Civil Engineering Association Software Software Installation Problems & Bugs Archive Problem STAAD.foundation V8i Release 5.0 Problem
 alcalan57
Junior Member
User ID: 3385
Threads: 5
Likes: 27 in 5 posts
Given Likes: 93
01-21-2010, 06:38 AM (This post was last modified: 01-21-2010, 07:35 AM by alcalan57.)
i am having problems when i use the foundation toolkit.
it stops working. when i use the the general foundation everything is fine
i'm using xp sp3 and foundation 5
does anyone have the same problem ?
fixed, i re install program and medicine and wallaaa working
 trebreh
User ID: 14487
Likes: 0 in 0 posts
Given Likes: 1
03-02-2010, 07:02 AM
staad foundation 5.0 cannot analyze mat foundation because it will appear that license is expired
 ASEC
United States
User ID: 13344
Threads: 15
Likes: 397 in 113 posts
Given Likes: 298
05-31-2010, 02:40 AM
Can someone probably fix the medicine for this so that mat design will also work.
 javier1212
User ID: 25002
Likes: 0 in 0 posts
Given Likes: 1
10-02-2010, 09:50 PM
I had the same problem with the mat analysis, and I copied the IEGLiclib.dll file and pasted it into every folder inside of C:/staad.foundation 5, but probably its neccesary only in the folder Analysis or SProStaad.
Now everything works fine.
 ASEC
United States
User ID: 13344
Threads: 15
Given Likes: 298
10-02-2010, 11:30 PM
Can you post the IEGLiclib.dll that you used. Thanks in advance
  Staad pro installation problem jigarcivil 4 8,080 10-11-2010, 06:17 PM
Last Post: ssi3k
