Civil Engineering Association eBooks Codes, Manual & Handbook A Professional's Handbook on Grouting and Concrete Repair
 tuanpecc1
Vietnam
User ID: 16595
Threads: 63
Likes: 1,427 in 86 posts
Given Likes: 1378
09-27-2010, 03:19 PM
[Image: 72815171735423631688.png]
Publisher: Five Star Products, Inc
Date : 2007
Pages : 122
Format : pdf
PREFACE
The American Society for Testing and Materials (ASTM), the Corp of Engineers and the American Concrete Institute (ACI), are key organizations responsible for establishing standards and specifications for nonshrink grout and concrete repair. The beneficial work of these organizations is important to industry. Reports, such as “Grouting between Foundations for the Support of Equipment and Machinery” (ACI 351.1R-99), provide an excellent overview for evaluating and selecting nonshrink grouts based on the different expansion mechanisms used by grout manufacturers. Because some of these expansion mechanisms have a significant effect on the successful use of grout products in the field, ACI 351.1R-99 is an important tool for owners, engineers, architects, specifiers and contractors.
However, the nature of some committees within industry organizations is to generate standards and practices around consensus. This is particularly evident with respect to nonshrink grout. Because of this, the term “nonshrink” is one that has often been used loosely and not clearly defined – certain “nonshrink” grouts available in the marketplace actually do exhibit shrinkage when tested by ASTM test methods. Because of this, engineers, architects, specifiers and owners must specify exact performance properties with respect to vertical height change characteristics of grouts, and contractors should understand the importance of the standards and specifications they are given. A successful grout job is the joint responsibility of the engineer, the contractor, and the manufacturer. The generic use of the term nonshrink in standards and specifications is insufficient. This handbook, in conjunction with ACI and ASTM standards, can guide the strengthening and use of product specifications to ensure proper selection, specification, and use of precision nonshrink grouts and concrete repair materials.
[-] The following 28 users Like tuanpecc1's post:28 users Like tuanpecc1's post
  • user, shaqee, vardan, kowheng, ziggywas1, jcbv, jcoronellr, ssi3k, toa011, DamaD, pezhmankhan, engr1900, roaming79, nhim4mat2006, bloodrn, durden, sacs, Galileo, narendra, sangen, cesar3226, cigutierrezg, sodapas, afandi_ali, shadabg, ykhackhack, lisine, andersen3
Threads: 1,298
09-30-2010, 02:38 PM
Hi, everybody.
You can find the Handbook mentioned above, and several other documents concerning cementitious and epoxy grouting on folowing link:
Good luck.
  • oanm2000, Umer.Aleem, sivlad, shadabg, ykhackhack
 usman
User ID: 59
Threads: 138
Likes: 6,571 in 671 posts
Given Likes: 4974
10-29-2010, 04:27 PM
Mirror
The original link is as mentioned by ir_71 in post #3, but it is in actual 31.2MB file, the link below is same file with 2.65MB without compromising the quality
[-] The following 8 users Like usman's post:8 users Like usman's post
  • shanta, chenamoy, toa011, salahcivil, cesar3226, Umer.Aleem, sivlad, ykhackhack
 Engramir
User ID: 42774
Threads: 1
Likes: 16 in 1 posts
Given Likes: 5
12-27-2012, 05:32 PM (This post was last modified: 12-27-2012, 05:37 PM by BennyP.)
[-] The following 16 users Like Engramir's post:16 users Like Engramir's post
  • techno, Quantumm, ykhackhack, ting tsai huang, malee, shadabg, isurya, malc, subin91, st77bel, Dell_Brett, nhim4mat2006, Hengki, uvsrao61, valinhas, Andrew seah
 Dell_Brett
Admin Deputy
Admin Deputy
Brazil
User ID: 4
Threads: 264
Likes: 19,035 in 2,188 posts
Given Likes: 42492
04-10-2013, 11:50 PM
  • st77bel, gulilero, shadabg, GMianG, Jackass, blaze
  Practical Guideline for Invetigation,Repair and Strenthening of Cracked Concrete Stru concreteok 0 1,746 03-19-2013, 12:46 PM
Last Post: concreteok
  The Grouting Handbook meditation 3 3,545 12-07-2010, 08:45 AM
  Handbook of Mold, Tool and Die repair Welding Ultra Zone 1 2,147 11-19-2009, 05:27 PM
Last Post: miquan
