Civil Engineering Association eBooks Journals, Papers and Presentations ACI SP-265-15 Structural Concrete Beam Shear - Still a Riddle ?
 pssst
Romania
User ID: 3083
Threads: 19
Likes: 574 in 54 posts
Given Likes: 401
11-18-2010, 11:09 AM
Synopsis: The paper reviews the application of classical plasticity theory to shear
failure of structural concrete beams. The resistance of concrete to shearing deforma-
tions is described by the modified Coulomb failure criterion. For beams with shear
reinforcement, this leads to an upper bound solution based on yield lines minimizing
the combined work of yielding stirrups and cracking concrete, the coinciding lower
bound solution corresponding to an inclined compression field (the web-crushing
criterion). For beams without shear reinforcement, the optimal failure mechanism is
a single yield line (straight or hyperbolic) from load to support, the coinciding lower
bound solution corresponding to a compressive strut between the load and support
platens. The predicted failure mechanisms and ultimate loads are compared with
experimental evidence, and it is concluded that the plasticity approach goes a long
way toward solving the riddle of shear failure.
[Image: 90144266293721336378_thumb.png][Image: 56172927029985010691_thumb.png]
[-] The following 11 users Like pssst's post:11 users Like pssst's post
  â€¢ kowheng, ravisbassi, Dell_Brett, toa011, ziggywas1, Eaky, sodapas, Umer.Aleem, jf28, Jackass, malc
  A NEW MODEL FOR JOINT SHEAR FAILURE OF REINFORCED CONCRETE INTERIOR BEAM-TO-COLUMN JO TAFATNEB 0 4,090 06-01-2014, 03:35 PM
  Shear Coefficients for Timoshenko Beam Theory mariusz 3 9,710 03-01-2013, 06:05 AM
  Punching Shear Retrofit Method Using Shear Bolts for Reinforced Concrete Slabs under yanburak 0 4,237 09-15-2010, 01:23 AM
Last Post: yanburak
