Civil Engineering Association eBooks Structural Books Other Materials (Wood, Brick, etc.) Polymers in Cementitious Materials
12-05-2010, 01:52 PM
Author: Michelle Miller | Size: 1 MB | Format: PDF | Publisher: Smithers Rapra Press | Year: 2008 | pages: 192 | ISBN: 9781859574911
[Image: 18513536922983435632.jpg]
Product Description:
"The construction industry increasingly requires products that are cost effective and easy to use, to enable fast track application whilst achieving a high physical performance. Incorporating a polymer in a cementitious mix brings key advantages, particularly in terms of workability, abrasion and impact resistance, with the resulting physical and chemical properties dependent upon the nature of the polymer material and the quantity used in relation to the cement phase.
This Rapra Handbook is intended to provide an insight into the uses of polymers within the construction industry. It describes the conception of polymer-modified cementitious materials through to the array of polymer-basedorpolymer-modified material utilised in modern day construction.
It not only covers the use of polymers in direct combination with cement but polymer concrete, impregnation of polymers into the concrete substrate and other polymer-based products, (i.e., coatings and adhesives). Both natural and synthetic polymers are reviewed.
This book is aimed at all those who are working with cement, and also at anyone who needs more information about this most versatile of materials, offering insight into:
the common polymers used in cementitious materials polymer concrete polymer Portland cement concrete reinforcement using synthetic fibres adhesives and coatings "
  â€¢ kowheng, kmmh76, Dell_Brett, mary, usman, cigutierrezg, faros3000, nigema
  Determination of Additives in Polymers and Rubber TAFATNEB 1 1,847 11-23-2016, 08:57 AM
Last Post: PinkPant
  Ferrocement & Laminated Cementitious Composites ir_71 2 2,982 05-08-2013, 09:24 AM
Last Post: subin91
  Corrosion of Polymers and Elastomers, 2nd Ed Dell_Brett 1 2,148 01-07-2013, 08:39 AM
Last Post: shadabg
  Polymers in Asphalt: Rapra Review Report 179 ir_71 1 2,220 10-22-2012, 07:18 AM
Last Post: shadabg
  Polymers in Construction portal61 1 2,233 08-21-2012, 09:23 AM
Last Post: shadabg
