Civil Engineering Association Software Software Installation Problems & Bugs Archive Problem Wind Load in ETABS
Wind Load in ETABS
 techno
User ID: 4555
Threads: 95
Likes: 244 in 127 posts
Given Likes: 2286
10-11-2010, 02:20 PM
can anyone explain how to assign wind load on structure in ETABS using the diaphragm concept?
 nuttapolk
User ID: 731
Likes: 4 in 2 posts
Given Likes: 855
10-12-2010, 05:06 PM
You must assign rigid diaphragm to floor (area/joint) by use assign diaphragm
When you assign load case, select wind load type and you can select auto standard such as ASCE7-05 it will automatically applied load to diaphragm.
Also you can choose user define in wind load case to assign the value of wind load to each floor diaphragm in term of table.
[-] The following 1 user Likes nuttapolk's post:1 user Likes nuttapolk's post
  • narendra
 techno
User ID: 4555
Threads: 95
Given Likes: 2286
10-12-2010, 10:22 PM
Dear nuttapolk,
1. select all slab elements, then assign diaphragm.
2. define wind load case such as windx and windy.
3. define load combination.
Is that as simple as this? Really appreciate.
[-] The following 2 users Like techno's post:2 users Like techno's post
  • ISTRAKTURA, narendra
 zipatton
User ID: 1594
Threads: 4
Likes: 251 in 66 posts
Given Likes: 123
10-13-2010, 04:25 AM
Hi,
It is not necessary to fill the outside walls of the model. Etabs takes the surface wind pressure as the distance between the floor diaphragm. It means that even you don't get walls in te model, the surface pressure will be calculate on the virtual walls. It is very powerful for structural models.
Best regards
Zipatt
[-] The following 2 users Like zipatton's post:2 users Like zipatton's post
  • concreteok, narendra
 jameschan
User ID: 2992
Threads: 1
Likes: 5 in 5 posts
Given Likes: 3
10-13-2010, 05:53 AM
Dear zipatton,
in my model, it consists of walls itself only. very less beam and column.
So, what's ur opinion?
[-] The following 1 user Likes jameschan's post:1 user Likes jameschan's post
  • narendra
 zipatton
User ID: 1594
Threads: 4
Given Likes: 123
10-13-2010, 06:43 PM
No problem,
You can get the surface you want in the table of "load pattern" of wine and then make all the amenagement you want. So if you have walls it is OK. The problem is when you do not get walls (openings buildings). And then, you use the load pattern table.
Please read carefully the manual called "latearal load", chapter 2. It is well explained (as usual with CSI).
Hope it is hlepful for you.
Best regards
Zipatton
[-] The following 1 user Likes zipatton's post:1 user Likes zipatton's post
  • narendra
  Etabs auto wind load skyscraper 5 9,897 09-07-2010, 11:11 PM
Last Post: nuttapolk
  Load Cases - Etabs elle 2 6,359 04-10-2010, 09:48 PM
Last Post: elle
  Load Combination for CSI-Etabs & Safe as per Indian Standards lucky_b2me 0 4,591 11-07-2009, 05:44 AM
Last Post: lucky_b2me
