Civil Engineering Association eBooks Journals, Papers and Presentations A NEW ROCK BOLT DESIGN CRITERION
 tuanpecc1
Vietnam
User ID: 16595
Threads: 62
Likes: 1,427 in 86 posts
Given Likes: 1378
09-18-2010, 03:09 PM
A NEW ROCK BOLT DESIGN CRITERION AND KNOWLEDGE-BASED EXPERT SYSTEM FOR STRATIFIED ROOF
ABSTRACT
Since its development in the 1920s, bolting has become the most dominant support method in underground construction. However, because of the geological environment, the design process for roof bolt systems is an art rather than a science. To quantify the selection of bolting systems a MSBT (minimum solid beam thickness) approach was developed. The ultimate goal of this bolt design paradigm was achieved by optimizing bolt length, bolt density, and bolt pretension during installation. The impact of the number of strata layers within bolting range and pretension applied to bolts upon the stability of an opening was investigated using FLAC model. Four statistical models for predicting optimum bolt supports using a minimum solid beam thickness were established, and based on these results, a design criterion was proposed.
To meet support needs in various geological and geotechnical settings, a variety of bolt types have been developed. The installation of such bolt-based support systems is often complex and specialized, and thus imposes a challenge for engineers to identify the specific cause and to take appropriate remedial measures once problems arise. To solve these problems, a knowledge-based expert system (KBES) has been developed. The knowledge base includes the data accumulated from years of laboratory and field investigations conducted by the Mine Safety and Health Administration of the US Department of Labor. A user-friendly Windows-based program was implemented using KAPPA environment. After identifying the problem, the KBES searches its knowledge base and reasons out the most likely, secondary, and other potential causes, then provides solutions according to users’ input.
The results of this research are validated and demonstrated using case studies.
[Image: 64995672282728453061.png]
[-] The following 11 users Like tuanpecc1's post:11 users Like tuanpecc1's post
  β€’ ziggywas1, Dell_Brett, kowheng, cigutierrezg, malc, peymanlord, shadabg, lisine, zrilek, kuyasipil, harsono
Threads: 154
09-06-2012, 07:18 AM
Direct Link :Wink
[-] The following 2 users Like shadabg's post:2 users Like shadabg's post
  β€’ blaze, Jackass
  Development of a probability based load criterion for American national standard A58 miquan 1 5,945 10-10-2014, 08:08 AM
Last Post: rusty
  numerical modelling for rock mechanics and rock engineering youceftli 1 5,430 10-31-2011, 09:02 PM
Last Post: youceftli
