Civil Engineering Association eBooks Journals, Papers and Presentations Determination of Wind Loads on Building and Other Structures
 ali akbar
User ID: 21331
Threads: 96
Likes: 491 in 83 posts
Given Likes: 927
09-02-2010, 09:26 AM (This post was last modified: 09-02-2010, 09:45 AM by Grunf.)
[Image: 86706469098845156734_thumb.jpg]
The post contains two presentations on determination of wind loads on building and other structures. This is a series of three presentations. However, the last presentation which explains the second method (analytical procedure) of wind load calculations based on ASCE-05, is not finished yet and shall be prepared soon. By the time it is finished, I will post it.
Thanks
[-] The following 13 users Like ali akbar's post:13 users Like ali akbar's post
  β€’ majeed, hapsea, mig21, Dell_Brett, PSMUSACALA, melkat, oanm2000, cristi, jcbv, maad59, jcoronellr, malc, tang1942
 matthewkmk
User ID: 24442
Threads: 7
Likes: 3 in 3 posts
Given Likes: 9
09-03-2010, 02:13 AM
Does these presentations refer to ASCE or other codes? thx
  β€’
 ali akbar
User ID: 21331
Threads: 96
Given Likes: 927
09-05-2010, 08:27 AM
(09-03-2010, 02:13 AM)matthewkmk Wrote: Does these presentations refer to ASCE or other codes? thx
They are completely based on ASCE-05 as stated in the first slide.
[-] The following 1 user Likes ali akbar's post:1 user Likes ali akbar's post
  β€’ oanm2000
  Influence of diagonal braces in RCC multi-storied frames under wind loads: A case stu TAFATNEB 0 4,163 11-25-2013, 04:36 PM
  Modelling and Analysis of Infilled Frame Structures Under Seismic Loads TAFATNEB 0 4,081 09-10-2013, 01:52 PM
  Challenges in the computation of lower-bound buckling loads for tanks under wind pres asim99 0 3,764 04-02-2013, 11:39 PM
  Computation of Wind Flow around a Tall Building and the Large--Scale Vortex Structure asim99 0 4,353 12-31-2012, 02:09 AM
  e-Analysis of High-Rise Buildings Subjected to Wind Loads ivanveliki 1 6,575 01-29-2012, 07:07 AM
Last Post: kvtasp
  [ASCE] Methods of Calculating Wind Loads on Long‐Span Girder Bridges with Tall Piers mybest 0 4,621 11-27-2011, 07:40 AM
Last Post: mybest
