A Plasticity Model to Predict the Effects of Confinement on Concrete. Technical Report: CaltechEERL:EERL-2008-01. Earthquake Engineering Research Laboratory, Pasadena, CA.
Taflanidis, Alexandros (2007) Stochastic System Design and Applications to Stochastically Robust Structural Control. Technical Report: CaltechEERL:EERL-2007-05. Earthquake Engineering Research Laboratory, Pasadena, CA.
Oh, Chang Kook (2007) Bayesian Learning for Earthquake Engineering Applications and Structural Health Monitoring. Technical Report: CaltechEERL:EERL-2007-04. Earthquake Engineering Research Laboratory, Pasadena, CA.
Muto, Matthew (2007) Application of Stochastic Simulation Methods to System Identification. Technical Report: CaltechEERL:EERL-2007-02. Earthquake Engineering Research Laboratory, Pasadena, CA.
Ching, Jianye and Porter, Keith A. and Beck, James L. (2007) Uncertainty Propagation and Feature Selection for Los Estimation in Performance-based Earthquake Engineering. Technical Report: CaltechEERL:EERL-2004-02. California Institute of Technology, Pasadena, California.
Yamada, Masumi (2007) Early Warning for Earthquakes with Large Rupture Dimension. Technical Report: CaltechEERL:EERL-2007-03. Earthquake Engineering Research Laboratory, Pasadena, CA.
Mitrani-Reiser, Judith (2007) An Ounce of Prevention: Probabilistic Loss Estimation for Performance-Based Earthquake Engineering. Technical Report: CaltechEERL:EERL2007-01. Earthquake Engineering Research Laboratory, Pasadena, CA.
Porter, Keith A. and Krishnan, Swaminathan and Xu, Xin (2006) Analysis of Simultaneous Operational Failure of Critical Facilities due to Earthquake, for a California Utlity. Technical Report: CaltechEERL:EERL-2006-01. Earthquake Engineering Research Laboratory, Pasadena, CA.
Bradford, Samuel Case (2006) Time-Frequency Analysis of Systems with Changing Dynamic Properties. Technical Report: CaltechEERL:EERL-2006-02. Earthquake Engineering Research Laboratory, Pasadena, CA.
Grasso, Veronica F. and Beck, James L. and Manfredi, Gaetano (2005) Seismic Early Warning Systems: Procedure for Automated Decision Making. Technical Report: CaltechEERL:EERL-2005-02. Earthquake Engineering Research Laboratory, Pasadena, CA.
Krishnan, Swaminathan and Ji, Chen and Komatitsch, Dimitri and Tromp, Jeroen (2005) Performance of 18-Story Steel Momentframe Buildings during a large San Andreas Earthquake - A Southern California-Wide End-to-End Simulation. Technical Report: CaltechEERL:EERL-2005-01. Earthquake Engineering Research Laboratory, Pasadena, California.
Cua, Georgia B. (2005) Creating the Virtual Seismologist: developments in ground motion characterization and seismic early warning. Technical Report: CaltechEERL:EERL-2004-12. Earthquake Engineering Research Laboratory, Pasadena, CA.
Alves, Steven, W. (2004) Nonlinear Analysis of Pacoima Dam with Spatially Nonuniform Ground Motion. Technical Report: CaltechEERL:EERL-2004-11. Earthquake Engineering Research Laboratory, Pasadena, CA.
Porter, Keith A. and Beck, James L. and Ching, Jianye and Mitrani-Reiser, Judith and Miyamura, M. and Kusaka, A. and Kudo, T. and Ikkatai, K. and Hyodo, Y. (2004) Real-time Loss Estimation for Instrumented Buildings. Technical Report: CaltechEERL:EERL-2004-08. Earthquake Engineering Research Laboratory, Pasadena, CA.
Porter, Keith A. (2004) A Survey of Bridge Practitioners to Relate Damage to Closure. Technical Report: CaltechEERL:EERL-2004-07. Earthquake Engineering Research Laboratory, Pasadena, California.
Scruggs, Jeffrey T. (2004) Structural Control Using Regenerative Force Actuation Networks. Technical Report: CaltechEERL:EERL-2004-09. Earthquake Engineering Research Laboratory, Pasadena, CA.
Shaikhutdinov, R. V. (2004) Structural Damage Evaluation: Theory and Applications to Earthquake Engineering. Technical Report: CaltechEERL:EERL-2004-06. Earthquake Engineering Research Laboratory, Pasadena, CA.
Guyader, Andrew (2004) A Statistical Approach to Equivalent Linearization with Applications to Performance-Based Engineering. Technical Report: CaltechEERL:EERL-2004-04. Earthquake Engineering Research Laboratory, Pasadena, CA.
Clinton, John F. (2004) Modern Digital Seismology: Instrumentation, and Small Amplitude Studies in the Engineering World. Technical Report: CaltechEERL:EERL-2004-10. Earthquake Engineering Research Laboratory, Pasadena, CA.
Guyader, Andrew and Iwan, Wilfred D. (2004) User Guide for AutoCSM: Automated Capacity Spectrum Method of Analysis. Technical Report: CaltechEERL:EERL-2004-05. Earthquake Engineering Research Laboratory, Pasadena, CA.
Krishnan, Swaminathan (2004) FRAME3D - A Program for Three-Dimensional Nonlinear Time- History Analysis of Steel Buildings: User Guide. Technical Report: CaltechEERL:EERL-2003-03. California Institute of Technology.
Ching, Jianye and Beck, James L. and Porter, Keith A. and Shaikhutdinov, Rustem (2004) Real-time Bayesian State Estimation of Uncertain Dynamical Systems. Technical Report: CaltechEERL:EERL-2004-01. California Institute of Technology.
Bradford, Samuel Case and Clinton, John F. and Favela, J. and Heaton, T. H. (2004) Results of Millikan Library Forced Vibration Testing. Technical Report: CaltechEERL:EERL-2004-03. California Institute of Technology.
Camelo, Vanessa Sabrina (2003) Dynamic Characteristics of Woodframe Buildings. Technical Report: CaltechEERL:EERL-2003-04. Earthquake Engineering Research Laboratory, Pasadena, CA.
Krishnan, Swaminathan (2003) Three-Dimensional Nonlinear Analysis of Tall Irregular Steel Buildings Subject to Strong Ground Motion. Technical Report: CaltechEERL:EERL-2003-01. California Institute of Technology.
Ching, Jianye and Beck, James L. (2003) Two-step Bayesian Structure Health Monitoring Approach for IASC-ASCE Phase II Simulated and Experimental Benchmark Studies. Technical Report: CaltechEERL:2003.EERL-2003-02. California Institute of Technology.
Beck, James L. and Porter, Keith A. and Shaikhutdinov, R. V. and Au, S. K. and Mizukoshi, K. and Miyamura, M. and Ishida, H. and Moroi, T. and Tsukada, Y. and Masuda, M. (2002) Impact of Seismic Risk on Lifetime Property Values. Technical Report: CaltechEERL:2002.EERL-2002-04. California Institute of Technology.
Porter, Keith A. and Beck, James L. and Seligson, Hope A. and Scawthorn, Charles R. and Tobin, L. Thomas and Young, Ray and Boyd, Tom (2002) Improving Loss Estimation for Woodframe Buildings. Volume 1: Report. Technical Report: CaltechEERL:2002.EERL-2002-01. Consortium of Universities for Research in Earthquake Engineering, Richmond, CA.
Porter, Keith A. and Beck, James L. and Seligson, Hope A. and Scawthorn, Charles R. and Tobin, L. Thomas and Young, Ray and Boyd, Tom (2002) Improving Loss Estimation for Woodframe Buildings. Volume 2: Appendices. Technical Report: CaltechEERL:2002.EERL-2002-02. Consortium of Universities for Research in Earthquake Engineering, Richmond, CA.
Yuen, Ka-Veng (2002) Model Selection Identification and Robust Control for Dynamical Systems. Technical Report: CaltechEERL:2002.EERL-2002-03. California Institute of Technology.
Huixian, Liu and Housner, George W. and Lili, Xie and Duxin, He (2002) The Great Tangshan Earthquake of 1976. Technical Report: CaltechEERL:EERL.2002.001. California Institute of Technology.
Au, Siu-Kui (2001) On the solution of first excursion problems by simulation with applications to probabilistic seismic performance assessment. Technical Report: CaltechEERL:2001.EERL-2001-02. California Institute of Technology.
