Civil Engineering Association eBooks Codes, Manual & Handbook British Standards (BS) BS 6031:2009 Code of practice for earthworks
10-28-2010, 07:03 PM (This post was last modified: 01-09-2011, 06:45 AM by ir_71.)
[Image: 48766481299011873834.jpg]
This standard gives recommendations and guidance for unreinforced earthworks forming part of general civil engineering construction, with the exception of dams. This standard also gives recommendations and guidance for temporary excavations such as trenches and pits.
NOTE Reinforced earthworks are covered in BS 8006-1 and BS 8006-2. This document applies to earthworks classified as Geotechnical Category 1, 2 and 3 structures as defined in BS EN 1997-1:2004.
thumbup
[-] The following 34 users Like ir_71's post:34 users Like ir_71's post
  â€¢ allagui10, ziggywas1, Dell_Brett, toa011, ruwan75, oanm2000, shaqee, hmwere, isurya, kowheng, jcbv, ascetic19, kaci, peixoto, daywalker, cordoba123, chenamoy, roaming79, salahcivil, zrilek, Adam Smith, cristi, blaze, nhim4mat2006, avscorreia, ziadjordan, ssi3k, almadar12, robertsas, mowafi3m, rohailiyaz, dbsimon29, grass, vinnunsam
09-21-2012, 05:14 PM
New working links:
  â€¢ cace-01, malc, miquan, Andrew seah, Jackass, blaze, lisine, Dell_Brett, knrsa, Trishu999, jayvijayyy, vinnunsam
 PinkPant
Turkey
User ID: 25448
Threads: 67
Likes: 4,007 in 374 posts
Given Likes: 10354
11-09-2016, 04:05 AM
Use regular forum pass
PinkPant
[-] The following 13 users Like PinkPant's post:13 users Like PinkPant's post
  â€¢ zrilek, avge, asumi, oanm2000, Evandrojr, Aviator, Dell_Brett, vinnunsam, techno, monter, heogay43, blaze, rizal13
  BS 8006-1: Code of practice for Strengthened/reinforced soils and other fills ir_71 8 8,005 05-29-2024, 12:10 PM
  BS 5930:2015+A1:2020 - Code of practice for ground investigations concreteok 0 3,829 07-25-2023, 10:35 AM
Last Post: concreteok
  BS 6349-1: Maritime Structures: Code of Practice for General Criteria Gabemzaman 9 9,916 06-07-2023, 05:10 AM
Last Post: ersin
  BS 8476: Code of practice for the safe use of concrete pumps ir_71 2 3,365 02-12-2022, 08:00 AM
  BS 5262:1991 Code of practice for External renderings ir_71 3 3,638 07-31-2021, 08:00 PM
Last Post: monter
  BS 8102:1990 Code of practice for Protection of structures against water from the gro ir_71 6 5,178 07-31-2021, 07:54 PM
Last Post: monter
  BS 8102:2009 - Code of practice for protection of below ground structures against wat Mohammad6299 1 2,496 02-17-2021, 11:20 AM
Last Post: temp1366
