Civil Engineering Association eBooks Structural Books Concrete Prescriptive Method for Insulating Concrete Forms in Residential Construction
 Dell_Brett
Admin Deputy
Admin Deputy
Brazil
User ID: 4
Threads: 246
Likes: 19,038 in 2,189 posts
Given Likes: 42508
09-21-2010, 05:59 AM
Prescriptive Method for Insulating Concrete Forms in Residential Construction - 2nd Ed.
[Image: 76922770602223144417.jpg]
Insulating Concrete Forms (ICFs) represent a category of building product that is receiving greater attention among builders. ICFs are hollow blocks, planks, or panels that can be constructed of rigid foam plastic insulation, a composite of cement and foam insulation, a composite of cement and wood chips, or other suitable insulation material that has the ability to act as forms for cast-in-place concrete walls. The forms typically remain in place after the concrete has cured, providing wellinsulated construction. ICFs continue to gain popularity because they are competitive with lightframe construction and offer a strong, durable, and energy-efficient wall system for housing.
The second edition expands on the first edition by adding provisions for Seismic Design Categories C and D (Seismic Zones 3 and 4). Wall construction requirements utilizing Grade 60 reinforcing steel and concrete mixes with selected compressive strengths are included. In addition, tables throughout the document have been simplified as a result of additional evaluation and user input.
[Image: 43265238868668653788.jpg]
[-] The following 9 users Like Dell_Brett's post:9 users Like Dell_Brett's post
  â€¢ vardan, kowheng, paladin, barukai, Nilupa, cristi, Ernest0, lednar_ved, pedzaquino
  Residential cellular concrete buildings ir_71 2 3,175 02-09-2018, 03:39 AM
Last Post: concreteok
  Masonery and concrete for residential construction Tonyanders 4 3,477 12-09-2015, 03:15 PM
  Standard Structural Designs for Low-Rise Residential Buildings in Reinforced Concrete david-smith 1 2,474 11-21-2012, 07:02 PM
Last Post: ska51
  Design and Construction using insulating Concrete Formwork gboyega 0 2,904 08-25-2009, 07:21 AM
Last Post: gboyega
