Civil Engineering Association Software Software Installation Problems & Bugs Archive Problem [REQUEST] Problem when install Revit Structure 2011
[Request] Problem when install Revit Structure 2011
 HungNguyen29
Junior Member
User ID: 27544
Threads: 11
Likes: 15 in 4 posts
Given Likes: 264
09-17-2010, 04:54 AM
Dear,
Now I'm using system program: win 7, 32 bits. When I install Revit Suite Structure 2011, I can't select the product Revit Structure 2011, only permited library of revit and Error report install from Autodesk. I don't uderstand what happening.
I need your help!!
Thanks and BestRegards,
New engineer
 kamran
Senior Member
User ID: 91
Threads: 61
Likes: 1,777 in 176 posts
Given Likes: 1299
09-17-2010, 08:45 AM
if you downloaded from Autodeswk web site ,
you should download revit structure libraries and temps
follow this post:
Kamran via HP :)
 angryits
User ID: 26884
Threads: 1
Likes: 0 in 0 posts
Given Likes: 4
09-17-2010, 10:13 AM
I'm sorry I'm to be new engineer, Revit Str can make 3D model only building ??
 kamran
Senior Member
User ID: 91
Threads: 61
Given Likes: 1299
09-17-2010, 10:38 AM
Autodesk® Revit® Structure building information modeling (BIM) software for structural engineering provides purpose-built tools for structural design and analysis. With the advantage of BIM, Revit Structure helps to improve multi-discipline coordination of structural design documentation, minimize errors, and enhance collaboration between structural engineering and architecture teams.
Kamran via HP :)
[-] The following 1 user Likes kamran's post:1 user Likes kamran's post
  • Grunf
 HungNguyen29
Junior Member
User ID: 27544
Threads: 11
Given Likes: 264
09-19-2010, 10:35 AM
Dear,
I found my problem is have to remove Dwf view, a component software of autodesk.
But, I met new problem when installing it, I can't configure bundle name: ENUHelpstr of 6 bundles of Revit Structure??
Thank and BestRegards
New Engineer
 RANA WASEEM
User ID: 10336
Threads: 119
Likes: 1,021 in 194 posts
Given Likes: 820
09-19-2010, 11:25 AM
Dear Hung.
Yes the main problem in VISTA is about dwg view..you have to uninstall the previous version because the new revit has the latest one..and about the second problem u mentioned, i didnt encounter this problem after solving the first problem. but any how you must use the Administrator account from windows VISTA and always TURN OFF UAC(User Account Control) by going to users in control panel before installing these type of large and rather complex installations..hope it will solve ur problem...otherwise u may be missing some installtion components.
WS
 HungNguyen29
Junior Member
User ID: 27544
Threads: 11
Given Likes: 264
09-20-2010, 02:14 AM
Dear Coss,
I turn off UAC before installed special software, so I think my revit file configuration not enough components.
Thank & BestRegards,
  [REQUEST] primavera to revit structure?? 1212 0 4,065 10-01-2010, 07:24 AM
Last Post: 1212
  Revit Structure 2011 license problem bluefish80 4 8,839 09-10-2010, 03:08 PM
Last Post: mdmh10
  DOMED ROOF in Revit Structure??? I need help alnasir 0 3,700 09-08-2010, 09:30 PM
Last Post: alnasir
  Rebar render in Revit Structure 2010 stigtg 3 7,086 07-09-2010, 07:32 PM
Last Post: stigtg
  Revit Structure 2010 (Help Menu) albert23rd 0 4,279 06-05-2010, 10:12 AM
Last Post: albert23rd
  Revit Structure for structural engineer asim99 6 10,300 12-30-2009, 09:10 AM
Last Post: migvytas
