Civil Engineering Association eBooks Structural Books Steel Non-Linear Static and Cyclic Analysis of Steel Frames with Semi-Rigid Connections
 Flexi
User ID: 300
Likes: 5,440 in 422 posts
Given Likes: 110
09-13-2009, 02:41 PM (This post was last modified: 08-27-2010, 08:52 AM by Grunf.)
[Image: 73340394620611866297.jpg]
By Siu-Lai Chan, Pui-Tak Chui
* Publisher: Elsevier Science
* Number Of Pages: 350
* Publication Date: 2000-03-01
* ISBN-10 / ASIN: 008042998X
* ISBN-13 / EAN: 9780080429984
* Binding: Hardcover
Product Description:
This book is devoted to the discussion and studies of simple and efficient numerical procedures for large deflection and elasto-plastic analysis of steel frames under static and dynamic loading.
In chapter 1, the basic fundamental behaviour and philosophy for design of structural steel is discussed, emphasising different modes of buckling and the inter-relationship between different types of analysis. In addition to this, different levels of refinement for non-linear analysis are described. An introduction is also given to the well-known P-&dgr; and P-&Dgr; effects. Chapter 2 presents the basic matrix method of analysis and gives several examples of linear analysis of semi-rigid pointed frames. It is evident from this that one must have a good understanding of first-order linear analysis before handling a second-order non-linear analysis. In chapter 3, the linearized bifurcation and second-order large deflection are compared and the detailed procedure for a second-order analysis based on the Newton-Raphson scheme is described. Chapter 4 introduces various solution schemes for tracing of post-buckling equilibrium paths and the Minimum Residual Displacement control method with arc-length load step control is employed for the post-buckling analysis of two and three dimensional structures. Chapter 5 addresses the non-linear behaviour and modelling of semi-rigid connections while several numerical functions for description of moment versus rotation curves of typical connection types are introduced. The scope of the work in chapter 6 covers semi-rigid connections and material yielding to the static analysis of steel frames. Chapter 7 studies the cyclic response of steel frames with semi-rigid joints and elastic material characteristics. In the last chapter the combined effects of semi-rigid connections and plastic hinges on steel frames under time-dependent loads are studied using a simple springs-in-series model. For computational effectiveness and efficiency, the concentrated plastic hinge concept is used throughout these studies.
[-] The following 31 users Like Flexi's post:31 users Like Flexi's post
  β€’ Dell_Brett, Dell_Brett, kowheng, kowheng, aslam, aslam, timosiβ„’, timosiβ„’, ingchio, ingchio, zrilek, zrilek, Administrator , Administrator , dajabar, dajabar, cristi, cristi, dr_lemon_tea, dr_lemon_tea, mishanya, mishanya, jocagalhao, jocagalhao, simanta, erick, Grunf, vardan, fer962933, david-smith, warbeast
 miquan
Vietnam
User ID: 631
Threads: 171
Likes: 3,748 in 387 posts
Given Likes: 1331
09-30-2010, 07:05 AM
New link:
[-] The following 5 users Like miquan's post:5 users Like miquan's post
  β€’ Grunf, zrilek, shmpabe, cesar3226, fer962933
Threads: 307
09-30-2010, 07:26 AM
Mirror links:
πŸ‘‰ CLICK HERE πŸ‘ˆ rared pdf 13.196 MB
If you like the book, we strongly suggest to buy it! Support the author(s)!
[-] The following 11 users Like Grunf's post:11 users Like Grunf's post
  β€’ AG.NAYEL, draluka, ladjin, zrilek, jcoronellr, cesar3226, fer962933, theanhpe, Jackass, inal_tab, david-smith
 miquan
Vietnam
User ID: 631
Threads: 171
Given Likes: 1331
08-10-2012, 02:57 AM
Author: S.L. Chan, P.P.T. Chui | Size: 13.2 MB | Format: PDF | Quality: Scanner | Publisher: ELSEVIER | Year: 2000 | pages: 355 | ISBN: 0 08 042998 X
Authors:
S.L. Chan
Department of Civil and Structural Engineering,
The Hong Kong Polytechnic University
P.P.T. Chui
Ove Arup and Partners (Hong Kong) Limited
(Formerly Department of Civil and Structural Engineering,
The Hong Kong Polytechnic University)
[-] The following 20 users Like miquan's post:20 users Like miquan's post
  β€’ malc, kowheng, jokerβ„’, Jackass, lisine, slowet, Dell_Brett, simanta, blaze, jcbv, pedzaquino, gulilero, chenamoy, david-smith, knrsa, oanm2000, wanwin, monter, febo927, chrono146
  Behaviour and Design of Steel and Composite Connections in Fire carolinandra 0 3,426 01-10-2023, 12:16 AM
Last Post: carolinandra
  Architecturally Exposed Structural Steel: Specifications, Connections, Details carolinandra 0 2,026 01-25-2019, 11:06 AM
  Design and Analysis of Connections in Steel Structures: Fundamentals and Examples amindoxiti 1 2,821 12-16-2018, 07:54 AM
Last Post: malee
  Proceedings of the Workshop on Connections in Steel Structures Flexi 4 5,272 06-14-2018, 01:14 PM
Last Post: gulilero
  Semi-rigid Connections Handbook ir_71 3 4,488 05-31-2016, 04:11 PM
Last Post: ssobhan
  SCI P101: Curtain wall connections to steel frames ir_71 3 4,141 02-27-2016, 04:51 AM
Last Post: cabpcabp
  Advanced Analysis of Steel Frames Theory, Software, and Applications abudabeeja 3 4,801 11-20-2014, 03:18 PM
