German geotechnical code DIN 1054.
Moderator note:
thread moved from request section of the forum.
(Grunf)
Hi, Ayman10
here is the link to the requested standard Code: Content of this section is hidden, You must be registered and upgrade your account to see this content.See this link to read how you can remove this limitation: π CLICK HERE π Good luck!
The following 14 users Like ir_71's post:β’ blaze, kaci, Dell_Brett, isurya, ynopum,
Hi, Ayman10.
I have something for you: DIN 1055-9: Code: Content of this section is hidden, You must be registered and upgrade your account to see this content.See this link to read how you can remove this limitation: π CLICK HERE π and DIN 1055-2 Code: Content of this section is hidden, You must be registered and upgrade your account to see this content.See this link to read how you can remove this limitation: π CLICK HERE π For EN 1997 - 1 and 2 you have to take a look on the topic for Eurocodes. I will post a new topic for some useful China web sites. Regards IR.
10-13-2010, 05:56 AM
EN 1997 (eurocode 7) will be mandatory in Germany. You will alsoneed the german NAD.
DIN organization will also publish DIN 1054-100 which will also be mandatory. (A draft version has already been published but it's too expensive to get). Other standards like DIN 4017, 4084, 4085 were revised after 2005 so that they are compatible with EC7 & DIN 1054 - 100. The current standard is DIN 1054:2005. It was corrected 3 or 4 times and was revised once. The initial version is also available in English. The version to come in the future (DIN 1054-100) will have all the material already contined in EC7 removed.
DIN EN 01997 - Eurocode 7 Entwurf, Berechnung und Bemessung in der Geotechnik
Code: Content of this section is hidden, You must be registered and upgrade your account to see this content.See this link to read how you can remove this limitation: π CLICK HERE π I have some problems with my connection. I prepared DIN 1055 but can't upload it. Permanently crash (only 22 mb). WILL BE UPLOADED!!! Additional to DIN 1055 I will upload you DIN 4019+4024+4084+4085+4095. This will take a time, because the source is very slow. DIN 1055-1_06.2002 DIN 1055-2 Entwurf_01.2007 DIN 1055-3_03.2006 DIN 1055-4 Berichtigung 1_03.2006 DIN 1055-4_03.2005 DIN 1055-5_07.2005 DIN 1055-6 Berichtigung 1_02.2006 DIN 1055-6_03.2005 DIN 1055-7_11[1].2002 DIN 1055-8_01[1].2003 DIN 1055-9_08[1].2003 DIN 1055-10_07[1].2004 DIN 1055-100_03[1].2001
Due to connection problems I had to split the files.
Perhaps somebody can organize it in one file. Regards DIN 01055 - Einwirkungen auf Tragwerke Code: Content of this section is hidden, You must be registered and upgrade your account to see this content.See this link to read how you can remove this limitation: π CLICK HERE π P. S. The other standards will be uploaded after I have changed my modem
The following 9 users Like bus001's post:β’ Grunf, julioreptil, Dell_Brett, concreteok, majkyy, kevin8107, utan, oreslaw, nhim4mat2006
My mistake
DIN 01054 Baugrund Code: Content of this section is hidden, You must be registered and upgrade your account to see this content.See this link to read how you can remove this limitation: π CLICK HERE π DIN 04019 Setzungsberechnungen Code: Content of this section is hidden, You must be registered and upgrade your account to see this content.See this link to read how you can remove this limitation: π CLICK HERE π DIN 04024 - Maschinenfundamente Code: Content of this section is hidden, You must be registered and upgrade your account to see this content.See this link to read how you can remove this limitation: π CLICK HERE π DIN 04084 - GelΓ€nde- und BΓΆschungsbruchberechnungen Code: Content of this section is hidden, You must be registered and upgrade your account to see this content.See this link to read how you can remove this limitation: π CLICK HERE π
The following 6 users Like bus001's post:β’ Dell_Brett, Grunf, Ayman10, oanm2000, oreslaw, nhim4mat2006
DIN 04085 - Baugrund, Berechnung des Erddrucks
Code: Content of this section is hidden, You must be registered and upgrade your account to see this content.See this link to read how you can remove this limitation: π CLICK HERE π DIN 04095 - DrΓ€nung zum Schutz baulicher Anlagen Code: Content of this section is hidden, You must be registered and upgrade your account to see this content.See this link to read how you can remove this limitation: π CLICK HERE π DIN 04123 - Ausschachtungen, GrΓΌndungen und Unterfangungen im Bereich bestehender GebΓ€ude Code: Content of this section is hidden, You must be registered and upgrade your account to see this content.See this link to read how you can remove this limitation: π CLICK HERE π DIN 04124 - BΓΆschungen, Verbau, Arbeitsraumbreiten Code: Content of this section is hidden, You must be registered and upgrade your account to see this content.See this link to read how you can remove this limitation: π CLICK HERE π That's it. Regards
The following 11 users Like bus001's post:β’ concreteok, Grunf, Dell_Brett, Ayman10, ynopum, blaze, oanm2000, cristi, oreslaw, sivlad, nhim4mat2006
This is DIN 1054-101 German edition.
WARNING note that the quality is poor (bitmap made with printscreen). Code: Content of this section is hidden, You must be registered and upgrade your account to see this content.See this link to read how you can remove this limitation: π CLICK HERE π .
12-08-2012, 11:12 PM
Links are dead. Could someone reupload DIN -1054 English version?.
Thanks! |
| GERMANY - DIN 4094 | PinkPant | 3 | 8,784 |
02-25-2017, 09:30 AM Last Post: deadlord_2 |
| GERMANY - DIN 1045 | ascetic19 | 1 | 6,014 |
12-01-2009, 08:47 AM Last Post: ascetic19 |