Zhang, Yunfeng (2001) Semi-active control of dynamically excited structures using active interaction control. Technical Report: CaltechEERL:2001.EERL-2001-01. California Institute of Technology.
Au, Siu-Kui and Beck, James L. (2000) On the solution of first-excursion failure problem for linear systems by efficient simulation. Technical Report: CaltechEERL:2000.EERL-2000-01. California Institute of Technology.
Irfanoglu, Ayhan (2000) Structural design under seismic risk using multiple performance objectives. Technical Report: CaltechEERL:2000.EERL-2000-02. California Institute of Technology.
Aagaard, Brad Thomas (1999) Finite-element simulations of earthquakes. Technical Report: CaltechEERL:1999.EERL-99-03. California Institute of Technology.
Halling, Marvin Wilford (1999) Investigation of base-isolated structures during recent earthquakes and computer simulations utilizing near-source long-period ground motions. Technical Report: CaltechEERL:1999.EERL-95-09. California Institute of Technology.
Carlson, Anders E. (1999) Three-dimensional nonlinear inelastic analysis of steel moment-frame buildings damaged by earthquake excitations. Technical Report: CaltechEERL:1999.EERL-99-02. California Institute of Technology.
Beck, James L. and Papadimitriou, Costas and Chan, Eduardo and Irfanoglu, Ayhan (1998) A performance-based optimal structural design methodology. Technical Report: CaltechEERL:1998.EERL-97-03. California Institute of Technology.
Iwan, Wilfred D. and Toki, K. (1998) Proceedings of the U.S.-Japan Workshop on near-field earthquake damage in urban areas, Honolulu, Hawaii, January 5-7, 1998. Technical Report: CaltechEERL:1998.EERL-98-01. California Institute of Technology.
Vanik, Michael W. (1997) A Bayesian probabilistic approach to structural health monitoring. Technical Report: CaltechEERL:1997.EERL-97-07. California Institute of Technology.
Polidori, David C. (1997) A probabilistic treatment of uncertainty in nonlinear dynamical systems. Technical Report: CaltechEERL:1997.EERL-97-09. California Institute of Technology.
Wang, Luo-Jia (1997) Active interaction control for civil structures. Technical Report: CaltechEERL:1997.EERL-97-04. California Institute of Technology.
Jennings, Paul C. (1997) Earthquake response of tall regular buildings. Technical Report: CaltechEERL:1997.EERL-97-01. California Institute of Technology.
Hall, John F. (1997) Efficient nonlinear seismic analysis of arch dams: User's manual for SCADA, Smeared Crack Arch Dam Analysis. Technical Report: CaltechEERL:1997.EERL-96-01. California Institute of Technology.
Chan, Eduardo (1997) Optimal design of building structures using genetic algorithms. Technical Report: CaltechEERL:1997.EERL-97-06. California Institute of Technology.
May, B. Scott (1997) Probabilistic robust control: theory and applications. Technical Report: CaltechEERL:1997.EERL-97-08. California Institute of Technology.
Hall, John F. (1997) Seismic response of steel frame buildings to near-source ground motions. Technical Report: CaltechEERL:1997.EERL-97-05. California Institute of Technology.
Wang, Luo-Jia and Gu, Qun and Iwan, Wilfred D. (1996) A Collection of processed near-field earthquake accelerograms with response and drift spectra. Technical Report: CaltechEERL:1996.EERL-96-05. California Institute of Technology.
Gan, Wenshui (1996) Earthquake response of steel braces and braced steel frames. Technical Report: CaltechEERL:1996.EERL-96-06. California Institute of Technology.
Huang, Ching-Tung (1996) On the dynamic response of nonlinear uncertain systems. Technical Report: CaltechEERL:1996.EERL-96-03. California Institute of Technology.
Wang, Luo-Jia (1996) Processing of near-field earthquake accelerograms. Technical Report: CaltechEERL:1996.EERL-96-04. California Institute of Technology.
Yang, Chi-Ming (1996) Statistical system identification and applications to seismic response of structures. Technical Report: CaltechEERL:1996.EERL-96-02. California Institute of Technology.
Beck, James L. and May, B. Scott and Polidori, David C. and Vanik, Michael W. (1995) Ambient vibration studies of three steel-frame buildings strongly shaken by the 1994 Northridge earthquake. Technical Report: CaltechEERL:1995.EERL-95-06. California Institute of Technology.
Papadimitriou, Costas and Beck, James L. and Katafygiotis, Lambros S. (1995) Asymptotic expansions for reliabilities and moments of uncertain dynamic systems. Technical Report: CaltechEERL:1995.EERL-95-05. California Institute of Technology.
Iwan, Wilfred D. (1995) Drift demand spectra for selected Northridge sites. Technical Report: CaltechEERL:1995.EERL-95-07. California Institute of Technology.
Huang, Liping (1995) Mode-like properties and identification of nonlinear vibrating systems. Technical Report: CaltechEERL:1995.EERL-95-04. California Institute of Technology.
Chen, Xiaodong (1995) Near-field ground motion from the Landers earthquake. Technical Report: CaltechEERL:1995.EERL-95-02. California Institute of Technology.
Hall, John F. (1995) Parameter study of the response of moment-resisting steel frame buildings to near-source ground motions. Technical Report: CaltechEERL:1995.EERL-95-08. California Institute of Technology.
Hayen, Jeffrey Clyde (1995) Response control of structural systems using semi-actively controlled interactions. Technical Report: CaltechEERL:1995.EERL-95-03. California Institute of Technology.
Pich, Peter (1994) Nonlinear rigid block dynamics. Technical Report: CaltechEERL:1994.EERL-95-01. California Institute of Technology.
Challa, Venkata Ramana Murty (1992) Nonlinear seismic behaviour of steel planar moment-resisting frames. Technical Report: CaltechEERL:1992.EERL-92-01. California Institute of Technology.
Chiang, Dar-Yun (1992) Parsimonious modeling of inelastic systems. Technical Report: CaltechEERL:1992.EERL-92-02. California Institute of Technology.
Iwan, Wilfred D. (1992) Proceedings of the International Workshop on Seismic Design and Reassessment of Offshore Structures. Technical Report: CaltechEERL:1992.EERL.1992.001. California Institute of Technology.
Beck, Robert Teran (1991) Fundamental problems in the application of structural identification procedures to damage detection. Technical Report: CaltechEERL:1991.EERL-91-03. California Institute of Technology.
Hall, John F. and Dowling, Michael J. and El-Aidi, Bahaa (1991) Defensive design of concrete gravity dams. Technical Report: CaltechEERL:1991.EERL-91-02. California Institute of Technology.
Katafygiotis, Lambros S. (1991) Treatment of model uncertainties in structural dynamics. Technical Report: CaltechEERL:1991.EERL-91-01. California Institute of Technology.
Levine, Marie-Bernard P. (1990) Accelerogram processing using reliability bounds and optimal correction methods. Technical Report: CaltechEERL:1990.EERL-90-02. California Institute of Technology.
Hou, Zhikun (1990) Nonstationary response of structures and its application to earthquake engineering. Technical Report: CaltechEERL:1990.EERL-90-01. California Institute of Technology.
Papadimitriou, Konstantinos (1990) Stochastic characterization of strong ground motion and applications to structural response. Technical Report: CaltechEERL:1990.EERL-90-03. California Institute of Technology.
Donlon, William P (1989) Experimental investigation of the nonlinear seismic response of concrete gravity dams. Technical Report: CaltechEERL:1989.EERL-89-01. California Institute of Technology.
US-China Joint Project on Strong Ground Motion Measurements, (1989) Digital near source accelerograms recorded by instrumental arrays in Tangshan, China. Part I (1982.7-1984.12). Technical Report: CaltechEERL:1989.EERL-89-04. California Institute of Technology.
Jensen, Hector A (1989) Dynamic response of structures with uncertain parameters. Technical Report: CaltechEERL:1989.EERL-89-02. California Institute of Technology.
Thyagarajan, Ravi Shanker (1989) Modeling and analysis of hysteretic structural behavior. Technical Report: CaltechEERL:1989.EERL-89-03. California Institute of Technology.
