Civil Engineering Association Software Software Installation Problems & Bugs Archive Problem Static and Dynamic Analysis of Nonlinear Plane Structures
 88FeNIX
User ID: 24521
Threads: 39
Likes: 229 in 52 posts
Given Likes: 303
09-23-2010, 12:28 PM
Hi to all,
I am doing research and a need a software for Static and Dynamic Analysis of a Nonlinear Plane Structure. I have heard of DRAIN-2DX. But it works in DOS and ain't user friendly. Can any one suggest any other software with Graphical User interface?
 dert
User ID: 3632
Threads: 2
Likes: 11 in 5 posts
Given Likes: 19
09-23-2010, 12:40 PM (This post was last modified: 09-23-2010, 01:36 PM by BennyP.)
try nonlim pro.
NONLINPRO uses a (slightly) modified version of DRAIN2DX. The modification is not in the
calculation code, just in the file output.
good luck
try this website. it is free to download
[-] The following 2 users Like dert's post:2 users Like dert's post
  • 88FeNIX, fer962933
 Sumatra
User ID: 14369
Threads: 103
Likes: 1,925 in 240 posts
Given Likes: 1580
09-23-2010, 02:44 PM
Hi 88FeNIX,
I think sap2000 or etabs is one of the best user friendly program with a handy GUI. You can also try Seismostruct or Zeus-NL (in other version) for the best user friendly freeware programs for RC structure. however, these last two programs have the disadvantage which is its advantage at the same time: using fiber model for section analysis to define the member's hinge that is embeded in the program. it is meant the program automatically calculate the force-deformation curve for each member. unfotunately, the hinge definition is only for moment and axial-moment interaction. if you prefer to consider shear hinge in the analysis, these programs would not help you.
If your intention is for the research (to achieve a goal as close as posible to the real case), then you need the sophisticated program which is commonly not user friendly. Ruaumoko, Opensees, and DRAIN are strongly recommended for this task. :dash2:
cheers
adekajeng
[-] The following 2 users Like Sumatra's post:2 users Like Sumatra's post
  • moh_towhid, 88FeNIX
 88FeNIX
User ID: 24521
Threads: 39
Given Likes: 303
09-24-2010, 05:56 AM (This post was last modified: 09-24-2010, 05:58 AM by kowheng.)
Dear adekajeng,
You have been real helpful but i am also sorry that i didnt conveyed my problem completely. Actually i am right now doing research and using SAP but thought
that it is a commerical software.
Thanks a lot and i will give Seismostruct & Zeus-NL a go.
Moderator Notes:
  Nonlinear Static Analysis of a Multistory Plane Frame 88FeNIX 2 5,980 09-28-2010, 02:12 PM
Last Post: neikrof
  [HELP] NonLinear Dynamic Analysis using SAP2000 v14.1 anez_regar 3 8,269 05-30-2010, 12:34 PM
Last Post: anez_regar
  SAP2000: how to use NL-Link element for nonlinear analysis Sumatra 0 4,899 03-18-2010, 06:22 AM
Last Post: Sumatra
