Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Theses, Journals and Papers Request [REQUEST] ASCE Journal/Proceedings
[Request] ASCE Journal/Proceedings
 yanburak
User ID: 27551
Threads: 74
Likes: 821 in 94 posts
Given Likes: 421
#41
10-15-2010, 03:03 AM
Please, help me to download this papers:
1. Double-Layer Grids: Review of Static and Thermal Analysis Methods
J. Struct. Engrg. Volume 122, Issue 8, pp. 873-881 (August 1996)
Ramesh B. Malla and Reynaud L. Serrette
2. Double-Layer Grids: Review of Dynamic Analysis Methods and Special Topics
J. Struct. Engrg. Volume 122, Issue 8, pp. 882-892 (August 1996)
3. Effective Strength of 'Square-and-Diagnonal' Double-Layer Grid
J. Struct. Engrg. Volume 118, Issue 1, pp. 52-72 (January 1992)
Toshitsugu Saka and Yoshiya Taniguchi
Thanks.
[-] The following 1 user Likes yanburak's post:1 user Likes yanburak's post
  β€’ fer962933
 onest30
User ID: 21849
Threads: 4
Likes: 118 in 26 posts
Given Likes: 132
#42
10-15-2010, 05:10 AM (This post was last modified: 10-15-2010, 05:22 AM by onest30.)
Yanburak,
find the papers listed below in the link at the bottom:
here is the link:
ps: unfortunately I have not access to the 3 paper
Vladimir,
Complex Edge Stiffeners for Thin-Walled Members
J. Struct. Engrg. Volume 132, Issue 2, pp. 212-226 (February 2006)
B. W. Schafer, A. Sarawit, and T. PekΓΆz
Distortional Buckling of Cold-Formed Stainless Steel Sections: Experimental Investigation
J. Struct. Engrg. Volume 132, Issue 4, pp. 497-504 (April 2006)
Maura Lecce and Kim J. R. Rasmussen
Lateral Behavior of Plasterboard-Clad Residential Steel Frames
J. Struct. Engrg. Volume 125, Issue 1, pp. 32-39 (January 1999)
Emad F. Gad, Adrian M. Chandler, Colin F. Duffield, and Graeme Stark
Screwed Connection Tests of Thin G550 and G300 Sheet Steels
J. Struct. Engrg. Volume 125, Issue 2, pp. 128-136 (February 1999)
Colin A. Rogers and Gregory J. Hancock
Crippling Capacity of Web Elements with Openings
J. Struct. Engrg. Volume 125, Issue 2, pp. 137-141 (February 1999)
R. A. LaBoube, W. W. Yu, S. U. Deshmukh, and C. A. Uphoff
here is the link
[-] The following 10 users Like onest30's post:10 users Like onest30's post
  β€’ struceng, yanburak, Vladimir, Dell_Brett, goober, jcbv, chigozie, malc, Grunf, fer962933
 ynopum
Burundi
User ID: 2733
Threads: 24
Likes: 2,399 in 365 posts
Given Likes: 155
#43
10-15-2010, 08:31 AM
Yan:
Quote:3. Effective Strength of 'Square-and-Diagnonal' Double-Layer Grid
[-] The following 5 users Like ynopum's post:5 users Like ynopum's post
  β€’ Vladimir, goober, yanburak, chigozie, fer962933
 Vladimir
Ukraine
User ID: 19969
Threads: 25
Likes: 417 in 60 posts
Given Likes: 173
#44
10-18-2010, 04:34 PM
Please, help me with these papers:
Reversed Cyclic Performance of Shear Walls with Wood Panels Attached to Cold-Formed Steel with Pins
J. Struct. Engrg. Volume 135, Issue 8, pp. 959-967 (August 2009)
Reynaud Serrette and David P. Nolan
Shear Resistance of Gypsum-Sheathed Light-Gauge Steel Stud Walls
J. Struct. Engrg. Volume 122, Issue 4, pp. 383-389 (April 1996)
Reynaud Serrette, Kehinde Ogunfunmi
Estimating Drift in Cold-Formed Steel Frame Structures
Structures Congress 2006: Structural Engineering and Public Safety
Reynaud Serrette, Khanh Chau
Shift of Effective Centroid of Channel Columns
J. Struct. Engrg. Volume 125, Issue 5, pp. 524-531 (May 1999)
Ben Young and Kim J. R. Rasmussen
Prediction of Ultimate Capacity of Perforated Lipped Channels
J. Struct. Engrg. Volume 125, Issue 5, pp. 510-514 (May 1999)
Y. Pu, M. H. R. Godley, R. G. Beale, and H. H. Lau
Thanks, Vladimir.