Levine, Marie-Bernard P. and Beck, James L. and Iwan, Wilfred D. and Jennings, Paul C. and Relles, Raul (1988) Accelerograms recorded at Caltech during the Whittier Narrows earthquakes of October 1 and 4, 1987 : a preliminary report. Technical Report: CaltechEERL:1988.EERL-88-01. California Institute of Technology.
Nowak, Paul Scott (1988) Effect of nonuniform seismic input on arch dams. Technical Report: CaltechEERL:1988.EERL-88-03. California Institute of Technology.
El-Aidi, Bahaa (1988) Nonlinear earthquake response of concrete gravity dam systems. Technical Report: CaltechEERL:1988.EERL-88-02. California Institute of Technology.
Duron, Ziyad H. (1987) Experimental and finite element studies of a large arch dam. Technical Report: CaltechEERL:1987.EERL-87-02. California Institute of Technology.
Peng, Chia-Yen (1987) Generalized modal identification of linear and nonlinear dynamic systems. Technical Report: CaltechEERL:1987.EERL-87-05. California Institute of Technology.
Jayakumar, Paramsothy (1987) Modeling and identification in structural dynamics. Technical Report: CaltechEERL:1987.EERL-87-01. California Institute of Technology.
Dowling, Michael J. (1987) Nonlinear seismic analysis of arch dams. Technical Report: CaltechEERL:1988.EERL-87-03. California Institute of Technology.
Whirley, Robert Gary (1987) Random response of nonlinear continuous systems. Technical Report: CaltechEERL:1987.EERL-87-04. California Institute of Technology.
Peek, Ralf (1986) Analysis of unanchored liquid storage tanks under seismic loads. Technical Report: CaltechEERL:1986.EERL-86-01. California Institute of Technology.
Paparizos, Leonidas G (1986) Some observations on the random response of hysteretic systems. Technical Report: CaltechEERL:1986.EERL-86-02. California Institute of Technology.
Moser, Michael Anthony (1986) The response of stick-slip systems to random seismic excitation. Technical Report: CaltechEERL:1986.EERL-86-03. California Institute of Technology.
Beck, Robert Teran and Beck, James L. (1985) Comparison between transfer function and modal minimization methods for system identification. Technical Report: CaltechEERL:1985.EERL-85-06. California Institute of Technology.
Jeong, Garrett Duane (1985) Cumulative damage of structures subjected to response spectrum consistent random processes. Technical Report: CaltechEERL:1985.EERL-85-03. California Institute of Technology.
Pak, Ronald Y. S (1985) Dynamic response of a partially embedded bar under transverse excitations. Technical Report: CaltechEERL:1985.EERL-85-04. California Institute of Technology.
Maragakis, Emmanuel (1984) A model for the rigid body motions of skew bridges. Technical Report: CaltechEERL:1984.EERL-85-02. California Institute of Technology.
Chelvakumar, Kasivisvanathan (1984) A Simple strain-space plasticity model for clays. Technical Report: CaltechEERL:1984.EERL-85-05. California Institute of Technology.
Wilson, John Charles (1984) Analysis of the observed earthquake response of a multiple span bridge. Technical Report: CaltechEERL:1984.EERL-84-01. California Institute of Technology.
Smith, Kenneth Scott (1984) Stochastic analysis of the seismic response of secondary systems. Technical Report: CaltechEERL:1984.EERL-85-01. California Institute of Technology.
Iwan, Wilfred D. and Moser, Michael Anthony and Peng, Chia-Yen (1984) Strong-motion earthquake measurement using a digital accelerograph. Technical Report: CaltechEERL:1984.EERL-84-02. California Institute of Technology.
Cifuentes, Arturo O (1984) System identification of hysteretic structures. Technical Report: CaltechEERL:1984.EERL-84-04. California Institute of Technology.
Jain, Sudhir Kumar (1983) Analytical models for the dynamics of buildings. Technical Report: CaltechEERL:1983.EERL-83-02. California Institute of Technology.
Huang, Moh-jiann (1983) Investigation of local geology effects on strong earthquake ground motions. Technical Report: CaltechEERL:1983.EERL-83-03. California Institute of Technology.
McVerry, Graeme Haynes and Beck, James L. (1983) Structural identification of JPL Building 180 using optimally synchronized earthquake records. Technical Report: CaltechEERL:1983.EERL-83-01. California Institute of Technology.
Botelho, Dirceu Luiz Rodrigues (1982) An empirical model for vortex-induced vibrations. Technical Report: CaltechEERL:1982.EERL-82-02. California Institute of Technology.
Rashed, Ahmed (1982) Dynamic analyses of fluid-structure systems. Technical Report: CaltechEERL:1982.EERL-82-03. California Institute of Technology.
Lin, Albert Niu (1982) Experimental observations of the effect of foundation embedment on structural response. Technical Report: CaltechEERL:1982.EERL-82-01. California Institute of Technology.
Psycharis, Ioannis N. (1981) Dynamic behavior of rocking structures allowed to uplift. Technical Report: CaltechEERL:1981.EERL-81-02. California Institute of Technology.
Shih, Choon-Foo (1981) Failure of liquid storage tanks due to earthquake excitation. Technical Report: CaltechEERL:1981.EERL-81-04. California Institute of Technology.
Iwan, Wilfred D. (1981) U.S. Strong-Motion Earthquake Instrumentation: Proceedings of the U.S. National Workshop on Strong-Motion Earthquake Instrumentation. Technical Report: CaltechEERL:1981.EERL.1981.001. Earthquake Engineering Research Laboratory.
Krousgrill, Charles Morton (1980) A linearization technique for the dynamic response of nonlinear continua. Technical Report: CaltechEERL:1980.EERL-80-08. California Institute of Technology.
Lee, David M. and Jennings, Paul C. and Housner, George W. (1980) A Selection of important strong motion earthquake records. Technical Report: CaltechEERL:1980.EERL-80-01. California Institute of Technology.
Yoder, Paul Jerome (1980) A strain-space plasticity theory and numerical implementation. Technical Report: CaltechEERL:1980.EERL-80-07. California Institute of Technology.
Liu, Wing Kam (1980) Development of finite element procedures for fluid-structure interaction. Technical Report: CaltechEERL:1980.EERL-80-06. California Institute of Technology.
Haroun, Medhat Ahmed (1980) Dynamic analyses of liquid storage tanks. Technical Report: CaltechEERL:1980.EERL-80-04. California Institute of Technology.
Abdel-Ghaffar, Ahmed Mansour and Scott, Ronald F. and Craig, Michael J. (1980) Full-scale experimental investigation of a modern earth dam. Technical Report: CaltechEERL:1980.EERL-80-02. California Institute of Technology.
Cohen, Martin (1980) Silent boundary methods for transient wave analysis. Technical Report: CaltechEERL:1980.EERL-80-09. California Institute of Technology.
Rutenberg, Avigdor and Jennings, Paul C. and Housner, George W. (1980) The response of Veteran's Hospital building 41 in the San Fernando earthquake. Technical Report: CaltechEERL:1980.EERL-80-03. California Institute of Technology.
Hall, Shawn Anthony (1980) Vortex-induced vibrations of structures. Technical Report: CaltechEERL:1980.EERL-81-01. California Institute of Technology.
McVerry, Graeme Haynes (1979) Frequency domain identification of structural models from earthquake records. Technical Report: CaltechEERL:1979.EERL-79-02. California Institute of Technology.
Mason, Alfred B (1979) Some observations on the random response of linear and nonlinear dynamical systems. Technical Report: CaltechEERL:1979.EERL-79-01. California Institute of Technology.
Abdel-Ghaffar, Ahmed Mansour and Scott, Ronald F. (1978) An Investigation of the dynamic characteristics of an earth dam. Technical Report: CaltechEERL:1978.EERL-78-02. California Institute of Technology.
Beck, James L. (1978) Determining models of structures from earthquake records. Technical Report: CaltechEERL:1978.EERL-78-01. California Institute of Technology.
Helmberger, Donald V. and Jennings, Paul C. (1978) Strong ground motion : N.S.F. Seminar-Workshop Proceedings. Technical Report: CaltechEERL:EERL.1978.002. California Institute of Technology.
Iwan, Wilfred D. (1978) Strong-motion earthquake instrument arrays : proceedings of the International Workshop on Strong-Motion Earthquake Instrument Arrays, May 2-5, 1978, Honolulu, Hawaii. Technical Report: CaltechEERL:EERL.1978.001. California Institute of Technology.
