11-14-2010, 06:49 AM
EN 1052 Methods of test for masonry
EN 1052-2:1999 Methods of test for masonry - Part 2: Determination of flexural strength
This European Standard specifies a method for determining the flexural strength of small masonry specimens for the two principal axes of loading. Guidance is given on the preparation of the specimens, the conditioning required before testing, the testing machine, the method of test, the method of calculation and the contents of the test report.
EN 1052-4:2000 Methods of test for masonry - Part 4: Determination of shear strength including damp proof course
This European Standard specifies a method for determining the in plane shear strength of horizontal bed joints in masonry incorporating sheet damp proof course material using a specimen tested in double shear with load applied perpendicular to the bed joints. Guidance is given on the preparation of the specimens, the conditioning required before testing, the testing machine, the method of test, the method of calculation and the contents of the test report.
EN 1052-5:2005 Methods of test for masonry - Part 5: Determination of bond strength by the bond wrench method
This document specifies a method for determining the bond strength of horizontal bed joints in masonry using a bond wrench.
Guidance is given on the preparation of the specimens, the conditioning required before testing, the testing equipment, machine, the method of test, the method of calculation and the contents of the test report.
:JC_cheers:
