Civil Engineering Association eBooks Journals, Papers and Presentations Methods of resisting hydrostatic uplift in substructures by I. H. Wong
 aslam
Abu Dhabi
User ID: 64
Threads: 330
Likes: 7,707 in 755 posts
Given Likes: 2168
11-30-2010, 07:55 AM (This post was last modified: 06-07-2011, 05:40 AM by Grunf.)
by I. H. Wong
Mitic Associates, 95 Cashew Road #03-03, Singapore 679666, Singapore
Received 5 March 2001;
revised 8 May 2001;
accepted 10 May 2001.
Available online 13 August 2001.
Abstract:
Many underground structures are constructed for use as car parks and shops in basements of buildings and as mass rapid transit stations, depressed roadways and civil defense shelters in cities located in coastal areas where the ground is level and the elevations are low, with an attendant high groundwater table. This paper discusses the various methods of resisting hydrostatic uplift. These include the use of tension piles and the installation of a water pressure relief system under the base slab of the basement. A case history in Singapore employing a pressure relief system below a three-level basement is presented.
Author Keywords: Deep excavation; Groundwater pressure; Uplift; Stiff; Soft soils
Article Outline
1. Introduction
2. Mechanism of flotation caused by hydraulic uplift
3. Conventional methods to resist uplift
3.1. Toeing in of base slab into surrounding ground
3.2. Increasing dead weight of structure
3.3. Ground anchors
3.4. Tension piles
4. Design of tension piles
5. Methods to reduce or eliminate uplift
6. Design of under-drain system
6.1. Operating costs
7. Effects of dewatering on adjacent ground and structures
8. Case history Raffles City
8.1. Site conditions
8.2. Performance of under-drain system
9. Beneficial effects of pressure relief system for waterproofing of basement
10. Conclusions
References
Updated link:
[-] The following 4 users Like aslam's post:4 users Like aslam's post
  • techno, zero85, RyanRS, ykhackhack
 kuyasipil
User ID: 20057
Threads: 21
Likes: 247 in 15 posts
Given Likes: 111
06-07-2011, 02:11 AM (This post was last modified: 06-07-2011, 02:18 AM by kowheng.)
[-] The following 13 users Like kuyasipil's post:13 users Like kuyasipil's post
  • techno, shaqee, dbsimon29, knrsa, oreslaw, oanm2000, HungNguyen29, ambrish, tang1942, zero85, zrilek, peymanlord, cepot
06-07-2011, 05:43 AM
[Image: comments.png]
Uploaded: Jun/07/2011
File Size: 701.13 KB
Paginated,
Searchable text
[-] The following 16 users Like Grunf's post:16 users Like Grunf's post
  • Jackass, blaze, ebaturalp, malc, seriousboy, ssi3k, oanm2000, lasalleguy, sodapas, gatob, zrilek, stanco, Trishu999, peymanlord, avscorreia, ykhackhack
 lisine
Vanuatu
User ID: 17927
Threads: 272
Likes: 11,709 in 1,305 posts
Given Likes: 4621
11-12-2015, 12:17 PM
[-] The following 17 users Like lisine's post:17 users Like lisine's post
  • avscorreia, dinu69in, PinkPant, ting tsai huang, oanm2000, RyanRS, techno, Rainbow, bridgeengineer, cace-01, zrilek, ruaumoko, gulilero, Dell_Brett, ykhackhack, milova, Hengki
  DURABILITY OF POST-TENSIONED BRIDGE SUBSTRUCTURES ir_71 0 4,978 12-08-2010, 02:55 PM
