Civil Engineering Association eBooks Journals, Papers and Presentations MULTI-SCALE COMPUTATIONAL SIMULATION OF PROGRESSIVE COLLAPSE OF STEEL FRAMES
 yanburak
User ID: 27551
Threads: 93
Likes: 821 in 94 posts
Given Likes: 421
10-03-2010, 11:47 AM
[Image: 26859860080283088771.jpg]
ABSTRACT
Progressive building collapse occurs when failure of a structural component leads to the
failure and collapse of surrounding members, possibly promoting additional collapse.
Global system collapse will occur if the damaged system is unable to reach a new static
equilibrium configuration. The objective of this research is to identify and investigate
important issues related to collapse of seismically designed steel building systems using
multi-scale computational models.
Coupled multi-scale finite element simulations are first carried out to investigate the
collapse response of moment resisting steel frame sub-assemblages. Simulation results
suggest that for collapse resistant construction, designers should strive to use a larger
number of smaller beam members rather than concentrate resistance in a few larger
members and should specify ASTM A-992 steel rather than specifying generic steels.
Improved behavior can also be achieved by increasing the shear tab thickness or directly
welding the beam web to the column.
Using information gleaned from the sub-assemblage simulations, computationally
efficient structural scale models for progressive collapse analysis of seismically designed
steel frames systems are developed. The models are calibrated and utilized within the
context of the alternate path method to study the collapse resistance of multistory steel
moment and braced frame building systems. A new analysis technique termed
“pushdown analysis” is proposed and used to investigate collapse modes, failure loads
and robustness of seismically designed frames. The collapse and pushdown analyses
show that systems designed for high seismic risk are less vulnerable to gravity-induced
progressive collapse and more robust than those designed for moderate seismic risk.
Motivated by a number of deficiencies in existing ductile fracture models for steel, a new
micro-mechanical constitutive model is proposed. Damage mechanics principles are used
and a scalar damage variable is introduced to represent micro-structural evolution related
to micro-void nucleation, growth and coalescence during the ductile fracture process in
steels. Numerical implementation and parametric studies are presented and discussed.
Calibration and validation studies show that the proposed model can successfully
represent ductile fracture of steels.
Although the system studies in this dissertation focused primarily on in-plane collapse
response, the models and simulation methodologies developed herein can be extended in
future work to address the collapse resistance of three-dimensional models.
7,05 Mb
[Image: 06863010127263689187.jpg]
[Image: 89204536475127751451.jpg][Image: 58374625607140065485.jpg]
[-] The following 5 users Like yanburak's post:5 users Like yanburak's post
  • kowheng, NAUTILUS87, cargadory2k, Dell_Brett, moh_towhid
  Seismic Design of Steel Special Moment Frames: A Guide for Practicing Engineers yanburak 2 8,203 08-04-2021, 08:44 PM
Last Post: Wijono
  Earthquake-Induced Collapse Simulation of a Super-Tall Mega-Braced Frame-Core Tube Bu TAFATNEB 1 8,356 10-30-2020, 08:45 AM
Last Post: gbn1980
  Progressive collapse analysis of an RC building with exterior partially infilled wall asim99 1 6,596 03-01-2017, 04:02 PM
Last Post: pezhmankhan
  Progressive Collapse of Multi-Storey Buildings due to Sudden Column Loss –Part II: Ap TAFATNEB 0 4,947 05-09-2014, 02:00 PM
  Retrofit Methods to Mitigate Progressive Collapse TAFATNEB 0 4,848 05-09-2014, 11:44 AM
  SIMULATION TECHNIQUES FOR COLLAPSE ANALYSIS OF RC BRIDGE UNDER STRONG EARTHQUAKE TAFATNEB 0 4,342 05-03-2014, 09:39 AM
  Progressive Collapse of Bridges—As pects of Analysis and Design TAFATNEB 0 4,373 05-02-2014, 09:02 AM