Psycharis, Ioannis N. (1978) The Salonica (Thessaloniki) earthquake of June 20, 1978. Technical Report: CaltechEERL:1978.EERL-78-03. California Institute of Technology.
Abdel-Ghaffar, Ahmed Mansour and Housner, George W. (1977) An analysis of the dynamic characteristics of a suspension bridge by ambient vibration measurements. Technical Report: CaltechEERL:1977.EERL-77-01. California Institute of Technology.
Housner, George W. and Jennings, Paul C. (1977) Earthquake design criteria for structures. Technical Report: CaltechEERL:1977.EERL-77-06. California Institute of Technology.
Morrison, Paul and Maley, Richard and Brady, Gerald and Porcella, Ronald (1977) Earthquake recordings on or near Dams. Technical Report: CaltechEERL:1977.EERL.1977.002. California Institute of Technology.
Abdel-Ghaffar, Ahmed Mansour (1977) Engineering data and analyses of the Whittier, California earthquake of January 1, 1976. Technical Report: CaltechEERL:1977.EERL-77-05. California Institute of Technology.
Daly, W and Judd, W and Meade, R (1977) Evaluation of seismicity at U.S. reservoirs. Technical Report: CaltechEERL:1977.EERL.1977.001. California Institute of Technology.
Abdel-Ghaffar, Ahmed Mansour (1977) Studies on the effect of differential motions of two foundations upon the response of the superstructure of a bridge. Technical Report: CaltechEERL:1977.EERL-77-02. California Institute of Technology.
Gates, Nathan Craig (1977) The earthquake response of deteriorating systems. Technical Report: CaltechEERL:1977.EERL-77-03. California Institute of Technology.
Foutch, Douglas Allen (1976) A study of the vibrational characteristics of two multistory buildings. Technical Report: CaltechEERL:1976.EERL-76-03. California Institute of Technology.
Abdel-Ghaffar, Ahmed Mansour (1976) Dynamic analyses of suspension bridge structures. Technical Report: CaltechEERL:1976.EERL-76-01. California Institute of Technology.
Spanos, P-T. D (1976) Linearization techniques for non-linear dynamical systems. Technical Report: CaltechEERL:1976.EERL-76-04. California Institute of Technology.
Earthquake Engineering Research Laboratory, (1976) Strong motion earthquake accelerograms index volume. Technical Report: CaltechEERL:1976.EERL-76-02. California Institute of Technology.
Earthquake Engineering Research Laboratory, (1975) Analyses of strong motion earthquake accelerograms, Volume III - Response spectra; Part T - Accelerograms IIT274 through IIT293. Technical Report: CaltechEERL:1975.EERL-75-80. California Institute of Technology.
Earthquake Engineering Research Laboratory, (1975) Analyses of strong motion earthquake accelerograms, Volume III - Response spectra; Part U - Accelerograms IIU294 through IIU313. Technical Report: CaltechEERL:1975.EERL-75-81. California Institute of Technology.
Earthquake Engineering Research Laboratory, (1975) Analyses of strong motion earthquake accelerograms, Volume III - Response spectra; Part V - Accelerograms IIV314 through IIV333. Technical Report: CaltechEERL:1975.EERL-75-82. California Institute of Technology.
Earthquake Engineering Research Laboratory, (1975) Analyses of strong motion earthquake accelerograms, Volume III - Response spectra; Parts W and Y - Accelerograms IIW334 to IIW336, IIW338, IIW339, IIW342 to IIW345, and IIY370 to IIY381. Technical Report: CaltechEERL:1975.EERL-75-83. California Institute of Technology.
Earthquake Engineering Research Laboratory, (1975) Analyses of strong motion earthquake accelerograms, Volume IV - Fourier amplitude spectra; Parts T and U - Accelerograms IIT274 to IIT293 and IIU294 to IIU313. Technical Report: CaltechEERL:1975.EERL-75-100. California Institute of Technology.
Earthquake Engineering Research Laboratory, (1975) Analyses of strong motion earthquake accelerograms, Volume IV - Fourier amplitude spectra; Parts V, W, and Y - Accelerograms IV294 to IV333, IIW334 to IIW336, IIW338, IIW339, IIW342 to IIW345, and IIY370 to IIY381. Technical Report: CaltechEERL:1975.EERL-75-101. California Institute of Technology.
Foutch, Douglas Allen and Housner, George W. and Jennings, Paul C. (1975) Dynamic responses of six multistory buildings during the San Fernando earthquake. Technical Report: CaltechEERL:1975.EERL-75-02. California Institute of Technology.
Wong, Hung Leung (1975) Dynamic soil-structure interaction. Technical Report: CaltechEERL:1975.EERL-75-01. California Institute of Technology.
Earthquake Engineering Research Laboratory, (1975) Strong motion earthquake accelerograms, digitized and plotted data, Volume I - uncorrected accelerograms; Part X - Accelerograms IX355 through IX369. Technical Report: CaltechEERL:1975.EERL-73-29. California Institute of Technology.
Earthquake Engineering Research Laboratory, (1975) Strong motion earthquake accelerograms, digitized and plotted data, Volume I - Uncorrected accelerograms; Part T - Accelerograms IT274 through IT293. Technical Report: CaltechEERL:1975.EERL-73-25. California Institute of Technology.
Earthquake Engineering Research Laboratory, (1975) Strong motion earthquake accelerograms, digitized and plotted data, Volume I - uncorrected accelerograms; Part U - Accelerograms IU294 through IU313. Technical Report: CaltechEERL:1975.EERL-73-26. California Institute of Technology.
Earthquake Engineering Research Laboratory, (1975) Strong motion earthquake accelerograms, digitized and plotted data, Volume I - Uncorrected accelerograms; Part V - Accelerograms IV314 through IV333. Technical Report: CaltechEERL:1975.EERL-73-27. California Institute of Technology.
Earthquake Engineering Research Laboratory, (1975) Strong motion earthquake accelerograms, digitized and plotted data, Volume I - Uncorrected accelerograms; Part W - Accelerograms IW334 through IW 354. Technical Report: CaltechEERL:1975.EERL-73-28. California Institute of Technology.
Earthquake Engineering Research Laboratory, (1975) Strong motion earthquake accelerograms, digitized and plotted data, Volume I - uncorrected accelerograms; Part Y - Accelerograms IY370 through IY381. Technical Report: CaltechEERL:1975.EERL-73-30. California Institute of Technology.
Earthquake Engineering Research Laboratory, (1975) Strong motion earthquake accelerograms, digitized and plotted data, Volume II - corrected accelerograms and integrated ground velocity and displacement curves; Part U - Accelerograms IIU294 through IIU313. Technical Report: CaltechEERL:1975.EERL-75-51. California Institute of Technology.
Earthquake Engineering Research Laboratory, (1975) Strong motion earthquake accelerograms, digitized and plotted data, Volume II - corrected accelerograms and integrated ground velocity and displacement curves; Parts W and Y - Accelerograms IIW334 to IIW336, IIW338, IIW339, IIW342 to IIW345, and IIY370... Technical Report: CaltechEERL:1975.EERL-75-53. California Institute of Technology.
Earthquake Engineering Research Laboratory, (1975) Strong motion earthquake accelerograms, digitized and plotted data, Volume II - integrated ground velocity and displacement curves; Part T - Accelerograms IT274 through IT293. Technical Report: CaltechEERL:1975.EERL-75-50. California Institute of Technology.
Earthquake Engineering Research Laboratory, (1975) Strong motion earthquake accelerograms, digitized and plotted data, Volume II - integrated ground velocity and displacement curves; Part V - Accelerograms IIV314 through IIV333. Technical Report: CaltechEERL:1975.EERL-75-52. California Institute of Technology.
Miller, Richard Keith (1975) The Steady-state response of multidegree-of-freedom systems with a spatially localized nonlinearity. Technical Report: CaltechEERL:1975.EERL-75-03. California Institute of Technology.
Earthquake Engineering Research Laboratory, (1974) Analyses of strong motion earthquake accelerograms, Volume III - Response spectra; Part H - Accelerograms IIH115 through IIH126. Technical Report: CaltechEERL:1974.EERL-74-80. California Institute of Technology.
Earthquake Engineering Research Laboratory, (1974) Analyses of strong motion earthquake accelerograms, Volume III - Response spectra; Part I - Accelerograms II-I-128 through II-I-139. Technical Report: CaltechEERL:1974.EERL-74-81. California Institute of Technology.