[-] The following 1 user Likes Vladimir's post:1 user Likes Vladimir's post
  β€’ fer962933
 radespino
User ID: 28029
Threads: 2
Likes: 107 in 11 posts
Given Likes: 0
#45
10-19-2010, 02:53 AM (This post was last modified: 10-19-2010, 03:55 AM by BennyP.)
ASCE JOURNAL REQUEST
[-] The following 6 users Like radespino's post:6 users Like radespino's post
  β€’ Vladimir, yanburak, goober, jcbv, chigozie, fer962933
 denim
User ID: 24721
Threads: 8
Likes: 13 in 7 posts
Given Likes: 50
#46
10-19-2010, 03:45 AM
From Journal of Structural Engineering -- November 2010
Geometrically Nonlinear Analysis of Plane Frames Subjected to Temperature Changes
Aslam Kassimali and Juan J. Garcilazo
pp. 1342-1349
thanks!
[-] The following 1 user Likes denim's post:1 user Likes denim's post
  β€’ fer962933
 zinduy
User ID: 31185
Likes: 9 in 2 posts
Given Likes: 2
#47
10-19-2010, 06:41 AM (This post was last modified: 10-19-2010, 06:44 AM by Grunf.)
Here is your request:
[-] The following 6 users Like zinduy's post:6 users Like zinduy's post
 Vladimir
Ukraine
User ID: 19969
Threads: 25
Given Likes: 173
#48
10-24-2010, 05:56 PM
Axial Compression Tests of Cold-Formed Angles
J. Struct. Engrg. Volume 125, Issue 5, pp. 515-523 (May 1999)
D. Popovic, G. J. Hancock, and K. J. R. Rasmussen
Bending and Torsion of Cold-Formed Channel Beams
J. Struct. Engrg. Volume 125, Issue 5, pp. 540-546 (May 1999)
Bogdan M. Put, Yong-Lin Pi, and N. S. Trahair
Longitudinal Fillet Welds in Thin-Walled C450 RHS Members
J. Struct. Engrg. Volume 125, Issue 8, pp. 821-828 (August 1999)
Xiao-Ling Zhao and Riadh Al-Mahaidi
Void-Filled SHS Beams Subjected to Large Deformation Cyclic Bending
J. Struct. Engrg. Volume 125, Issue 9, pp. 1020-1027 (September 1999)
Xiao-Ling Zhao, Raphael Grzebieta
Axial Fatigue Performance of Cold-Formed Steel Sections
J. Struct. Engrg. Volume 124, Issue 2, pp. 149-157 (February 1998)
Sherif K. Hassan, D. Polyzois, G. Morris
Thanks, Vladimir.
  β€’ fer962933
 onest30
User ID: 21849
Threads: 4
Given Likes: 132
#49
10-24-2010, 06:40 PM
Vladimir,
find the papers refered below in the link at the bottom:
here is the link
  β€’ Dell_Brett, Grunf, jcbv, Vladimir, yanburak, goober, husni02, toshi615, malc, fer962933
 Vladimir
Ukraine
User ID: 19969
Threads: 25
Given Likes: 173
#50
10-30-2010, 05:18 PM
I'm looking for these papers:
Design of Lipped Channel Columns
J. Struct. Engrg. Volume 124, Issue 2, pp. 140-148 (February 1998)
Ben Young, Kim J. R. Rasmussen
Tests of Fixed-Ended Plain Channel Columns
J. Struct. Engrg. Volume 124, Issue 2, pp. 131-139 (February 1998)
Behavior of Gypsum-Sheathed Cold-Formed Steel Wall Studs
J. Struct. Engrg. Volume 120, Issue 5, pp. 1644-1650 (May 1994)
Thomas H. Miller, Teoman Pekoz
Load-Eccentricity Effects on Cold-Formed Steel Lipped-Channel Columns
J. Struct. Engrg. Volume 120, Issue 3, pp. 805-823 (March 1994)
Unstiffened Strip Approach for Perforated Wall Studs
J. Struct. Engrg. Volume 120, Issue 2, pp. 410-421 (February 1994)
Thanks, Vladimir.
  β€’ fer962933
Pages (72): « Previous 1 2 3 4 5 6 7 8 9 10 … 72 Next »
  [REQUEST] ASCE Journal of Structural Engineering Vol. 132 (2006) mistahpablo 1 2,145 03-31-2017, 04:44 AM
Last Post: pezhmankhan
  [REQUEST] ASCE Journal of the Soil Mechanics and Foundation miquan 9 5,775 12-22-2014, 08:28 PM
Last Post: f_slikken
