Civil Engineering Association eBooks Codes, Manual & Handbook British Standards (BS) BS 1427:2009 Guide to on-site test methods for the analysis of waters
11-21-2010, 05:52 AM
Author: EH/3/2 Committee | Size: 1 MB | Format: PDF | Publisher: BSI | Year: 2009 | pages: 120 | ISBN: 978 0 580 59059 7
[Image: 47159029461622428696.jpg]
BS 1427 describes methods for the analysis of industrial and other waters. These methods can be undertaken outside of the chemical laboratory, for example on-site tests. This guide is for testing when the purpose of the test is to characterize the water under test for quality or process control purposes. The test methods are simple procedures for use by a trained analyst or by an individual that has had appropriate training.
Since 1993, many industrial laboratories have been shut down and the use of on-site methods increased significantly. Non-analysts using proprietary test-kits carry out a very significant proportion of these tests.
This revision of BS 1427 contains updates to specific methods since the previous standard and provides guidance on the use of the much wider range of available commercial test-kits. Since 1993, the range, type and quality of commercial test-kits/apparatus have improved. The improvements include significant benefits in terms of increased reliability and ease of use for on site testing. The use of pre-packaged chemicals and reagents has also reduced health and safety risks associated with handling chemicals and enhanced the simplicity of testing.
Most of the methods described in this standard apply to use on clean or lightly polluted waters which might have undergone treatment or been modified for industrial use.
The types of waters that are normally tested include:
a) Boiler waters
b) Cooling waters
c) Waters from hot water systems
d) Waters from air conditioning systems
e) Waters from industrial air washing systems
f) Potable waters
g) Ground waters
h) Surface waters
i) Process waters
j) Swimming pool waters.
Who should use BS 1427?
Water industry samplers and analysts
Environmental and water treatment consultants
  â€¢ kmmh76, kowheng, Grunf, i_kabir, Dell_Brett, toa011, oanm2000, roaming79, utan
 i_kabir
Bangladesh
User ID: 741
Threads: 122
Likes: 3,231 in 259 posts
Given Likes: 446
11-21-2010, 06:42 AM
[-] The following 4 users Like i_kabir's post:4 users Like i_kabir's post
  â€¢ kowheng, Grunf, Dell_Brett, oanm2000
09-24-2012, 04:50 AM
New working links:
  â€¢ mahyarov, knrsa, lisine, Dell_Brett, Jackass, malc, utan, blaze, st77bel, miquan
  ISO 22762-1: Elastomeric seismic-protection isolators Part 1: Test methods poolmand 0 2,956 11-16-2024, 01:18 PM
  BS 7910:2005 Guide to methods for assessing the acceptability of flaws in metallic st ir_71 4 4,075 03-04-2020, 08:08 PM
Last Post: sabooryan
  BS EN 1340/AC:2006 Concrete kerb units - Requirements and test methods ir_71 2 3,150 07-22-2017, 07:41 AM
  BS EN 1338:2003 Concrete paving blocks. Requirements and test methods mybest 5 4,758 02-28-2016, 12:56 PM
  BS EN 196-5:2011 Methods of testing cement Part 5: Pozzolanicity test for pozzolanic ir_71 1 2,286 04-14-2015, 05:03 PM
Last Post: Veggeta
  BS EN 12859:2011 Gypsum blocks - Definitions, requirements and test methods ir_71 3 3,288 12-27-2014, 10:34 PM
Last Post: Veggeta
  BS 1377 PARTS 1 TO 9 : 1990 - Methods of Test for Soils for Civil Engineering Purpose Gabemzaman 5 7,211 01-24-2014, 06:02 PM
Last Post: jacs1976
