Civil Engineering Association eBooks Codes, Manual & Handbook British Standards (BS) BS EN 13242-2002 Aggregates for unbound and hydraulically bound materials for use in
 st77bel
Romania
User ID: 12964
Threads: 12
Likes: 432 in 86 posts
Given Likes: 696
09-25-2010, 04:51 AM (This post was last modified: 11-05-2010, 09:03 AM by Grunf. Edit Reason: N/A )
BS EN 13242:2002
Aggregates for unbound and hydraulically bound materials for use in civil engineering work and road construction
Status: Current
Publication Date: 12/12/02
Committee: B/502
ISBN: 0580409759
Pages: 42
International Equivalent: EN 13242:2002
Descriptors:
Aggregates, Construction materials, Road surfacing, Construction engineering works
Cross references:
EN 196-2, EN 932-3, EN 932-5, EN 933-1, EN 933-3, EN 933-4, EN 933-5, EN 933-8, EN 933-9, EN 1097-1, EN 1097-2:1998, EN 1097-6:2000, EN 1367-1, EN 1367-2, EN 1367-3, EN 1744-1:1998, EN 1744-3, ISO 565, prEN 13055-2:2000, 89/106/EEC, 98/598/EC, 93/68/EEC
Moderator note:
Info added. Thread moved from Request Section to Codes, Manual & Handbook Section. (Grunf)
  β€’
09-26-2010, 11:02 AM
Hi, st77bel
I have BS EN 13242:2002 in English and EN 13242:2002+A1:2007 in German.
Here are the links:
and
Good luck!
  β€’ Dell_Brett, st77bel, peixoto, Grunf, parwez007, vpmohammed
09-25-2012, 04:50 AM
BS EN 13242:2002+А1:2007 Aggregates for unbound and hydraulically bound materials for use in civil engineering work and road construction
Author: CEN/TC 154 "Aggregates" | Size: 0.78 MB | Format: PDF | Quality: Original preprint | Publisher: CEN | Year: 2007 | pages: 44 | ISBN: 9780580622953
[Image: 18165366547792942890.jpg]
This European Standard specifies the properties of aggregates obtained by processing natural or manufactured or recycled materials for hydraulically bound and unbound materials for civil engineering work and road construction.
It provides for the evaluation of conformity of the products to this European Standard.
˜NOTE 1 Aggregates used in construction should comply with all the requirements of this European Standard. As well as familiar and traditional natural and manufactured aggregates Mandate M/125 β€œAggregates” included recycled aggregates and some materials from new or unfamiliar sources. Recycled aggregates are included in the standards and new test methods for them are at an advanced stage of preparation. For unfamiliar materials from secondary sources, however, the work on standardisation has only started recently and more time is needed to define clearly the origins and characteristics of these materials. In the meantime such unfamiliar materials when placed on the market as aggregates must comply fully with this standard and national regulations for dangerous substances (see Annex ZA of the standard) depending upon their intended use. Additional characteristics and requirements may be specified on a case by case basis depending upon experience of use of the product, and defined in specific contractual documents.β„’
NOTE 2 Properties for lightweight aggregates are specified in EN 13055-2.
  β€’ kowheng, blaze, malc, Dell_Brett, peixoto, Jackass, lisine, st77bel, miquan
01-23-2017, 05:52 PM
  β€’ civilfafa, Dell_Brett, malc, zrilek
  BS ISO 12108:2002 Metallic materials. Fatigue testing. Fatigue crack growth method ir_71 2 3,041 12-24-2014, 11:25 AM
Last Post: sssiin
  BS EN 1097-10:2002 Tests for mechanical and physical properties of aggregates. Determ ir_71 0 1,916 08-20-2012, 02:43 PM
  BS EN 13285:2010 Unbound mixtures. Specifications ir_71 4 3,243 07-17-2012, 07:42 PM