Earthquake Engineering Research Laboratory, (1974) Analyses of strong motion earthquake accelerograms, Volume III - Response spectra; Part S - Accelerograms IIS255 through IIS273. Technical Report: CaltechEERL:1974.EERL-74-86. California Institute of Technology.
Earthquake Engineering Research Laboratory, (1974) Analyses of strong motion earthquake accelerograms, Volume III - Response spectra; Parts J, K, and L - Accelerograms IIJ141 through IIJ150, IIK157 through IIK160, and IIL166 through IIL175. Technical Report: CaltechEERL:1974.EERL-74-82. California Institute of Technology.
Earthquake Engineering Research Laboratory, (1974) Analyses of strong motion earthquake accelerograms, Volume III - Response spectra; Parts M and N - Accelerograms IIM176 through IIM184 and IIN185 through IIN197. Technical Report: CaltechEERL:1974.EERL-74-83. California Institute of Technology.
Earthquake Engineering Research Laboratory, (1974) Analyses of strong motion earthquake accelerograms, Volume III - Response spectra; Parts O and P - Accelerograms IIO198 to IIO201,IIO204 to IIO208, IIO210, IIO213, IIP214 to IIP223, IIP231 and IIP232. Technical Report: CaltechEERL:1974.EERL-74-84. California Institute of Technology.
Earthquake Engineering Research Laboratory, (1974) Analyses of strong motion earthquake accelerograms, Volume III - Response spectra; Parts Q and R - Accelerograms IIQ233 through IIQ243, IIR244 through IIR254. Technical Report: CaltechEERL:1974.EERL-74-85. California Institute of Technology.
Earthquake Engineering Research Laboratory, (1974) Analyses of strong motion earthquake accelerograms, Volume IV - Fourier amplitude spectra; Part H - Accelerograms IIH115 through IIH126. Technical Report: CaltechEERL:1974.EERL-74-100. California Institute of Technology.
Earthquake Engineering Research Laboratory, (1974) Analyses of strong motion earthquake accelerograms, Volume IV - Fourier amplitude spectra; Part I - Accelerograms II-I-128 through II-I-139. Technical Report: CaltechEERL:1974.EERL-74-101. California Institute of Technology.
Earthquake Engineering Research Laboratory, (1974) Analyses of strong motion earthquake accelerograms, Volume IV - Fourier amplitude spectra; Parts J, K, L, and M - Accelerograms IIJ141 through IIJ150, IIK157 through IIK160, IIL166 through IIL175, and IIM176 through IIM184. Technical Report: CaltechEERL:1974.EERL-74-102. California Institute of Technology.
Earthquake Engineering Research Laboratory, (1974) Analyses of strong motion earthquake accelerograms, Volume IV - Fourier amplitude spectra; Parts N, O, and P - Accelerograms IIN185 to IIN197, IIO198 to IIO201, IIO213, IIP214 to IIP223, IIP231 and IIP232. Technical Report: CaltechEERL:1974.EERL-74-103. California Institute of Technology.
Earthquake Engineering Research Laboratory, (1974) Analyses of strong motion earthquake accelerograms, Volume IV - Fourier amplitude spectra; Parts Q, R and S - Accelerograms IIQ233 to IIQ243, IIR244 to IIR254, IIS255 to IIS273. Technical Report: CaltechEERL:1974.EERL-74-104. California Institute of Technology.
Earthquake Engineering Research Laboratory, (1974) Strong motion earthquake accelerograms, digitized and plotted data, Volume I - uncorrected accelerograms; Part S - Accelerograms IS255 through IS273, Accelerograms from the San Fernando, California, earthquake of February 9, 1971. Technical Report: CaltechEERL:1974.EERL-73-24. California Institute of Technology.
Earthquake Engineering Research Laboratory, (1974) Strong motion earthquake accelerograms, digitized and plotted data, Volume I - Uncorrected accelerograms; Part R - Accelerograms IR244 through IR 254. Technical Report: CaltechEERL:1973.EERL-73-23. California Institute of Technology.
Earthquake Engineering Research Laboratory, (1974) Strong motion earthquake accelerograms, digitized and plotted data, Volume II - corrected accelerograms and integrated ground velocity and displacement curves; Part H - Accelerograms IIH115 through IIHI26. Technical Report: CaltechEERL:1974.EERL-74-50. California Institute of Technology.
Earthquake Engineering Research Laboratory, (1974) Strong motion earthquake accelerograms, digitized and plotted data, Volume II - corrected accelerograms and integrated ground velocity and displacement curves; Part I - Accelerograms II-I-128 through II-I-139. Technical Report: CaltechEERL:1974.EERL-74-51. California Institute of Technology.
Earthquake Engineering Research Laboratory, (1974) Strong motion earthquake accelerograms, digitized and plotted data, Volume II - corrected accelerograms and integrated ground velocity and displacement curves; Part N - Accelerograms IIN185 through IIN197. Technical Report: CaltechEERL:1974.EERL-74-54. California Institute of Technology.
Earthquake Engineering Research Laboratory, (1974) Strong motion earthquake accelerograms, digitized and plotted data, Volume II - corrected accelerograms and integrated ground velocity and displacement curves; Part S - Accelerograms IIS255 through IIS273. Technical Report: CaltechEERL:1974.EERL-74-57. California Institute of Technology.
Earthquake Engineering Research Laboratory, (1974) Strong motion earthquake accelerograms, digitized and plotted data, Volume II - corrected accelerograms and integrated ground velocity and displacement curves; Parts J and K - Accelerograms IIJ141 through IIJ150 and IIK157 through IIK160. Technical Report: CaltechEERL:1974.EERL-74-52. California Institute of Technology.
Earthquake Engineering Research Laboratory, (1974) Strong motion earthquake accelerograms, digitized and plotted data, Volume II - corrected accelerograms and integrated ground velocity and displacement curves; Parts L and M - Accelerograms IIL166 through IIL175 and IIM176 through IIM184. Technical Report: CaltechEERL:1974.EERL-74-53. California Institute of Technology.
Earthquake Engineering Research Laboratory, (1974) Strong motion earthquake accelerograms, digitized and plotted data, Volume II - corrected accelerograms and integrated ground velocity and displacement curves; Parts O and P - Accelerograms IIO198 to IIO201, IIO204 to IIO208, IIO210, IIO213, IIP214 to ... Technical Report: CaltechEERL:1974.EERL-74-55. California Institute of Technology.
Earthquake Engineering Research Laboratory, (1974) Strong motion earthquake accelerograms, digitized and plotted data, Volume II - corrected accelerograms and integrated ground velocity and displacement curves; Parts Q and R - Accelerograms IIQ233 to IIQ243 and IIR244 to IIR254. Technical Report: CaltechEERL:1974.EERL-74-56. California Institute of Technology.
Jephcott, Donald K. and Hudson, Donald E. (1974) The performance of public school plants during the San Fernando earthquake. Technical Report: CaltechEERL:1974.EERL-74-01. California Institute of Technology.
Earthquake Engineering Research Laboratory, (1973) Analyses of strong motion earthquake accelerograms, Volume III - Response spectra; Part B - Accelerograms IIB021 through IIB040. Technical Report: CaltechEERL:1973.EERL-73-80. California Institute of Technology.
Earthquake Engineering Research Laboratory, (1973) Analyses of strong motion earthquake accelerograms, Volume III - Response spectra; Part C - Accelerograms IIC041 through IIC055. Technical Report: CaltechEERL:1973.EERL-73-81. California Institute of Technology.
Earthquake Engineering Research Laboratory, (1973) Analyses of strong motion earthquake accelerograms, Volume III - Response spectra; Part D - Accelerograms IID056 through IID070. Technical Report: CaltechEERL:1973.EERL-73-82. California Institute of Technology.
Earthquake Engineering Research Laboratory, (1973) Analyses of strong motion earthquake accelerograms, Volume III - Response spectra; Part E - Accelerograms IIE071 through IIE085. Technical Report: CaltechEERL:1973.EERL-73-83. California Institute of Technology.
Earthquake Engineering Research Laboratory, (1973) Analyses of strong motion earthquake accelerograms, Volume III - Response spectra; Part F - Accelerograms IIF086 through IIF105. Technical Report: CaltechEERL:1973.EERL-73-84. California Institute of Technology.
