Civil Engineering Association Software Software Installation Problems & Bugs Archive Problem frame partial fixity springs in SAP2000 or ETABS
 ralarcon
User ID: 2278
Threads: 7
Likes: 154 in 8 posts
Given Likes: 178
09-07-2010, 11:18 PM
Hello!
I want to simulate a metalic structure with intermedium values (p.e. 70% or 50% of stiffness) on the joints in SAP2000 or ETABS using:
Assign menu > Frame/Line > Frame Releases/Partial Fixity .
How can I find 'k' values that could simulate my reality?
Thank you
 PanosP
User ID: 13654
Threads: 3
Likes: 30 in 13 posts
Given Likes: 126
09-08-2010, 07:53 AM (This post was last modified: 09-09-2010, 04:36 PM by BennyP.)
I am supposing that you want to alter the stiffness of your current system. As such you would be interested in the active stiffness of this system. And by active I mean the effects your system feels at current state. As such if you want to find out the rotational stiffness of your beam, as part of a frame, at the left hand support then you need to extract the rotation of the node in question and then divide it by the equivalent moment of the beam at hand at the same node. The reciprocal of this ratio is the active stiffness at hand. Multiplication of this number by 0.7 would then yield the partial fixity for 70% stiffness level. A word of warning regarding the units of all the above numbers. Hope this helps.
Moderator Note:
[-] The following 4 users Like PanosP's post:4 users Like PanosP's post
  • salman22, mig21, ralarcon, deadlord
 parhyang
User ID: 25165
Threads: 28
Likes: 1,261 in 219 posts
Given Likes: 447
09-23-2010, 02:38 PM (This post was last modified: 09-25-2010, 06:27 AM by parhyang.)
fully rigid connection have stiffness k=lamda*4*E*I/L, where lamda > 100
if you want to define partial connection just multiple coefficient with these values.
gold rules, the units should be consistent.
 ralarcon
User ID: 2278
Threads: 7
Given Likes: 178
09-24-2010, 02:51 AM (This post was last modified: 09-24-2010, 03:01 AM by ralarcon.)
Thanks for the answers but I believe the correct solution is as explained in McGuire Matrix Structural Analysis chapter 13. this is not so simplified.
 parhyang
User ID: 25165
Threads: 28
Given Likes: 447
09-24-2010, 07:21 AM (This post was last modified: 09-24-2010, 07:38 AM by parhyang.)
yes i do make simplified as proposed by Romstad (1970),
Sc = n/(1-n)*4EI/L
you can verified by make simple example and play a role with fixity factors says 0.0 trough 1.0 (increment 0.2) and plot bending moment result, and you'll get clear.
about references you prefer, how do you apply alpha_1 and alpha_2 (p.394 of the books) in SAP2000. did you ever verify?
add shoot,
[Image: 54938593242537551120.png]
[-] The following 4 users Like parhyang's post:4 users Like parhyang's post
  • ralarcon, chigozie, yly8, fer962933
 ralarcon
User ID: 2278
Threads: 7
Given Likes: 178
09-24-2010, 02:47 PM
Could you tell me where I get the book where it appears the explanation of Romstad (1970)?
thanks
 parhyang
User ID: 25165
Threads: 28
Given Likes: 447
09-25-2010, 06:37 AM (This post was last modified: 09-25-2010, 06:54 AM by parhyang.)
i don't have original papers/report, i was taken from:
[Image: 73340394620611866297.jpg]
you can found these books in this tread,
btw, it's implemented too by MULTIFRAME developers.
take attention in SAP2000/ETABS steel design routine since moment magnification with "k" factor method is not appropriates for these type of connection, you should perform 2nd order p-delta analysis and follow DAM-AISC 2005 procedures.
[-] The following 6 users Like parhyang's post:6 users Like parhyang's post
  • Dell_Brett, ralarcon, Grunf, chigozie, jcoronellr, fer962933
  Response Modification Factor ( R ) via Pushover analysis using SAP2000/ETABS paladin 8 13,815 09-29-2010, 02:29 PM
Last Post: paladin
  Shear reinforcement for pushover analysis in SAP2000 / ETABS paladin 14 21,661 09-26-2010, 11:21 AM
Last Post: Sumatra
  basic concept of springs in safe farooq 6 9,590 09-23-2010, 03:01 PM
Last Post: parhyang
  Etabs and Sap2000 Column Design Ultra Zone 7 13,653 01-23-2010, 02:11 PM
Last Post: sonidero
