Civil Engineering Association Software Software Installation Problems & Bugs Archive Problem Time history function not working with moving load cases?
 Coaster
User ID: 12435
Threads: 7
Likes: 7 in 3 posts
Given Likes: 1
10-14-2010, 12:35 AM
Hi,
I have created a linear direct integration time history load case, which contains a bridge live load pattern. This load pattern has a time history function associated.
The problem is that when I change the time history function, all the results stay the same...Even if I create a null time history function (all zeros throughout the time), I still get stresses and deformations in the structure, suggesting that the time history function is actually doing nothing!
Am I doing something wrong? Is this a bug? I've seen that time history functions work with static load cases...Can't it work with moving load cases?
Any help will be mostly appreciated!
 essenza
User ID: 865
Threads: 54
Likes: 296 in 111 posts
Given Likes: 294
10-14-2010, 03:24 PM
Hi
I think u should create moving load case that is presented as multi step static case. I know SAP2000 having this capabilities. In case you are interested in moving load dynamics i guess you should find other advanced software than SAP2000 as the equation of motion for dynamic interaction between vehicle and structure is quite complicated.
DE
 Coaster
User ID: 12435
Threads: 7
Likes: 7 in 3 posts
Given Likes: 1
10-14-2010, 03:32 PM
thank you for your suggestions! I'll have to do multi step static case then...
  Load Cases - Etabs elle 2 6,356 04-10-2010, 09:48 PM
Last Post: elle
  Time History Reading Problem ttperform 0 3,824 03-14-2010, 03:45 PM
Last Post: ttperform