Earthquake Engineering Research Laboratory, (1973) Analyses of strong motion earthquake accelerograms, Volume III - Response spectra; Part G - Accelerograms IIG106 through IIG114. Technical Report: CaltechEERL:1973.EERL-73-85. California Institute of Technology.
Earthquake Engineering Research Laboratory, (1973) Analyses of strong motion earthquake accelerograms, Volume IV - Fourier amplitude spectra; Part B - Accelerograms IIB021 through IIB040. Technical Report: CaltechEERL:1973.EERL-73-100. California Institute of Technology.
Earthquake Engineering Research Laboratory, (1973) Analyses of strong motion earthquake accelerograms, Volume IV - Fourier amplitude spectra; Part C - Accelerograms IIC041 through IlC055. Technical Report: CaltechEERL:1973.EERL-73-101. California Institute of Technology.
Earthquake Engineering Research Laboratory, (1973) Analyses of strong motion earthquake accelerograms, Volume IV - Fourier amplitude spectra; Part D - Accelerograms IID056 through IID070. Technical Report: CaltechEERL:1973.EERL-73-102. California Institute of Technology.
Earthquake Engineering Research Laboratory, (1973) Analyses of strong motion earthquake accelerograms, Volume IV - Fourier amplitude spectra; Part E - Accelerograms IIE071 through IIE085. Technical Report: CaltechEERL:1973.EERL-73-103. California Institute of Technology.
Earthquake Engineering Research Laboratory, (1973) Analyses of strong motion earthquake accelerograms, Volume IV - Fourier amplitude spectra; Part F - Accelerograms IIF086 through IIF105. Technical Report: CaltechEERL:1973.EERL-73-104. California Institute of Technology.
Earthquake Engineering Research Laboratory, (1973) Analyses of strong motion earthquake accelerograms, Volume IV - Fourier amplitude spectra; Part G - Accelerograms IIG106 through IIG114. Technical Report: CaltechEERL:1973.EERL-73-105. California Institute of Technology.
Wood, John H (1973) Earthquake-induced soil pressures on structures. Technical Report: CaltechEERL:1973.EERL-73-05. California Institute of Technology.
Crouse, C. B (1973) Engineering studies of the San Fernando earthquake. Technical Report: CaltechEERL:1973.EERL-73-04. California Institute of Technology.
Iemura, H. and Jennings, Paul C. (1973) Hysteretic response of a nine story reinforced concrete building during the San Fernando Earthquake. Technical Report: CaltechEERL:1973.EERL-73-07. California Institute of Technology.
Earthquake Engineering Research Laboratory, (1973) Research papers submitted to Fifth World Conference on Earthquake Engineering, Rome, Italy 25-29 June 1973. Technical Report: CaltechEERL:1973.EERL-73-02. California Institute of Technology.
Trifunac, Mihailo D. (1973) Routine computer processing of strong-motion accelerograms. Technical Report: CaltechEERL:1973.EERL-73-03. California Institute of Technology.
Earthquake Engineering Research Laboratory, (1973) Strong motion earthquake accelerograms, digitized and plotted data, Volume I - Uncorrected accelerograms; Part M - Accelerograms IM 176 through IM 184, Accelerograms from the San Fernando, California, earthquake of February 9, 1971. Technical Report: CaltechEERL:1973.EERL-72-26. California Institute of Technology.
Earthquake Engineering Research Laboratory, (1973) Strong motion earthquake accelerograms, digitized and plotted data, Volume I - Uncorrected accelerograms; Part N - Accelerograms IN185 through IN197, Accelerograms from the San Fernando, California, earthquake of February 9, 1971. Technical Report: CaltechEERL:1973.EERL-72-27. California Institute of Technology.
Earthquake Engineering Research Laboratory, (1973) Strong motion earthquake accelerograms, digitized and plotted data, Volume I - Uncorrected accelerograms; Part O - Accelerograms 1O198 Through 1O213, Accelerograms from the San Fernando, California, earthquake of February 9, 1971. Technical Report: CaltechEERL:1973.EERL-73-20. California Institute of Technology.
Earthquake Engineering Research Laboratory, (1973) Strong motion earthquake accelerograms, digitized and plotted data, Volume I - uncorrected accelerograms; Part P - Accelerograms IP214 through IP232, Accelerograms from the San Fernando, California, earthquake of February 9, 1971. Technical Report: CaltechEERL:1973.EERL-73-21. California Institute of Technology.
Earthquake Engineering Research Laboratory, (1973) Strong motion earthquake accelerograms, digitized and plotted data, Volume I - Uncorrected accelerograms; Part Q - Accelerograms IQ233 through IQ243, Accelerograms from the San Fernando, California, earthquake of February 9, 1971. Technical Report: CaltechEERL:1973.EERL-73-22. California Institute of Technology.
Earthquake Engineering Research Laboratory, (1973) Strong motion earthquake accelerograms, digitized and plotted data, Volume II - corrected accelerograms and integrated ground velocity and displacement curves; Part B - Accelerograms IIB021 through IlBO40. Technical Report: CaltechEERL:1973.EERL-72-50. California Institute of Technology.
Earthquake Engineering Research Laboratory, (1973) Strong motion earthquake accelerograms, digitized and plotted data, Volume II - corrected accelerograms and integrated ground velocity and displacement curves; Part C - Accelerograms IIC041 through IIC055. Technical Report: CaltechEERL:1973.EERL-72-51. California Institute of Technology.
Earthquake Engineering Research Laboratory, (1973) Strong motion earthquake accelerograms, digitized and plotted data, Volume II - corrected accelerograms and integrated ground velocity and displacement curves; Part D - Accelerograms IID056 through IID070. Technical Report: CaltechEERL:1973.EERL-72-52. California Institute of Technology.
Earthquake Engineering Research Laboratory, (1973) Strong motion earthquake accelerograms, digitized and plotted data, Volume II - corrected accelerograms and integrated ground velocity and displacement curves; Part E - Accelerograms IIE071 through IIE085. Technical Report: CaltechEERL:1973.EERL-73-50. California Institute of Technology.
Earthquake Engineering Research Laboratory, (1973) Strong motion earthquake accelerograms, digitized and plotted data, Volume II - corrected accelerograms and integrated ground velocity and displacement curves; Part F - Accelerograms IIF086 through IIF105. Technical Report: CaltechEERL:1973.EERL-73-51. California Institute of Technology.
Earthquake Engineering Research Laboratory, (1973) Strong motion earthquake accelerograms, digitized and plotted data, Volume II - corrected accelerograms and integrated ground velocity and displacement curves; Part G - Accelerograms IIG106 through IlGI14. Technical Report: CaltechEERL:1973.EERL-73-52. California Institute of Technology.
Udwadia, F. E. and Trifunac, Mihailo D. (1973) The Fourier transform, response spectra and their relationship through the statistics of oscillator response. Technical Report: CaltechEERL:1973.EERL-73-01. California Institute of Technology.
Irvine, H. Max (1973) The Veracruz earthquake of 28 August 1973. Technical Report: CaltechEERL:1973.EERL-73-06. California Institute of Technology.
Earthquake Engineering Research Laboratory, (1972) Analyses of strong motion earthquake accelerograms, Volume III - Response spectra; Part A - Accelerograms IIA001 through IIA020. Technical Report: CaltechEERL:1972.EERL-72-80. California Institute of Technology.
Earthquake Engineering Research Laboratory, (1972) Analyses of strong motion earthquake accelerograms, Volume IV - Fourier amplitude spectra; Part A - Accelerograms IIA001 through IIA020. Technical Report: CaltechEERL:1972.EERL-72-100. California Institute of Technology.
Wood, John H (1972) Analysis of the earthquake response of a nine-story steel frame building during the San Fernando earthquake. Technical Report: CaltechEERL:1972.EERL-72-04. California Institute of Technology.
Jennings, Paul C. (1972) Dynamics of building-soil interaction. Technical Report: CaltechEERL:1972.EERL-72-01. California Institute of Technology.
Udwadia, F. E. (1972) Investigation of earthquake and microtremor ground motions. Technical Report: CaltechEERL:1972.EERL-72-02. California Institute of Technology.
Jennings, Paul C. (1972) Rapid calculation of selected fourier spectrum ordinates. Technical Report: CaltechEERL:1972.EERL-72-05. California Institute of Technology.
