Civil Engineering Association Software Software Installation Problems & Bugs Archive Problem Beam Column Capacity Ratio
 foli
User ID: 15919
Threads: 2
Likes: 2 in 1 posts
Given Likes: 2
09-06-2010, 03:44 AM
I have a problem with the beam column capacity ratio at ETABS v.9.7.1.
When I used the ACI 318-05 to design the concrete frame, I can not to display the beam column capacity ratio. the result is N/A (not applicable) at the beam column capacity ratio out put.
But when I used the ACI 318-99 to design the concrete frame, I have no problem and I can to display the result of beam column capacity ratio.
Is there someone who can help me to solve this problem?
Best regards
Alvin
[-] The following 2 users Like foli's post:2 users Like foli's post
  • mecheil.edwar, BennyK
 salman22
User ID: 21608
Threads: 8
Likes: 14 in 9 posts
Given Likes: 24
09-06-2010, 04:24 AM
According to ETABS 9.7.0, following are the rules where it calculates the beam column capacity ratio:
Rules: Beam-column capacity ratio is only determined for a station
a) if the station has a beam-column joint (top of the column),
b) if the frame is a ductile moment resisting frame,
c) if the column above is a concrete column when it exists,
d) if all the beams framing into the column are concrete beams,
e) if the connecting member design results are available, and
f) if the load combo involves seismic load.
Kindly check your model for above.
[-] The following 2 users Like salman22's post:2 users Like salman22's post
  • RANA WASEEM, aslam
 foli
User ID: 15919
Threads: 2
Likes: 2 in 1 posts
Given Likes: 2
09-06-2010, 07:51 AM
I have re-check my model and have no problem for the above rules. I think there is no problem with my model because if I change the concrete design code with the oldest code like ACI 318-99, there is no problem with Beam-column capacity ratio in ETABS.
 ascetic19
User ID: 100
Threads: 16
Likes: 498 in 65 posts
Given Likes: 673
09-06-2010, 10:36 AM
dear foli,
i think you are right. i spent an hour over small model.
unfortunately, i could not get any result from 318-05.
it seems there is bug about this code.
regards,
ascetic19
[-] The following 1 user Likes ascetic19's post:1 user Likes ascetic19's post
  • mecheil.edwar
 vsa2010
User ID: 22156
Threads: 9
Likes: 422 in 53 posts
Given Likes: 64
09-08-2010, 01:37 AM
dear ascetic19 & foli,
I import etabs v6 model(very old version) to v9.7.1
Result of analyze is ok:
v6 and v9.7.1 have the same displacements and member forces.
But i got the same problem:
ACI 318-05: no result (N/A)
ACI 318-99: no problem
I think maybe we miss something in v9.7.1
Best regards
vsa2010
[-] The following 1 user Likes vsa2010's post:1 user Likes vsa2010's post
  • robertsas
 robertsas
Indonesia
User ID: 655
Threads: 155
Likes: 5,665 in 416 posts
Given Likes: 3149
09-08-2010, 04:21 AM
Dear all,
Yes, I had try in ETABS v. 9.6 for all ACI 318 there is no problem.
But in ETABS v 9.5 for ACI 318-02 is no problem but ACI 318-05 has problem.
and ETABS v .9.7.1, I have same problem with ACI 318-05.
anyone could explain ??
regards,
robertsasmita
[-] The following 1 user Likes robertsas's post:1 user Likes robertsas's post
  • mecheil.edwar
 vccalderon
El Salvador
User ID: 12783
Threads: 2
Likes: 21 in 4 posts
Given Likes: 70
09-08-2010, 04:56 AM
You should check to see if you have a strong column - weak beam, sometimes that's the problem and all you have to do is increase the size of the column. I did once what some of you were saying about changing the code, that's right it pases with ACI318-99 ist's not an error it's just that the 05 and further codes have more requirements.
Good Bye I hope this helps you a little bit
 ascetic19
User ID: 100
Threads: 16
Given Likes: 673
09-08-2010, 07:22 AM
dear vccalderon,
i tried what you said
but there is no solution.
on the other hand if you look at the joint shear calculation in cloumn design window,
the program does not recognize the rebar areas from elements. i think this is the problem
program; design according to 318-05, can not read rebar areas
regards,
  • mecheil.edwar
 mecheil.edwar
Senior Member
User ID: 27088
Threads: 25
Likes: 612 in 216 posts
Given Likes: 1759
09-26-2010, 09:04 PM
Also I did many trails and I got the same results
Etabs design the joint based on ACI 99 and ACI 2002 but No desgin result for ACI 2005
I will search again and if I get any new results I will Inform.
 mecheil.edwar
Senior Member
User ID: 27088
Threads: 25
Given Likes: 1759
#10
10-05-2010, 06:44 PM
Now It is a Bug inside Etabs
I prepared one model in Sap 14.2 and same model in Etabs 9.7.1
both of them Support ACI 2005/IBC 2003
I got results for design of joint with Sap
But I got non result for design of joint with Etabs N/A
So It is Bug with Etabs Program
Hoping next realse they will fix this bug
Pages (2): 1 2 Next »