Earthquake Engineering Research Laboratory, (1972) Strong motion earthquake accelerograms, digitized and plotted data, Volume I - Uncorrected accelerograms; Part G - Accelerograms IG106 through IG114. Technical Report: CaltechEERL:1972.EERL-72-20. California Institute of Technology.
Earthquake Engineering Research Laboratory, (1972) Strong motion earthquake accelerograms, digitized and plotted data, Volume I - Uncorrected accelerograms; Part F - Accelerograms IF086 through IF105, Accelerograms from the San Fernando, California, earthquake of February 9, 1971. Technical Report: CaltechEERL:1972.EERL-71-23. California Institute of Technology.
Earthquake Engineering Research Laboratory, (1972) Strong motion earthquake accelerograms, digitized and plotted data, Volume I - Uncorrected accelerograms; Part H - Accelerograms IH115 through IH127, Accelerograms from the San Fernando, California, earthquake of February 9, 1971. Technical Report: CaltechEERL:1972.EERL-72-21. California Institute of Technology.
Earthquake Engineering Research Laboratory, (1972) Strong motion earthquake accelerograms, digitized and plotted data, Volume I - uncorrected accelerograms; Part I - Accelerograms 1I128 Through 1I140, Accelerograms from the San Fernando, California, earthquake of February 9, 1971. Technical Report: CaltechEERL:1972.EERL-72-22. California Institute of Technology.
Earthquake Engineering Research Laboratory, (1972) Strong motion earthquake accelerograms, digitized and plotted data, Volume I - Uncorrected accelerograms; Part J - Accelerograms IJ141 through IJ152, Accelerograms from the San Fernando, California, earthquake of February 9, 1971. Technical Report: CaltechEERL:1972.EERL-72-23. California Institute of Technology.
Earthquake Engineering Research Laboratory, (1972) Strong motion earthquake accelerograms, digitized and plotted data, Volume I - Uncorrected accelerograms; Part K - Accelerograms IK 153 Through IK 165, Accelerograms from the San Fernando, California, earthquake of February 9, 1971. Technical Report: CaltechEERL:1972.EERL-72-24. California Institute of Technology.
Earthquake Engineering Research Laboratory, (1972) Strong motion earthquake accelerograms, digitized and plotted data, Volume I - uncorrected accelerograms; Part L - Accelerograms IL166 through IL175, Accelerograms from the San Fernando, California, earthquake of February 9, 1971. Technical Report: CaltechEERL:1972.EERL-72-25. California Institute of Technology.
Skattum, Knut Sverre (1971) Dynamic analysis of coupled shear walls and sandwich beams. Technical Report: CaltechEERL:1971.EERL-71-06. California Institute of Technology.
Bielak, Jacobo (1971) Earthquake response of building-foundation systems. Technical Report: CaltechEERL:1971.EERL-71-04. California Institute of Technology.
Jennings, Paul C. (1971) Engineering features of the San Fernando earthquake of February 9, 1971. Technical Report: CaltechEERL:1971.EERL-71-02. California Institute of Technology.
Jennings, Paul C. and Matthiesen, R. B. and Hoerner, John Brent (1971) Forced vibration of a 22-story steel frame building. Technical Report: CaltechEERL:1971.EERL-71-01. California Institute of Technology.
Trifunac, Mihailo D. and Udwadia, F. E. and Brady, Arthur Gerald (1971) High frequency errors and instrument corrections of strong-motion accelerograms. Technical Report: CaltechEERL:1971.EERL-71-05. California Institute of Technology.
Hoerner, John Brent (1971) Modal coupling and earthquake response of tall buildings. Technical Report: CaltechEERL:1971.EERL-71-07. California Institute of Technology.
Adu, Randolph Ademola (1971) Response and failure of structures under stationary random excitation. Technical Report: CaltechEERL:1971.EERL-71-03. California Institute of Technology.
Earthquake Engineering Research Laboratory, (1971) Strong motion earthquake accelerograms, digitized and plotted data, Volume I - uncorrected accelerograms; Part C - Accelerograms IC041 through IC055. Technical Report: CaltechEERL:1971.EERL-71-20. California Institute of Technology.
Earthquake Engineering Research Laboratory, (1971) Strong motion earthquake accelerograms, digitized and plotted data, Volume I - uncorrected accelerograms; Part D - accelerograms ID056 through ID070. Technical Report: CaltechEERL:1971.EERL-71-21. California Institute of Technology.
Earthquake Engineering Research Laboratory, (1971) Strong motion earthquake accelerograms, digitized and plotted data, Volume I - uncorrected accelerograms; Part E - Accelerograms IE071 through IE085. Technical Report: CaltechEERL:1971.EERL-71-22. California Institute of Technology.
Earthquake Engineering Research Laboratory, (1971) Strong motion earthquake accelerograms, digitized and plotted data, Volume II - corrected accelerograms and integrated ground velocity and displacement curves; Part A - Accelerograms IIA001 through IIA020. Technical Report: CaltechEERL:1971.EERL-71-50. California Institute of Technology.
Hudson, Donald E. (1971) Strong-Motion Instrumental data on the San Fernando Earthquake of Feb. 9, 1971. Technical Report: CaltechEERL:1971.EERL.1971.001. California Institute of Technology.
Keightley, W. O. (1970) A strong-motion accelerograph array with telephone line interconnections. Technical Report: CaltechEERL:1970.EERL-70-05. California Institute of Technology.
Heitner, Kenneth Leon (1970) Additional investigations on a mathematical model for calculation of the run-up of tsunamis. Technical Report: CaltechEERL:1970.EERL.1970.001. California Institute of Technology.
Trifunac, Mihailo D. (1970) Ambient vibration test of a thirty-nine story steel frame building. Technical Report: CaltechEERL:1970.EERL-70-02. California Institute of Technology.
Trifunac, Mihailo D. and Hudson, Donald E. (1970) Laboratory evaluations and instrument corrections of strong-motion accelerograms. Technical Report: CaltechEERL:1970.EERL-70-04. California Institute of Technology.
Trifunac, Mihailo D. (1970) Low frequency digitization errors and a new method for zero baseline correction of strong-motion accelerograms. Technical Report: CaltechEERL:1970.EERL-70-07. California Institute of Technology.
Trifunac, Mihailo D. (1970) On the Statistics and possible triggering mechanism of earthquakes in Southern California. Technical Report: CaltechEERL:1970.EERL-70-03. California Institute of Technology.
Trifunac, Mihailo D. (1970) Response envelope spectrum and interpretation of strong earthquake ground motion. Technical Report: CaltechEERL:1970.EERL-70-06. California Institute of Technology.
Earthquake Engineering Research Laboratory, (1970) Strong motion earthquake accelerograms, digitized and plotted data, Volume I - uncorrected accelerograms; Part B - Accelerograms IB21 through IB40. Technical Report: CaltechEERL:1970.EERL-70-21. California Institute of Technology.
Trifunac, Mihailo D. (1970) Wind and microtremor induced vibrations of a twenty-two story steel frame building. Technical Report: CaltechEERL:1970.EERL-70-01. California Institute of Technology.
Heitner, Kenneth Leon (1969) A mathematical model for calculation of the run-up of tsunamis. Technical Report: CaltechEERL:1969.EERL.1969.001. California Institute of Technology.
Tsai, N. C. (1969) Influence of local geology on earthquake ground motion. Technical Report: CaltechEERL:1969.EERL.1969.002. California Institute of Technology.
Trifunac, Mihailo D. (1969) Investigation of strong earthquake ground motion. Technical Report: CaltechEERL:1969.EERL.1969.003. California Institute of Technology.
Earthquake Engineering Research Laboratory, (1969) Strong motion earthquake accelerograms, digitized and plotted data, Volume I - uncorrected accelerograms; Part A - Accelerograms IA1 through IA20. Technical Report: CaltechEERL:1969.EERL-70-20. California Institute of Technology.
Nigam, Navin Chandra and Jennings, Paul C. (1968) Digital calculation of response spectra from strong-motion earthquake records. Technical Report: CaltechEERL:1968.EERL.1968.002. California Institute of Technology.
Jennings, Paul C. and Housner, George W. and Tsai, N. C. (1968) Simulated earthquake motions. Technical Report: CaltechEERL:1968.EERL.1968.001. California Institute of Technology.
Peters, Rex Bredesen (1968) Strong motion accelerograph evaluation. Technical Report: CaltechEERL:1968.EERL.1968.004. California Institute of Technology.
U. S. Coast and Geodetic Survey. Seismological Field Survey, and Earthquake Engineering Research Laboratory, (1968) Strong-Motion Instrumental data on the Borrego Mountain Earthquake of 9 April 1968. Technical Report: CaltechEERL:1968.EERL.1968.003. California Institute of Technology.
Spencer, Richard A (1968) The nonlinear response of some multistory reinforced and prestressed concrete structures subjected to earthquake excitation. Technical Report: CaltechEERL:1968.EERL.1968.005. California Institute of Technology.
Husid, Raul (1967) Gravity effects on the earthquake response of yielding structures. Technical Report: CaltechEERL:1967.EERL.1967.004. California Institute of Technology.
Nigam, Navin Chandra (1967) Inelastic interactions in the dynamic response of structures. Technical Report: CaltechEERL:1967.EERL.1967.006. California Institute of Technology.
Lutes, Loren Daniel (1967) Stationary random response of bilinear hysteretic systems. Technical Report: CaltechEERL:1967.EERL.1967.001. California Institute of Technology.
Hallanger, Lawrence W (1967) The dynamic stability of an unbalanced mass exciter. Technical Report: CaltechEERL:1967.EERL.1967.005. California Institute of Technology.
Giberson, Melbourne Fernald (1967) The response of nonlinear multi-story structures subjected to earthquake excitation. Technical Report: CaltechEERL:1967.EERL.1967.002. California Institute of Technology.
Kuroiwa, Julio Horiuchi (1967) Vibration test of a multistory building. Technical Report: CaltechEERL:1967.EERL.1967.003. California Institute of Technology.
Brady, Arthur Gerald (1966) Studies of response to earthquake ground motion. Technical Report: CaltechEERL:1966.EERL.1966.001. California Institute of Technology.
Hanson, Robert D (1965) Post-elastic dynamic response of mild steel structures. Technical Report: CaltechEERL:1965.EERL.1965.001. California Institute of Technology.
Hanson, Robert D (1965) Static and dynamic tests of a full-scale steel-frame structure. Technical Report: CaltechEERL:1965.EERL.1965.002. California Institute of Technology.
Keightley, W. O. (1964) A Dynamic investigation of Bouquet Canyon Dam. Technical Report: CaltechEERL:1964.EERL.1964.002. California Institute of Technology.
Nielsen, Niels Norby (1964) Dynamic response of multistory buildings. Technical Report: CaltechEERL:1964.EERL.1964.004. California Institute of Technology.
Alford, Jack L. and Housner, George W. and Martel, R. R. (1964) Spectrum analyses of strong-motion earthquakes. Technical Report: CaltechEERL:1964.EERL.1964.001. California Institute of Technology.
O'Kelly, Michael Edmond James (1964) Vibration of viscously damped linear dynamic systems. Technical Report: CaltechEERL:1964.EERL.1964.003. California Institute of Technology.
Jennings, Paul C. (1963) Response of simple yielding structures to earthquake excitation. Technical Report: CaltechEERL:1963.EERL.1963.002. California Institute of Technology.
Keightley, W. O. (1963) Vibration tests of structures. Technical Report: CaltechEERL:1963.EERL.1963.001. California Institute of Technology.
Hudson, Donald E. (1962) Synchronized vibration generators for dynamic tests of full-scale structures. Technical Report: CaltechEERL:1962.EERL.1962.001. California Institute of Technology.
Jennings, Paul C. (1962) Velocity spectra of the Mexican earthquakes of 11 May and 19 May 1962. Technical Report: CaltechEERL:1962.EERL.1962.002. California Institute of Technology.
Hudson, Donald E. (1961) A New vibration exciter for dynamic tests of full scale structures. Technical Report: CaltechEERL:1961.EERL.1961.001. California Institute of Technology.
Merchant, Howard C (1961) Mode superposition methods applied to linear mechanical systems under earthquake type excitations. Technical Report: CaltechEERL:1961.EERL.1961.004. California Institute of Technology.
Iwan, Wilfred D. (1961) The Dynamic response of bilinear hysteretic systems. Technical Report: CaltechEERL:1961.EERL.1961.002. California Institute of Technology.
Keightley, W. O. and Housner, George W. and Hudson, Donald E. (1961) Vibration tests of the Encino Dam intake tower. Technical Report: CaltechEERL:1961.EERL.1961.003. California Institute of Technology.
Caughey, Thomas Kirk and Hudson, Donald E. and Powell, R. V. (1960) The C.I.T. Mark II electric analog type response spectrum analyzer for earthquake excitation studies. Technical Report: CaltechEERL:1960.EERL.1960.001. California Institute of Technology.
Hudson, Donald E. and Iwan, Wilfred D. (1960) The Wilmot survey type strong-motion earthquake recorder (The U.S.C.G.S. Seismoscope) part II. Technical Report: CaltechEERL:1960.EERL.1960.002. California Institute of Technology.
Hudson, Donald E. (1958) The Wilmot survey type strong-motion earthquake recorder. Technical Report: CaltechEERL:1958.EERL.1958.001. California Institute of Technology.
Caughey, Thomas Kirk and Hudson, Donald E. (1954) An electric analog type response spectrum analyzer for earthquake excitation studies. Technical Report: CaltechEERL:1954.EERL.1954.002. California Institute of Technology.
Housner, George W. (1954) Earthquake pressures on fluid containers. Technical Report: CaltechEERL:1954.EERL.1954.003. California Institute of Technology.
Hudson, Donald E. and Housner, George W. (1954) Vibration tests of a steel-frame building. Technical Report: CaltechEERL:1954.EERL.1954.001. California Institute of Technology.
Housner, George W. (1953) A Dislocation theory of earthquakes. Technical Report: CaltechEERL:1953.EERL.1953.001. California Institute of Technology.
Housner, George W. (1953) Analysis of the Taft accelerogram of the earthquake of 21 July 1952. Technical Report: CaltechEERL:1953.EERL.1953.002. California Institute of Technology.
Housner, George W. (1952) Intensity of ground motion during strong earthquakes. Technical Report: CaltechEERL:1952.EERL.1952.001. California Institute of Technology.
Hudson, Donald E. and Alford, Jack L. and Housner, George W. (1952) Response of a structure to an explosive-generated ground shock. Technical Report: CaltechEERL:1952.EERL.1952.002. California Institute of Technology
[-] The following 25 users Like Administrator 's post:25 users Like Administrator 's post
  β€’ Dell_Brett, Dell_Brett, aslam, aslam, Ultra Zone, Ultra Zone, junaid, junaid, struceng, struceng, abudabeeja, abudabeeja, essam2109, essam2109, kamran, kamran, juice, juice, rendel_Β©, miquan, cordoba123, melkat, Grunf, gulilero, oanm2000
 miquan
Vietnam
User ID: 631
Threads: 171
Likes: 3,748 in 387 posts
Given Likes: 1331
12-06-2010, 01:00 PM (This post was last modified: 12-06-2010, 01:22 PM by miquan.)
Seismic Design of Asymmetric Ductile Systems
Size: 6.32 MB | Format: PDF
[Image: 13066049848780849504.png]
PhD Thesis of R. Castillo at University of Canterbury, 2004
Seismic Design of Torsionally Eccentric Building with U-Shaped RC Walls
Size: 1.89 MB | Format: PDF
[Image: 73843422423132478557.png]
PhD Thesis of K. Beyer at ROSE School
Only chapter 7 (main content about torsion)
[-] The following 4 users Like miquan's post:4 users Like miquan's post
  β€’ usman, Administrator , Sumatra, oanm2000
Away  jokerβ„’
User ID: 10925
Threads: 79
Likes: 7,246 in 938 posts
Given Likes: 2428
05-28-2012, 03:23 PM
plz re-upload post #2
No limits to creativity
  β€’
 mybest
Indonesia
User ID: 32155
Threads: 265
Likes: 3,957 in 566 posts
Given Likes: 686
05-28-2012, 05:29 PM
Joker, both are free to download. Search by google
[-] The following 7 users Like mybest's post:7 users Like mybest's post
  β€’ 3fan, Dell_Brett, jokerβ„’, miquan, oanm2000, Grunf, milova
  [REQUEST] Paper - Earthquake Engineering and Engineering Vibration Sumatra 2 2,423 09-02-2015, 01:38 PM
Last Post: ssobhan
